June 8th, 2009, 05:22 PM | #1 | |
HID bulbs + Headlight modulator? Will it work?
Can I have a headlight modulator AND HID bulbs? Will the wiring interfere with each other? Can the bulbs handle the modulation, etc.... On one of my other threads someone said
-Dave |
June 8th, 2009, 06:07 PM | #2 |
Join Date: Dec 2008 Motorcycle(s): 08 Ninja 250R Posts: 52
well, the 250 doesn't have bilevel lights, it has a dedicated high and low beam (left light is low beam, right side high beam) so you dont have to worry about that. Also each bulb is a single filament bulb.
But I don't actually know about the HID setup with the modulator. It might interfere with the way the ballasts work, or the bulb itself.
'08 Ninja 250R: Yoshi Full System, HID's, FP Jet Kit, Snorkel removed, LED Brakelight, LED Footpeg Turnsignals, Zero Gravity SR Windscreen, Fender Eliminator, Solo Seat Cowl, Woodcraft Clip-Ons |
June 9th, 2009, 12:59 AM | #3 |
Join Date: Apr 2009 Motorcycle(s): 2009 Black Ninja 250R, 2004 Yellow Ninja 250R Posts: 111
i dont think a modulator would work with an HID system. As far as i know, each HID bulb needs a little time to warm up before coming to a full brightness. The modulation might interfere with it. And whenever an HID is initially started, it consumes a lot more current than when it is actually warmed up and been on for a while. I actually blown my headlight fuse twice when i forgot to turn off the high beam at start up.
June 9th, 2009, 05:44 AM | #4 |
Join Date: May 2009 Motorcycle(s): 09 Ninja 250R Special Ed Posts: 99
Having electricity fluctuate to HID = BAD!!! Flickering HID = BAD!!
I would not do it, HID do not work lilke regular bulbs, it will decrease the life of the bulb and kill the system prematurely. |
June 9th, 2009, 06:43 AM | #5 |
Join Date: Nov 2008 Motorcycle(s): 2008 WR250R, 2006 Ural Raven (Sold), 2009 Versys Green (Sold), 2008 Ninja 250R Green (Sold) Posts: A lot.
Yes and like hzrnbgy says they require some time to warm up so they would not be very noticable, and would probably not last very long.
June 9th, 2009, 07:19 PM | #6 |
hmmm interesting, No ID for me then :P modulator it is
-Dave |
HID and headlight modulator | ai4px | General Motorcycling Discussion | 1 | May 15th, 2012 01:49 PM |
How to install HI/Low HID bulbs into a pregen ninja | saber63 | 1986 - 2007 Ninja 250R Tech Talk | 25 | December 11th, 2011 02:16 AM |
Headlight Modulator | Ash | 1986 - 2007 Ninja 250R Farkles | 21 | May 13th, 2010 08:39 PM |
HID Lighting, Kits, Bulbs, etc. | g21-30 | Motorcycle-related | 7 | June 14th, 2009 05:06 PM |
