June 7th, 2009, 08:41 PM | #1 |
Crafty Salesman....
Join Date: May 2009 Motorcycle(s): 09 250r, 06 sv650sf Posts: 170
Clean air gone! Question though.
So removing the clean air system took care of crackling at lower rpms while decelerating. I have a CA bike so there were quite a few tubes involved with the clean air system.
I also took the time to tap the 2 carb vacuum tubes for syncing when I need to. I have one question: from the dealer I got my bike and there was a loose hose, coming up from the middle of the heads, which seemed to fit over the fuel sending unit's outlet fairly well. Is it supposed to, or is the sender/tube supposed to be in open air? |
June 7th, 2009, 09:25 PM | #2 |
Hey, I'm in CA also.
Does this mod affect emissions at all? Cause you know...we got that smog thing for bikes coming in 2012. |
Air filter question | Joshua95 | 2008 - 2012 Ninja 250R Tech Talk | 4 | April 2nd, 2014 03:00 PM |
air filter question | gsxrninja250 | 2008 - 2012 Ninja 250R Tech Talk | 4 | September 4th, 2011 07:33 PM |
Kleen Air Question | crankinaway | 2008 - 2012 Ninja 250R Tech Talk | 8 | June 18th, 2010 09:32 AM |
The Ram air question | Rayme | 2008 - 2012 Ninja 250R Tech Talk | 13 | May 29th, 2010 05:56 PM |
What do you use to clean your air filter. | tjkamper | 2008 - 2012 Ninja 250R Tech Talk | 1 | July 12th, 2009 01:26 PM |
