January 30th, 2013, 10:38 PM | #1 |
Testing for fork straightness?
I recently bought two sets of bent forks and will be getting all four tubes straightened. While I'm at it, I might as well check my other sets to see if they need straightening. The thing is, I don't have the best eyes for eyeballing these things. Short of removing them from the bikes and holding them up to each other, what else can I do?
January 30th, 2013, 10:45 PM | #2 |
A small straight edge but that's even tough with everything in the way.
January 30th, 2013, 10:54 PM | #3 |
Any machine shop can verify that for you.
If they freely roll on a flat surface, they are straight. If the bent is too severe, the section of the tube will become oval, which cannot be fixed by straighten them up. That deformation could lead to seal leak.
January 31st, 2013, 12:10 AM | #4 | |
I keep hearing that but my experience these last two days says otherwise. Two disassembled forks in my trunk, 8 shops, and many gallons of water in my trunk later (did you see what the weather was like in the southeast today?!) and I've found that they usually aren't even willing to talk to you. I must've heard "We don't do anything like that" more times than I can count today. One shop even tried to blow me off by saying that they were only set up for automotive applications, as if motorcycles weren't automotive! Yeah, but the problem is that I don't want to take apart forks for curiosity's sake! It just so happens that the ones I want to know about were rebuilt a year ago (bad seals) and never used since so it would be a horrible waste. I hit a curb with them and didn't go down so it didn't occur to me that they might be bent when I still had them apart. Now I hear that curb encounters often result in bent forks, so I want to check without taking them apart. Yep. Already understood. Thanks. |
January 31st, 2013, 12:20 AM | #5 |
Another thing you can do too, is drop the forks and get a piece of glass from the hardware store and lay it on top of the forks.
January 31st, 2013, 07:13 PM | #6 | |
If they were so pathetic, it was better that they didn't attempt doing the work. If bent, the kink should be located somewhere above the seal of the fork, since the suspension should have had some sag due to the weight on the front end at the time of impact. What do you have that could be used to measure any bent? Pipes, tape measure, ruler? We could engineer a simple gauge with what you have.
DIY- Replace fork seals, dust seals and fork oil | shortstuff | 2008 - 2012 Ninja 250R Tech Talk | 212 | November 6th, 2023 10:53 AM |
FS: Pregen : Fork Springs, Fork Clamp, Factory Pro Jet kit | FvnnyL3tt3r1ng | Motorcycle-related | 20 | February 24th, 2016 08:24 AM |
[roadracingworld.com] - Testing Before Testing For Pata Honda World Superbike Riders | Ninjette Newsbot | Motorcycling News | 0 | January 14th, 2015 11:10 AM |
Can fork springs be changed without removing the fork tubes? | AlanDog | 1986 - 2007 Ninja 250R Tech Talk | 26 | April 23rd, 2014 05:19 AM |
[kropotkin thinks...] - Bridgestone Testing 2010 Tires Because Of 2009 Testing Restri | Ninjette Newsbot | Motorcycling News | 0 | March 4th, 2009 10:50 AM |
