August 20th, 2014, 07:05 PM | #1 |
ran when parked
Join Date: Aug 2013 Motorcycle(s): Freeride 250R, KLX250SF, mopeds Posts: A lot.
MOTM - Sep '17, Dec '14
Can you crank a bike without carbs in it?
I'm thinking about picking up a blue 2009 Ninja 250 with unknown number of miles on it. Probably low. It's advertised on C-list for $700, the catch being it was lowsided and trashed the fairing, and then it sat because the owner was afraid to ride it, and the carbs were taken out of the bike to be cleaned but not put back in. The guy says he's moving or something and wants to just get rid of it as he's done riding. Clean title, battery is still good, I'm waiting to hear the other nonsense... I'm in a good position to buy a project bike, esp for this price (I work at a shop and have access to all the tools/equipment I need for anything).
The owner said that his friend took the carburetors out to clean them after the bike had been sitting for awhile, but was deployed overseas and the owner does not have the knowledge or fundage to have the carbs thrown back in (I just did it today and it SUUUUUCKS) My question is, what happens if you try and crank a bike that doesn't have carburetors in it? What can I do as far as ensuring the highest possibility that the engine is still good other than look at the mileage and judge by the condition of the rest of the bike? I'm not going to sit there and put the carbs back in unless he pays me for my time The major things I'll be looking for are: -Fork seals leaking -Carburetor parts all still there (who knows, when someone says their buddy cleaned them...) -Tire condition -Chain and sprockets -Evidence of a major wreck (bent rearsets, rims, handlebars) -Any rust in the gas tank -Presence/condition of engine oil/coolant/brake fluid -Frame damage -Condition of hoses/other rubber parts And obviously, does it stop and turn and go straight smoothly when being pushed. Things like electrical, cosmetic, minor things bent/broken don't bother me. Is there any other major stuff I should be looking for specifically from a bike that has been sitting for 2-odd years? Basically I don't want to put everything back together and realize that there's something F'ed up in the engine. I'm looking for a project bike, but I don't want to spend more than about $500 on the bike and $300-400 in parts. I realize that's super low, but again, I can do all of the actual work myself including tires, carbs, fork seals, and only expect to pay for parts that are damaged or have been sitting too long to be usable. Cheers! |
August 20th, 2014, 07:08 PM | #2 |
Que Buenos Son!!!
MOTM - Nov '14
Well, you could do a compression test. Don't need carbs for that, and no damage will be done if you turn the engine over manually.
August 20th, 2014, 07:19 PM | #3 |
A compression test is a good start. Check the oil too. Carbs are not needed to crank the motor.
August 22nd, 2014, 12:17 PM | #4 |
Inline 4!!!
Hell, go there with $400-500 cash and tell him you will lug it away for that price. He will take it. I promise you he will. He just wants it gone and the $500 will probably help him buy something else he wants like an xbox or airplane ticket, etc.
for $500, you can't go wrong. The seat alone is worth about $60 in good condition, along with the headlight, mirrors, rims, etc. etc. It will easily add up to $500 and you can have a little fun monkeying around with it. Make sure to post pics up of your progress, I like to follow those threads.
August 22nd, 2014, 12:47 PM | #5 |
well, if you crank it, I'd bet a pretty penny that it won't start.
talk him down to $500 if possible. No running and needs work? That's about the most I'd pay. Good luck! I hope this bike is a diamond in the rough for you!!! I've debated doing a project bike myself but I already have too many motorcycle and bicycle parts sitting around. |
August 22nd, 2014, 04:37 PM | #6 | ||
In the meanwhile, the oil pump will make oil reach all the critical points of high friction. Quote:
Here is how-to test leakage of the rings and of the valves in separate steps: http://www.dansmc.com/compression_test.htm http://www.dansmc.com/leakdown.htm
August 22nd, 2014, 04:47 PM | #7 |
Participant
Join Date: Oct 2012 Motorcycle(s): '94 K75 std Posts: Too much.
No problem cranking engine with no carbs.
You can certainly check compression with no carbs (essentially more-than-wide-open throttle), but reading will be different than that of a warmed-up engine. |
Crank but no start | fishdip | 1986 - 2007 Ninja 250R Tech Talk | 18 | May 29th, 2015 08:00 AM |
Another bike will crank but won't start thread... | remix919 | 2008 - 2012 Ninja 250R Tech Talk | 10 | May 12th, 2014 01:05 PM |
Bike won't start, cleaned carbs, new gas, backfires whats next? | Runeknight95 | 2008 - 2012 Ninja 250R Tech Talk | 7 | July 26th, 2013 09:53 PM |
Shimmed the carbs and WOW!!! Brand new bike! | Socal5646 | 1986 - 2007 Ninja 250R Tech Talk | 8 | September 18th, 2011 01:45 PM |
bike won't crank!! | LoneRonin | 2008 - 2012 Ninja 250R Tech Talk | 14 | September 5th, 2011 04:19 PM |
