August 27th, 2014, 08:15 AM | #1 |
Dunlop Roadsmart 2 (Or other SPORT TOURING tires)
Has anyone used these on their machine? I've purchased a 4.5 inch wheel, and do not want a full out supersport tire. So I've decided to check out some sport touring options.
Sizes I'm looking at: Front: 120/70/17 OR 120/60/17 (On this end, I would not mind a tire that is stock size) Rear: 160/70/17 Any other recommendations are welcome.
Paint side up, rubber side down! |
August 27th, 2014, 11:50 AM | #2 |
A 160/70 is going to be decently taller than stock. A 130/70 should have a sidewall height of 91mm. A 150/60 is 90mm. The 160/70 is 112mm, which is going to be over 1-5/8" taller in total diameter. A 160/60 is closer, at 96mm (not quite 1/2" taller total).
The change will have some effect on the geometry of the bike, as well as just making sure it fits in the available space. Wider and taller means that you're starting off closer to the swingarm sides, plus moving up toward the frame where it gets narrower. I can't give you any details on exactly what will or won't fit, or preferred tires. I put a Michelin Pilot Power 150/60 on mine, and so far am happy with it after about 1,500 miles.
*** Unregistered, I'm not your mom and I'm not paying for your parts, so do whatever you want with your own bike. *** Last futzed with by InvisiBill; August 27th, 2014 at 01:59 PM. Reason: I math bad. |
August 27th, 2014, 12:10 PM | #3 |
I think this thread is relevant:
https://www.ninjette.org/forums/show...t=rojoracing53 Michelin Pilot Street Radial. Looks like really good mileage and wear out of a sport touring type tire designed for bikes like the ninjette and baby cibber in mind. Also remember, it's a good idea to run a harder compound tire in back and a sticky compound tire in front. These bikes like a sticky front tire because they don't unweight the front as much when you roll on and load the rear. From the mileage jason and others have gotten, you might actually wear out a Pilot Street radial and a super sticky front at the same rate instead of the usual 2 rears for every 1 front. Jason is a very experienced rider and is generally very sensitive to things like tires and suspension setup. If the hard rear/soft front combo works for him and he's able to explain his logic, it's good enough for me to use with confidence. |
August 27th, 2014, 04:33 PM | #4 | |
August 27th, 2014, 04:34 PM | #5 | |
[superbikeplanet.com] - (Last Day To Enter) Win Tires! Soup's Dunlop Roadsmart "Road | Ninjette Newsbot | Motorcycling News | 0 | May 11th, 2012 12:30 PM |
[motorcyclistonline] - Dunlop Roadsmart II Tires | MC Tested | Ninjette Newsbot | Motorcycling News | 0 | March 20th, 2012 03:50 AM |
[topix.net] - Dunlop Roadsmart Sport-Touring Tires | Ninjette Newsbot | Motorcycling News | 0 | April 13th, 2011 03:00 AM |
[sportrider - latest stories] - SR Tested: Dunlop Sportmax Roadsmart Tires | Ninjette Newsbot | Motorcycling News | 0 | June 22nd, 2010 04:10 PM |
[webbikeworld.com] - Dunlop Roadsmart Tires Now Approved for the BMW R 1200 RT-P Poli | Ninjette Newsbot | Motorcycling News | 0 | June 12th, 2009 08:20 AM |
