May 20th, 2009, 10:12 PM | #1 |
Name: jason & char
Join Date: Mar 2009 Motorcycle(s): 08 kawi 250r Posts: 46
hesitation?
today when i was out on my bike , it started to hesitate between 8000 - 9000rpm's also the bike will not red line it will only go to 12000rpms.
hade this problem before changed the spark plugs cleaned the intake problem went away this time not so lucky. can anyone help? |
May 20th, 2009, 10:14 PM | #2 |
any mods done to the bike? how many miles on it?
May 20th, 2009, 10:27 PM | #3 |
Name: jason & char
12000km
2 brothers pipe slip on k&n filter |
May 21st, 2009, 01:29 AM | #4 |
by K&N filter... are you talking about a replacement panel for the stock filter or have you removed the airbox and installed a stand alone filter?
May 21st, 2009, 06:13 AM | #5 |
oddly enough my box stock 2009 (US carbs model), "hiccupped" at 8K rpm yesterday in 3rd and 4th gear. Weather was in the 70s, bike was warm, road was flat and I had gone about 10 miles. Choke was off (as I know it should be, but someone might ask). By hiccupped I mean it hit 8,000 dropped to about 7,500 then climbed to 9,000. Don't know if it would have climbed higher as I was getting to slower part of road. On the next straight road it went to 9K without hesitation in 4th gear. Never noticed it before. Will check it out on highway tonight. Believe it or not I am usually under 8k rpm due to the roads I usually ride.
May 24th, 2009, 07:38 PM | #6 |
Name: jason & char
just the slid in filter dident know thay had the a stand alone 1
May 24th, 2009, 07:47 PM | #7 | |
Name: jason & char
I always am riding my bike hard, so I was scared I broke somethin so I feel a bit better that ur 09 had this similar thing happen. not in that way. Dont want u to have this problem just I always beat up my bike so I was scared it might be really bad. I hope I figuer out the problem is its to nice for my bike to be down for fixin. hahaha |
May 24th, 2009, 07:50 PM | #8 |
have you made any jetting changes and what did the plugs look like when you changed them?
May 24th, 2009, 08:09 PM | #9 | |
May 24th, 2009, 10:18 PM | #10 |
there have been some ignitor issues that have caused some tach inaccuaracies, but I don't recall it ever affecting the bike at the 8K range.
May 25th, 2009, 02:51 PM | #11 |
Name: jason & char
May 25th, 2009, 02:53 PM | #12 |
what gear are you in that it won't go to redline? in all gears? if in all gears, what does it do when it reaches 12000rpm?
May 26th, 2009, 04:59 AM | #13 |
Name: jason & char
all but 1st n 2nd thay r still ok
and when it gets there its just like im stop given her gas but if i change gears the bike will keep speedin up |
May 26th, 2009, 11:35 AM | #14 |
that's strange.
I'm assuming the bike ran fine before this? My guess... you are actually at redline cutoff when you are reading 12K. It's the tach reading that might be off. The hesitation might be caused by a faulty ignition component... which could be the ignitor. The reason I point to the ignitor is that it could be also giving you the false redline reading on the tach. If the bike is still under warranty, take it to a dealer to get it checked out. |
May 27th, 2009, 03:30 PM | #15 | |
Name: jason & char
i may have got a bad spark plug so im goin to get a new set of ngks and see if it helps my problem do u know the part number for them i cant find it |
May 27th, 2009, 03:40 PM | #16 |
I believe it's in your owner's manual.
May 30th, 2009, 06:52 AM | #17 | |
Psychic war veteran
Join Date: May 2009 Motorcycle(s): Kawi Green '09 Ninja ZX6R Posts: 663
Assuming that everything else is 100% with fresh fuel, etc., (espeically on a relatively stock bike) and you're jetting is correct, or at least close enough that this is a NEW issue, CDIs are known to display funky tach readings from about 7500 up to about 9000 just like you're describing. It could be a heat related issue. The CDI is WELL KNOWN to be heat sensitive, and heat will play hell with electronics, and once it starts going bad, it's bad. It may be intermitant, and most notable with long running times or higher ambient temps outside. IF you are NOT noticing or feeling a REAL change in performance, it's the CLASSIC sign of a CDI going bad, especially if, as I suspect, you're riding it more and the daily temperature is going higher each day. Also be aware that the electronics heat up the longer you ride, regardless of outside temperature, too. This actually sounds like what has happening to my bike with the second CDI that I had in it. As it heated up, it went AFU and actually affected how the bike was running (sent wrong timing info to BOTH coils). The first, and the third unit only displayed funky tach readings, but the second one made the bike sputter and stumble terribly once it got hot. Before it finally died, the tech guy at the shop actually got it to fail repeatedly by removing it and placing it in the fridge, then installing it and heating it at idle with a hair dryer. Somewhere around 100F ambient as measured on the CDI case, it would stumble and choke. If you put an ice pack on it and cooled it off, it would run just fine! If it's consistent, and repeatable, and a NEW issue, then something has changed. My money is on the CDI. If you can duplicate it, and you're still under warranty, take it to the dealer. Welcome to the "Kawi spec'd crappy electronics in the 08+ Ninja 250 CDI" club.
* If you're arguing with some idiot over the internet, chances are pretty good he's doing the same thing! Zodiac Mindwarp and the Love Reaction |
June 12th, 2009, 07:00 PM | #18 | |
Name: jason & char
well i was out on the bike td n i noticed that now 3rd 4th 5th n 6thafter 8gs on the tach the bike is now back fireing n it wont go over 12gs also when i start the bike most of the times it gives a BIG BANG n a flame shoots out the tail pipe i asked a friend that knows small motors n he said if u have a back fire on a lawn more shim the carb on it n it will take away the back fire away i have not shimed the carb yet do u think it will help |
Hesitation/Stumbling 6K to 8K - Looking for Source - Ideas? | eif | 1986 - 2007 Ninja 250R Tech Talk | 5 | June 23rd, 2014 05:40 PM |
Power hesitation when accelerating? | mrb | 2008 - 2012 Ninja 250R Tech Talk | 17 | December 5th, 2013 02:35 PM |
Light WOT Hesitation? | JMcDonald | 2008 - 2012 Ninja 250R Tech Talk | 24 | September 16th, 2010 05:41 PM |
Up and down surging/hesitation at low RPMs | elicash80 | 1986 - 2007 Ninja 250R Tech Talk | 2 | August 29th, 2010 04:04 PM |
Bad stumble/hesitation | Cedilla | 2008 - 2012 Ninja 250R Tech Talk | 11 | October 17th, 2009 05:29 PM |
