June 6th, 2009, 06:20 PM | #1 |
Join Date: Apr 2009 Motorcycle(s): '09 Ninja 250R Posts: 171
Too much oil bad?
How bad is it to over fill the oil?
Went in for maitenance and the ****ers put an idiot to work on my bike. ****ing idiot ended up putting way to much. Went back and they syphoned out some but it's still above the line in the looking glass. Now my turn to be the idiot was when I took this as being ok after their explanation. Now 400 km later my bike is making noises. The oil light hasn't come on but i'm starting to think it might be that. Is it bad for the bike?.... Should i do an oil change right away or just let some of it out? I swear if this ruined my bike even the least.
Back on the road again Season 2010 Dam it feels good! |
June 6th, 2009, 08:39 PM | #2 |
That's me!
Join Date: Nov 2008 Motorcycle(s): 2008 Ninja 250r (Tis blue), 2008 CBR600RR Posts: 454
It's bad. Even though oil IS the lifeblood of your engine, I almost err on the side of low oil then high oil. If the crankshaft is able to slap the oil it can/will cause the oil to foam up, it causes a drain on power and will kill your oil in short order.
If you lean the bike over to the left side (when sitting on it), can you get the oil level to go down? If you're tilting it over and no matter what you can't get the oil level to show on the site glass, it's probably way to full. I'd also be concerned with what TYPE of oil they put in... |
June 6th, 2009, 08:40 PM | #3 |
Live Life
Join Date: Nov 2008 Motorcycle(s): 2009 Green SE Ninja 250 Posts: A lot.
Excess oil can be bad ranging from over pressure to foaming which would reduce the effectiveness of the oil. With the bike level the oil should be between the two lines on the sight glass. I'd first check the level and if it is still out-of-sight high call the dealer, remind him what happened and what you have and ask him what he wants you to do. I wouldn't accept the "don't worry your little head" answer. Just get it on the record there are still issues.
Then get the oil level down to where it belongs.
- ATGATT - Scorpion EX700 Hi-Vis Helmet, First Gear MeshTek 3.0 Jacket, TourMaster Transition 2 Jacket and Flex Pants, Sidi Doha boots |
June 6th, 2009, 08:58 PM | #4 | |
June 6th, 2009, 09:06 PM | #5 |
That's me!
Flashback 10 years ago... I had shoddy work done on one of my first Camaros and noticed that finding a quality shop is difficult to say the least. I have never been back to a shop for any reason ever. It's rather extreme and I don't suggest becoming a mechanic to everyone (to avoid getting crappy work done), but in the case of motorcycles (especially the 250s) they are STUPID easy to work on.
So long story short, for most any maintenance I'd suggest getting a manual and doing things yourself. That and forums are a glorious thing! |
June 6th, 2009, 10:24 PM | #6 | |
Join Date: Mar 2009 Motorcycle(s): '09 Blue Kawasaki KLE650 Versys, '95 Ducati 900SS/CR (undergoing track conversion) Posts: 287
June 6th, 2009, 11:07 PM | #7 |
June 7th, 2009, 04:58 AM | #8 |
MOTM - Sep '18, Feb '16
In engines class I answered every question on every test correct .I got high honors .The only question I got wrong was.Will excess oil cause oil starvation ? I said no . The answer is yes . Because of the oil foaming . I don't remember any of the other questions .But I sure remember that one.
June 7th, 2009, 09:15 AM | #9 |
correct... the oil can foam from being whipped up by the crank, which leads to the foam being picked up by the oil pump, which delivers foam (air/oil) to the normally "oiled" parts, which then results in inadequate lubrication. not too good for the crank, too.
June 8th, 2009, 04:50 AM | #10 |
Join Date: May 2009 Motorcycle(s): 2009 blue ninja 250R Posts: 742
It must happen a lot. I overfilled my 250 in the first week or so because I was checking the oil level improperly. Took it to the dealer and he immediately took out a special pump they have for removing oil through the filler slot. He restored oil level and gave me a lesson in reading the oil level. You live and learn.
June 8th, 2009, 07:59 PM | #11 |
So i drained the excess today. Took out another 200mL or so. Bike seems a bit better now.
Now i got a new quirk. Wouldn't call it a problem but the front of the bike seems to wobble ever so slightly when coming to a stop. Tire pressure is good.
Bad Oil Leak | thoughtquery | 1986 - 2007 Ninja 250R Tech Talk | 8 | August 5th, 2013 09:07 AM |
Oil overfill... bad? | Betlog | 2008 - 2012 Ninja 250R Tech Talk | 28 | July 4th, 2013 07:45 PM |
Oil change.. How bad is it? | tsdexter | 2008 - 2012 Ninja 250R Tech Talk | 14 | July 12th, 2012 09:04 AM |
Synthetic Oil: Bad? | jonthechron | 2008 - 2012 Ninja 250R Farkles | 25 | August 20th, 2010 05:59 PM |
Oil Change gone bad? | ricochet08 | 2008 - 2012 Ninja 250R Tech Talk | 9 | August 3rd, 2010 02:27 PM |
