January 27th, 2013, 02:11 PM | #1 |
Join Date: Apr 2012 Motorcycle(s): 2011 black Ninja 250r Posts: 114
Exhaust help needed
Well I have finally decided to go with a full exhaust but its between jardine rt-5 and leo vince gp corsa full but I am having a hard time finding reviews for a gp full is there anyone that has a full gp set up?
January 27th, 2013, 02:33 PM | #2 |
Jigglin' your Jiglets
MOTM - Apr '13
For track only right?
January 27th, 2013, 04:55 PM | #3 |
This would be mostly for street use I am replacing my exhaust after damage done from a slide
January 27th, 2013, 05:07 PM | #4 |
FYI: The Jardine can be found for a decent price here: http://stores.sportbiketrackgear.com...l.bok?no=14736
January 27th, 2013, 05:40 PM | #5 |
Thanks for the info I find that the Jardine is cheaper then the Leo but I am hearing that the quality and performace is better with the leo I am torn between the two right now.
January 27th, 2013, 05:45 PM | #6 |
If you're looking at quality, also consider Area P. They have very high quality products and fantastic customer service. I was quite impressed when I saw an Area P quiet core exhaust system on a 250R for the first time.
http://areapnolimits.com/products/Sl...-250R-2008.php |
January 27th, 2013, 05:57 PM | #7 |
I like the area p just as much as the leo but I am finding that the jardine to be a lot cheaper for a full system where I can use the saved money towards other parts.
January 27th, 2013, 08:15 PM | #8 |
MOTM - Apr '13
Like military spec earplugs and hearing aids!
January 27th, 2013, 08:20 PM | #9 |
Fast-Guy wannabe
MOTM - Jan '13
January 27th, 2013, 08:30 PM | #10 |
Join Date: Nov 2012 Motorcycle(s): 2012 Ninja 250(Totaled) Posts: 984
Since you're buying a full exhaust system, which no matter who makes it, is a decent chunk of money, wouldn't it make sense to spend the extra bit to get the extra quality? I know any time I drop more than 50 dollars on a product, I'm going to buy the one with the best quality. If that means I'm spending an extra 200 bucks, than so be it. Because I don't have a disposable income. I can't afford to spend a few hundred on something, only to have it break. Because then I have to buy another, which now equals the cost of the better one anyway.
"I am a creationist, I believe man created god." |
January 28th, 2013, 08:08 AM | #11 |
I agree Im not spending 20 bucks here and I would like to spend more for quality but I am on a budget and the main reason I am changing my exhaust is due to an accident I had when a car cut me off causing me to slide while avoiding him and then my exhaust took most of the damage. I also have other parts to fix on my right side so im trying to spread the moneyaround I have to fix it all by spring.
January 28th, 2013, 10:42 AM | #12 |
Join Date: Nov 2011 Motorcycle(s): Ninja 250r Posts: 152
yoshimura full carbon!! you go
btw. you gonna get a Powercommander, or just leave it on? |
January 28th, 2013, 10:55 AM | #13 |
Yoshi is nice. After I install the full system i will rejet and go with a K&N filter.
January 28th, 2013, 07:26 PM | #14 |
Yoshi's are much too loud and over rated imho.
January 28th, 2013, 07:36 PM | #15 | |
Nerd
Join Date: Mar 2012 Motorcycle(s): Ducati Hyperstrada Posts: 672
It doesn't LOOK that steep. But you can go first... |
January 29th, 2013, 10:19 AM | #16 |
I was thinking at first of just going back with stock to save money but found that the cost was a little less but almost close to the same as buying a new aftermarket exhaust slip on. The Leo vince gp corsa slip is the cheapest That I found and the weight is lighter then stock. Although my first thought was a slip on only I thought to stretch my budget a bit with a full system as there would be more to gain out of it.
January 29th, 2013, 10:19 AM | #17 |
MOTM - Apr '13
You can find a stock slip on for $50
January 29th, 2013, 10:46 AM | #18 |
I have kept an eye out on here but shipping always bumped it up. Have also been checking CL & Kijiji and always around the $100 and up mark but also not in the best shape either for what there asking. I checked some shops and scrap yards in the area but nothing really great. There was a motorcycle supershow in early Jan that I went to with a bunch of vendors to compare prices but not to many deals for the 250. While I was hitting up the local area vendors the best deals I got so far on the low end $$$ was a LV gp corsa aluminum slip at $169 and $320 for a Jardine aluminum rt-5 full exhaust.
FS: Area-P solo exhaust bracket for Ninja 300 w/stock exhaust | c-dog | Motorcycle-related | 2 | September 12th, 2014 10:48 AM |
How to remove stock exhaust and install aftermarket Slip-On Exhaust System Ninja 300 | SON1C | 2013 - 2017 Ninja 300 Tech Talk | 4 | August 14th, 2014 05:45 PM |
Exhaust hanger needed? | Little_Ghost | 2008 - 2012 Ninja 250R Farkles | 22 | February 11th, 2012 08:35 PM |
Full Exhaust for 2007 EX250F needed | buckwestern | Items Wanted | 0 | October 24th, 2011 12:20 PM |
Full exhaust system and rejet advice needed. | wild-bill | 2008 - 2012 Ninja 250R Tech Talk | 5 | December 14th, 2010 11:34 PM |
