Old February 4th, 2013, 04:41 AM   #1
novak2k9
Motorcycle(s): 2008 250r
Installing 15t Vortex front sprocket on 08 250r, require shimming and how?
Have a 15t Vortex sprocket on way..
http://www.solomotoparts.com/Vortex-...r-EX250-08-10/
Now do I have to shim this?
How do I go about doing that because doing a google/youtube search for "shim sprockets" isn't showing much. Is shimming just a washer slipped on shaft between motor and sprocket?
I should have just got a JT as I read it's a simple swap but too late.
Thanks
novak2k9 is offline   Reply With Quote
Old February 4th, 2013, 04:53 AM   #2
Graugaard
Graugaard's Avatar
Motorcycle(s): Ninja 250r
i got the old sprocket from JT 15t for the 2007> model for my 2008< model. It's 0,8mm shorter so i bought another shaft locking washer (the one you take off from the 14T sprocket), and added between my JT sprocket... works fine...
dunno if vortex has same size
Graugaard is offline   Reply With Quote
Old February 4th, 2013, 05:01 AM   #3
novak2k9
ok so just another added washer between the sprocket and motor to align everything.. thanks. All the searching I've done I haven't seen anything with pics of spacers added or if people that installed vortex 15s had to modify anything.
Won't know what the size is until the sprocket arrives. thanks
Old February 4th, 2013, 09:46 AM   #4
The thing is, you don't even have to do it on the JT sprocket because it's not off by that much.
That said, I don't think Vortex made sprockets for the older model so it probably only fits your bike.
Old February 4th, 2013, 10:28 AM   #5
cuong-nutz
cuong-nutz's Avatar
The difference between the pre 08 and the post 08 thickness is 0.8mm. Really not much of a difference. I bought the pregen one by accident and still plan on using it.
HalfFast Racing Team
Old February 4th, 2013, 10:40 AM   #6
The shaft locking washer is bowl-shapes. Are you sure that's the one you bought? There's another washe that I recall people buying to shim it.
Old February 4th, 2013, 11:05 AM   #7
mgentz
Board Member
I got a Renthal on my 09. no shimming needed.
Old February 4th, 2013, 11:47 AM   #8
Graugaard
Graugaard's Avatar
http://www.partzilla.com/parts/searc...ION/parts.html
92200 part number : 92200-0506 was the one i meant
15t front sprocket loose Lewis3845 1986 - 2007 Ninja 250R Tech Talk 2 March 10th, 2014 02:07 PM
Suggestions for a 15T front sprocket? tsdexter 2008 - 2012 Ninja 250R Tech Talk 7 June 21st, 2013 03:31 PM
15t front sprocket swap! play2pwn 2008 - 2012 Ninja 250R Tech Talk 3 October 17th, 2011 09:17 AM
15t jt front sprocket and now noise? greatwhiteninja 2008 - 2012 Ninja 250R Tech Talk 25 August 30th, 2011 08:34 PM
15T Front sprocket is greeaaatt! Hokie11 2008 - 2012 Ninja 250R Tech Talk 16 September 1st, 2009 03:47 PM
