Notices
Old January 30th, 2013, 01:33 PM   #1
indr
Camshaft Chain Inspection
Is there such a thing? Looked in the manual. Can't find anything regarding it.
FYI, have the engine ripped open so thoughts I'd check the chain and see if it needs replacement. Don't know what I'm supposed to be checking for though.
indr is offline   Reply With Quote
Old January 30th, 2013, 02:26 PM   #2
measure 20 links. since you cant get 20 links of the chain perfectly straight with the cams in place, you should be able to measure 10 and extrapolate out, but make sure you measure different sections of the chain as parts may be unevenly stretched.
Old January 30th, 2013, 03:23 PM   #3
indr
The chain is already out. So, I'm just measuring at different points on the chain to make sure they're all around the same or am I looking for a max stretch after which the chain would be unusable?
Old January 30th, 2013, 04:01 PM   #4
if its good, it will be within the service limit at any point that you measure it at. measurements should be consistent. if its inconsistent or over the service limit just get rid of it. you should be measuring from the center of the rivet of the chain. each rivet is one link. so measure the length of 20 rivets.
20 Link length
Standard: 127-127.4mm
Service Limit: 128.9mm
Old January 31st, 2013, 03:52 PM   #5
indr
20 Link length
What page is that info from?
Old January 31st, 2013, 04:11 PM   #6
its in the repair manual not the owners manual
Old February 1st, 2013, 01:14 PM   #7
indr
I have both. Can't find it.
Old February 1st, 2013, 01:40 PM   #8
it is in the section about timing and the cams
Old February 1st, 2013, 01:46 PM   #9
indr
Can't find it. Stop pulling numbers out of your ass.
Old February 1st, 2013, 01:48 PM   #10
i'm not, but now that you are so happy that someone has helped you i'll be unsubscribing from this thread.
Old February 1st, 2013, 02:25 PM   #11
indr
lol
Old February 1st, 2013, 05:27 PM   #12
@alex.s
Clymer says Kawi doesn't specify it either, remember?
Old February 1st, 2013, 05:31 PM   #13
please read my user message below my user name.
Old February 1st, 2013, 05:32 PM   #14
You're right: You're right.
Old February 1st, 2013, 05:33 PM   #15
it just so happens that i had a brand new cam chain recently. from a parts house. its an oem kawi chain with kawi branding on the packaging. it measured correctly according to the specs above. i also have an out of limits chain that was clacking like crazy it correctly measured outside of service limit. but if you don't like the numbers i copy/pasted, thats cool.
Old February 1st, 2013, 05:40 PM   #16
Oh, we like them. To quote the all-knowing sage known as @Motofool:
Originally Posted by Motofool View Post
Similar chain should have similar specification for wear limit.
Old February 2nd, 2013, 12:48 PM   #17
Originally Posted by CZroe View Post
........To quote the all-knowing sage known as @Motofool:
Where did you find that statement of mine?
http://en.wikipedia.org/wiki/Sage_%28Sophos%29
It is true, all these chains and sprockets follow standards that have been around since the beginning of the last century and, since they have work flawlessly, have not changed since then.
http://en.wikipedia.org/wiki/Roller_...hain_standards
Each link of a chain is a flat bearing with little angular movement, cyclic load and marginal lubrication, all of which is very bad for a long life.
Under those conditions, stiction and metal to metal contacts are frequent, which lead to progressive wear and increasing clearance between the journal and shaft.
Why is that clearance critical?
Full-film conditions of lubrication are when the bearing's load is carried solely by a film of fluid lubricant and there is no contact between the two bearing surfaces.
There is a narrow range of clearance that can keep that ideal condition of lubrication in a flat bearing.
What the elongation of the chain tells us?
It tells us how much that clearance has grown for each bearing connecting two links.
What we measure is an amplification of that via the addition of the clearance's increment of several links under some longitudinal load.
What happens when the measured elongation exceeds the maximum allowed by the specifications (0.1 mm for each bearing)?
The two secondary consequences are:
-A little retardation of the valve timing respect to the angular position of the crankshaft and
-The altered chain's pitch damages the sprockets, changing the shape of the teeth, which will induce over-load and damage in a new chain after replacement.
The more dangerous consequence is a deterioration of the lubrication of each bearing. Initially, load is carried partly by direct surface contact and partly by a film forming between the two; and for extreme increment of the clearance, the full load is carried by surface-to-surface contact. Each shaft starts being loaded with progressive bending loads.
All that deterioration process ends up in the catastrophic failure of one or more of the shafts-journals, with the consequent lock down or destruction of the engine.
Read more about flat bearings here:
http://en.wikipedia.org/wiki/Plain_bearing#Lubrication
Measuring the chain between edges of the rivet is more precise that guessing the center of the rivets.
Old February 2nd, 2013, 08:09 PM   #18
Old February 2nd, 2013, 08:29 PM   #19
tubarney
I thought the reason they started using chains instead of belts is so you don''t have to replace them.
Camshaft Chain Tensioner gxmcdg 2008 - 2012 Ninja 250R Tech Talk 16 October 27th, 2014 07:55 PM
Camshaft Issue jpatt87 2008 - 2012 Ninja 250R Tech Talk 42 March 25th, 2014 02:49 PM
Camshaft chain removal ElJokerr 1986 - 2007 Ninja 250R Tech Talk 16 October 24th, 2013 06:13 PM
Camshaft Chain tensioner mounting bolts cerberusrex25 1986 - 2007 Ninja 250R Tech Talk 7 June 19th, 2011 10:03 AM
