August 27th, 2014, 11:38 PM | #1 |
Join Date: Aug 2014 Motorcycle(s): 2009 Ninja 250R Posts: 2
Full exhaust and intake suggestions
Ex-Racer looking for some Experienced Racers/Tuners suggestions and opinions on a full exhaust system for a 2009 ninja 250 that are currently working for them.
I'm looking at a Full Systems from: Yoshimura Two-Bros Akrapovic Leovinci Or something that is working better? Airbox mods or elimination? K&N air filter or something else? Jet kits or jetting recommendations? Looking for more power while still keeping reliability. Will be used 75% street & 25% track days. Thanks for the help in advance! |
August 28th, 2014, 05:48 AM | #2 |
modaholic junkie
Join Date: Sep 2012 Motorcycle(s): 2001 ZX-12R, 2009 ninja 345cc and plenty of others in the past... Posts: 438
well of those you mentioned I think the one you definetely don't want to use is the Two-bros...
performance-wise the LeoVince is the reference point but people in the States with carburated models prefer AreaP's systems, not only because they are reviewed to perform well but also because their aftersales customer service is flawless... they provide you with rejetting instructions and suggestions etc... track guys remove box and use pods if it is not against certain class regulations, KN mostly either pods or filter... our track guys will give you more specified info (there are threads on rejetting and tuning based on choice of exhaust system and operating altitudes) since I am on the other side of the Atlantic...
If noone has tried it before, I will !!! |
August 28th, 2014, 07:04 AM | #3 |
dirty boy
MOTM - Apr '14
do some searches, do lots of reading and in the end do what ever it is that you want.
the difference is performance between most of the setups will be barely noticeable but other aspects of the setups will be such as, price, sound, looks, other quirks removing kleen air and common and generally recommended, (check your laws) the air box on the other hand, debatable, pro's and con's to each, read up, formulate your own opinions and make your own decision. Jetting, will need to be done, that is all, bikes are different, people live/ride in different areas with different setups, they all will require different jetting. However, check out the jetting database in the "DIY" sticky at the top of the new gen tech section for some guidance on where to start.
August 28th, 2014, 12:55 PM | #4 |
Join Date: Apr 2012 Motorcycle(s): '12 ninja 250r Posts: 762
Area P is a favorite here
August 28th, 2014, 05:27 PM | #5 |
Blind 250 Loving Whore
Area P
'Merica |
August 29th, 2014, 12:03 AM | #6 |
Input thanks
Thanks gentleman, I appreciate your input. I'll start doing research on the forum here. Raced most of the CBR's and the early R6's for about 13 yrs. so these 250's are real new to me. Trying to get a base setup for the wife's mostly street, but some track endeavors. Thanks again!
August 29th, 2014, 12:13 AM | #7 |
Freedom for Germany
@storm720, if you'd use it 25% street and 75% race, also looking for highest power output the best choice would be this https://www.ninjette.org/forums/showthread.php?t=66733
August 29th, 2014, 05:48 AM | #8 | |
dirty boy
MOTM - Apr '14
Like I said before, performance wise, I can't see you noticing a difference. If you are racing where fractions of seconds matter... sure but I still can't imagine your extra 1hp is gonna give you much of an edge in the 250 class where I imagine your riding is more the determining factor. Go with what you want but put lots of consideration into the way it sounds and looks because that is what you will notice the most JMO
August 30th, 2014, 12:46 PM | #9 |
Join Date: Mar 2014 Motorcycle(s): Currently own: 98 Honda VTR1000, 02 Suzuki's DR200 & DR650, 04 & 08 BUSA's, 05 Ducati SS1000, 12 Ninja 250R SE Posts: 59
I have the Yoshimura TRC full system with CF canister (restrictive sound reduction insert installed - a lot easier on the ears) -
Exhaust/Intake Upgrade Ideas | a.kozak | 1986 - 2007 Ninja 250R Tech Talk | 9 | March 1st, 2013 10:57 PM |
Top Exhaust + Intake + Jet option | 675Raisinator | Ninjettes At Speed | 6 | December 17th, 2011 05:07 PM |
[motorcyclistonline] - Cobra Engineering Introduces Exhaust and Air Intake Systems Fo | Ninjette Newsbot | Motorcycling News | 0 | June 11th, 2010 08:51 PM |
Exhaust Suggestions | tlhamon | 2008 - 2012 Ninja 250R Tech Talk | 6 | May 10th, 2009 10:09 PM |
Which came first...the intake or the exhaust? | M-Oorb | 2008 - 2012 Ninja 250R Tech Talk | 1 | December 5th, 2008 01:41 PM |
