January 29th, 2013, 06:18 PM | #1 |
Join Date: Apr 2012 Motorcycle(s): 09 Ninja 250R (Crashed/Unexistent) / 11 Ninja ZX6R Posts: 83
Lost Throttle Response
I need help here, I was riding my bike a few days ago, I had been riding for about 70 miles, I was going up-hill at about 80MPH and suddenly my speed started to decrease. I did let go of the throttle and rolled it again and no response, I did this about twice and held the throttle rolled. Once the speed reached about 30MPH the speed started to increase and I was on my way. I should not let out that I was getting close to an empty tank so I exited the highway a few miles down and filled-up. I did not have the same problem the rest of the day, but I have not used the bike since then.
Is it possible this happened because I was running out of fuel and going up-hill? Has anyone come across this problem before? I know little to nothing about motorcylces... |
January 29th, 2013, 06:25 PM | #2 |
Quite possible yes. Could also be a tank venting issue. If so, you cured it by opening the gas cap. Do a quick search of this forum for "venting". Maybe you will find similar issues.
First time it's ever happened? Any recent changes to the bike? I wouldn't worry about it to much unless it happens again.
January 29th, 2013, 06:32 PM | #3 |
first time this happens in the time I've had the bike which is about 9 months, and no changes, still stock.
thanks for the feedback, I'll look into the tank venting issue |
January 29th, 2013, 07:47 PM | #4 | |
The fuel system is a gravity feed system. It requires the weight if the fuel itself to feed the carbs. It is also possible for the the bike to slow down while riding on a flat surface if the fuel is too low. The carbs tend not to fill up as fast. I had it happen before. Any amount of throttle more than 1/4 resulted in a non response. The jet needles tend to start moving at this point and the carbs draw more gas. Low gas, go slow. Last futzed with by DaBlue1; January 30th, 2013 at 12:15 PM. |
January 30th, 2013, 11:42 AM | #5 |
thanks Blue
Full throttle kills bike, throttle lag response. | Diegone | 2008 - 2012 Ninja 250R Tech Talk | 10 | April 30th, 2014 03:25 AM |
throttle response | kslane | 1986 - 2007 Ninja 250R Tech Talk | 1 | August 5th, 2013 07:58 PM |
my ninja stopped grabbing first gear or lost throttle response i think? | jon.b.calderon | 2008 - 2012 Ninja 250R Tech Talk | 8 | March 16th, 2012 10:54 AM |
Roll on the throttle and no response? | RiderOnTheStorm | General Motorcycling Discussion | 5 | January 21st, 2012 09:05 PM |
