August 25th, 2014, 06:21 PM | #1 |
Did I screw up my carbs?
I recently bought a spare bike with no fuel tank. The seller fit it in my trunk sideways. Worried about fuel spilling out in my car, I asked if the float bowls had been drained and he told me they had.
That was over a week ago. I finally got around to removing the carbs and other stuff from the frame today. I was carrying them around with the boots, throttle cables, choke cable, etc attached as I looked for a safe place to set them. That's when I noticed fuel pouring out of one of the tubes. Oh boy. That means that there was fuel in it while it was sideways in my car. That means that as I moved them around today, sometimes upside down, fuel was contacting plastic and rubber parts inside. Did I ruin the carbs? Do I need to take them apart ASAP? |
August 25th, 2014, 07:09 PM | #2 |
Participant
Join Date: Oct 2012 Motorcycle(s): '94 K75 std Posts: Too much.
Nah. You're probably ok. Carb parts are designed for years of exposure to fuel vapor.
August 25th, 2014, 07:15 PM | #3 |
Inline 4!!!
I would say it's fine. Gasoline won't harm your carbs. especially if it was only for a few hours tops.
August 25th, 2014, 08:03 PM | #4 |
Oh you're screwed. Send it to me so I can properly dispose of it for you.
August 25th, 2014, 10:43 PM | #5 |
MOTM - July '15
I've rebuilt weedeater and lawnmower carbs before, and it was pretty easy. Would it even be a big deal if you did have to rebuild it? Or are these carbs more complex than that?
August 26th, 2014, 05:47 AM | #6 |
Thanks, guys. I didn't have the proper workspace or tools to take them apart right away, so your responses helped me sleep well.
The diaphragms cost a ton of money. If they get deformed or torn, you're screwed. I've been told to keep all the plastic/rubber parts away from fuel because it will melt/deform it. |
August 26th, 2014, 11:45 AM | #7 |
MOTM - July '15
Holy crap! Why?! That's insane. If I have a carb diaphragm issue, I'm buying a whole other parts bike, salvaging the carbs and parting the rest of the bike out. Craaaazy, man. I'm totally keeping that in mind. Thank you!
2008+ Ninja 250 Carburetor Screw size, allen screw size! | Runeknight95 | 2008 - 2012 Ninja 250R Tech Talk | 4 | March 2nd, 2015 11:49 AM |
A Screw | GearMonkey | Items Wanted | 8 | May 7th, 2013 04:50 PM |
Where does this screw go? | PistolPete93 | 2008 - 2012 Ninja 250R Tech Talk | 24 | March 5th, 2013 09:29 PM |
Theres a screw -__- | A Tomato | 2008 - 2012 Ninja 250R Tech Talk | 20 | July 7th, 2012 11:01 PM |
Where does this screw go? | patw | 2008 - 2012 Ninja 250R Tech Talk | 28 | January 7th, 2012 09:15 AM |
