Old May 16th, 2011, 12:21 PM   #1
muzkur
muzkur's Avatar
Motorcycle(s): 10' Ninja 250R
Universal Turn signals flush mount
Hi there!
I bought a universal turn signals for kawasakis but dont fit in 250r:
http://shop.the2wheels.com/Flush-Mou...s-010-2-x2.htm
Now I'm wondering try another model:
http://shop.the2wheels.com/Universal...s-GP005-x2.htm
Anyone use that turn lights? They fit in 250r? Need some fixes?
I think that's the same model:
Thanks for all
Last futzed with by muzkur; May 16th, 2011 at 12:32 PM. Reason: Add picture
muzkur is offline   Reply With Quote
Old May 17th, 2011, 07:52 AM   #2
CThunder-blue
ModMy250.com
CThunder-blue's Avatar
It does require to extra modification to fit. Check this thread out:
http://www.ninjette.org/forums/showthread.php?t=73710
The www.ModMy250.com guy
Old May 17th, 2011, 09:09 AM   #3
DarC
DUCEATR
DarC's Avatar
Motorcycle(s): RVT1000R
I have these on the 08 and there are two options to mount them.
1) Use 3M mounting tape and apply to the light to stick to bezel(black trim), and then between the bezel and your bodywork. This is how I initially mounted them up. You can't even tell they are "taped" on.
2) The proper fix is to use either a taped and threaded plastic tube or use some all thread and a tube nut to extend the threaded portion on the back so you can mount these using the supplied plastic nut/washer.
Easy fix with a trip to the hardware store. I alread had an electronic flasher relay so this was a very fast and great looking mod.
DarC is offline   Reply With Quote
Old May 17th, 2011, 09:59 AM   #4
muzkur
muzkur's Avatar
Thanks for the help.
That 2nd way's was what I planned.
Maybe I can buy some plastic tube nuts to use like extensors. Or I can rip out the original nut and fix a new one.
Anyway, that turn lights model are better to use. The first model I bought dont fit in the original hole but isn't larger enough to cover the hole.
flush-mount turn signals? SafetyPaws 2008 - 2012 Ninja 250R Farkles 21 July 15th, 2013 05:05 PM
Flush mount turn signals jagerbomb00 2008 - 2012 Ninja 250R Farkles 5 July 15th, 2013 08:35 AM
Flush Mount Turn Signals Gunner Motorcycle-related 1 May 12th, 2013 08:47 AM
Flush Mount Turn Signals VANtaged 1986 - 2007 Ninja 250R Farkles 7 September 20th, 2010 07:26 AM
flush mount turn signals fiberoptx 1986 - 2007 Ninja 250R Farkles 6 October 17th, 2009 06:45 PM
