Old September 1st, 2014, 05:32 PM   #1
scorch
scorch's Avatar
Motorcycle(s): 250
blinkers work sometimes
Lately i have been havingt this problem. Sometimes the blinkers work,a nd sometimes not. I checked the relay and it looks fine.. As far as i can tell.
On a ride, it might not work for 20 miles, then the next it will work.
I thought it might have been the vibration causing the relay or something to malfunction.
Anyone know what might be the cause.
scorch is offline   Reply With Quote
Old September 1st, 2014, 05:34 PM   #2
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Check the connection, sounds like they are either loose or you have a bad wire or ground.
Old September 2nd, 2014, 02:24 AM   #3
Linkin
Down Under
Linkin's Avatar
Motorcycle(s): Kawasaki ZXR250C Ninja
Is it just one side at all? Or both?
In any case, take all four apart and check the contacts/wiring
Linkin is offline   Reply With Quote
Old September 2nd, 2014, 06:07 AM   #4
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
stock signals and relay?
Old September 2nd, 2014, 06:25 AM   #5
scorch
scorch's Avatar
Motorcycle(s): 250
it is stock signals and stock relay. If the signals go out, they go out for all of them. Even the blinking signals in the dash disappears.
Old September 2nd, 2014, 09:04 AM   #6
snot
sammich maker
snot's Avatar
MOTM - Apr '15
I am thinking ground wire, could be a bad switch too.
Old September 2nd, 2014, 12:17 PM   #7
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
is this your bike with like 80k miles on it? I would try just replacing the blinker relay to start with before I started checking all the wiring.
Old September 2nd, 2014, 07:27 PM   #8
Asspire
Fix It Till Ya Break It
Asspire's Avatar
Motorcycle(s): 08 250RRrrrr
change the bulb?
cheap, and quick. flick the bulb and see if the filament is loose
Asspire is offline   Reply With Quote
Old September 3rd, 2014, 04:15 AM   #9
scorch
scorch's Avatar
Motorcycle(s): 250
The bulbs are good, its a weird wiring problem.
But can't find it, i looked at all the wires and they appear good. But i need to take a bit more time to look through it.
New Blinkers kennetht 2008 - 2012 Ninja 250R Tech Talk 24 February 1st, 2014 12:14 PM
Electric start problem, lights, blinkers, and indicator lights work. claymaker 1986 - 2007 Ninja 250R Tech Talk 8 July 10th, 2012 07:04 PM
Blinkers won't work? PLEASE HELP Snowman78666 General Motorcycling Discussion 2 November 9th, 2011 04:04 PM
blinkers don't work Domagoj 2008 - 2012 Ninja 250R Tech Talk 11 January 8th, 2011 12:03 AM
making an integrated tailight and flush blinkers work...I searched Mac 2008 - 2012 Ninja 250R Farkles 2 August 30th, 2010 04:29 PM
