Old January 19th, 2018, 08:09 AM   #1
doubleJ
Motorcycle(s): 2008 Green Ninja 250
Alternative Way To Access The Battery?
Hello...
My 2008 250 was stolen, years ago.
It was recovered and, aside from some broken plastics, hasn't given me a lick of trouble.
They keyed out the ignition, but the tank was fine, so I just had the ignition replaced.
When I picked the bike up, from the shop, I saw that that rear seat tumbler was also keyed out.
I hadn't noticed it and the shop never mentioned it.
So, my battery is 10 years old and finally bit it (spent about 15 minutes trying to start it).
Unfortunately, I never installed terminal tails and I can't get the rear seat off.
Is there another way to get to the battery?
I could always break the plastics and seat, but that kind of defeats the purpose.
I want to replace the battery and get back to riding.
Hehehe...
JJ
doubleJ is offline   Reply With Quote
Old January 19th, 2018, 08:27 AM   #2
Motorcycle(s): '13 Ninja 300 (white, the fastest color!), '13 R1200RT, '14 CRF250L, '12 TT-R125LE, '15 CRF110F, '13 TT-R50E
I thought there was a way to pop the rear seat off if that key lock wasn't working, but it's escaping my memory at the moment. Hopefully somebody else here remembers.
Old January 19th, 2018, 08:29 AM   #3
Wait - battery access is under the front seat! Don't you just need to pop off those small panels on the side of the seat, and then unscrew the two bolts holding the seat on?
Old January 19th, 2018, 08:35 AM   #4
doubleJ
Don't you have to remove to rear to open the front?
JJ
Old January 19th, 2018, 08:36 AM   #5
You'll need to get the rear seat off at some point for something, but shouldn't be needed for this.
Old January 19th, 2018, 08:36 AM   #6
JJ
No. See attached pics.
Old January 19th, 2018, 08:37 AM   #7
doubleJ
Well, this is why I asked.
Hehehe...
JJ
Old January 19th, 2018, 08:55 AM   #8
Some threads for the rear seat problem.
https://www.ninjette.org/forums/showthread.php?p=740088
https://www.ninjette.org/forums/showthread.php?t=189239
Old January 21st, 2018, 04:11 PM   #9
doubleJ
I took the side plastics off and unbolted the front seat, but it seems like it is attached at the rear of the seat.
I'm not sure how it is attached, but I was not able to disconnect it.
Any ideas?
JJ
Old January 21st, 2018, 06:15 PM   #10
Unbolt both sides?
Then lift rear and slide to back.
Old January 21st, 2018, 06:24 PM   #11
doubleJ
Originally Posted by JacRyann View Post
Unbolt both sides?
I guess I'm not sure what you're referring to.
The rear is what I can't lift.
It seems like it is still attached.
I removed a bolt from both sides.
JJ
Old January 21st, 2018, 06:28 PM   #12
Hmm, ok, no lifting rear then. Grab both front corners and pull towards back.
Or grab opposite diagonal corners and wiggle/rotate as you pull towards back?
Old January 22nd, 2018, 12:39 PM   #13
Lazarus
Lazarus's Avatar
Motorcycle(s): 2008 Ninja 250
The front seat has two plastic "pegs" at the rear underside of the seat. Once the seat is unbolted from the sides it needs a firm tug/wiggle towards the rear of the bike and it should pop out. Tug firmly in a linear motion then wiggle/lift up on the front seat. Should pop right out.
Lazarus is offline   Reply With Quote
Old January 24th, 2018, 07:53 AM   #14
doubleJ
That did it.
I thought the bolts were all that were holding it in place.
I didn't realize you had to move it backwards.
Thanks...
JJ
[motorcyclistonline] - An "Alternative" Alternative Take on Our 2015 Motorcycle of th Ninjette Newsbot Motorcycling News 0 December 3rd, 2015 01:11 PM
FS: Battery Tender 021-0128 Battery Tender Plus 12V Battery Charger (Automotive) tagg Amazon Postbot Amazon - Popular Motorcycling Items 0 April 23rd, 2013 04:52 PM
FS: Battery Tender 021-0123 Battery Tender Junior 12V Battery Charger (Automotive) ta Amazon Postbot Amazon - Popular Motorcycling Items 0 April 23rd, 2013 04:52 PM
Battery Lead Access? Samer 2008 - 2012 Ninja 250R Tech Talk 3 April 3rd, 2010 02:04 PM
