August 26th, 2014, 05:48 AM | #1 |
Daily Ninjette Rider
Join Date: Jul 2014 Motorcycle(s): 2012 Ninja 250R, 2015 Vespa GTS 300 IE Super, 1989 Honda Elite 80 (SOLD) Posts: 402
Tires make a squishing sound
I've noticed lately on the highway (in stop-and-go traffic) that my tires are making a squishing kind of sound. It gets louder when I accelerate and then blends in with road noise.
Is this normal? Does it mean anything? Am I just crazy?
Check out my music at http://www.proteusmusic.com |
August 26th, 2014, 06:47 AM | #2 |
modaholic junkie
Join Date: Sep 2012 Motorcycle(s): 2001 ZX-12R, 2009 ninja 345cc and plenty of others in the past... Posts: 438
have you checked your tyre pressures when tyres are cold ?? hope you are not using any tyre-polishing products....
If noone has tried it before, I will !!! |
August 26th, 2014, 06:48 AM | #3 |
I'd check the tire pressure first.
If that's OK, I'd get the tires up off the ground and spin the wheels to see if you can duplicate the noise. While the rear wheel is up, check that the chain doesn't get too tight at any point in the rotation. |
August 26th, 2014, 06:53 AM | #4 |
not an actual panda
Join Date: Aug 2012 Motorcycle(s): 2008 Ninja 250, 2009 CBR600RR (Sold) Posts: A lot.
wear earplugs.
August 26th, 2014, 07:10 AM | #5 |
I check the tire pressures once a week - I'm running 28 front and 32 rear.
I'll see what happens with the wheels off the ground, but it really sounds like a tire contacting road noise. Not using any tire-polishing products - I don't really know what that is!
August 26th, 2014, 07:29 AM | #6 |
I wouldn't think it would cause the issues you mentioned, but you might want to bump the pressures up some. 28/32 is about as low as you want to go, and I don't think there's any advantage in it.
August 26th, 2014, 07:52 AM | #7 |
I put them at 28/32 based on the manual - what does bumping the pressure up do?
August 26th, 2014, 09:32 AM | #8 |
28/32 is fine, bumping it up a bit for preference is also fine within reason. It's unlikely that tire pressure has anything to do with what you think you're hearing.
August 26th, 2014, 10:22 AM | #9 |
modaholic junkie
have you greased the front and rear wheel axles recently ?? they need greasing from time to time....if that is the case, raising wheel off the ground will eventually duplicate the sound, like our friend above mentioned....
August 26th, 2014, 10:31 AM | #10 | |
Your size and type of riding will have something to do with the pressure that's best for you also. Try going to 30/34 and see if you feel a difference. As Alex noted, it would be really odd if that cured the noise issue. |
August 26th, 2014, 10:38 AM | #11 |
Well I'm about 210lbs and commute 2 hrs total each day. I tend to ride pretty hard on surface streets but take it easy on the highway.
I haven't greased the axles, I'm going to check with the wheels up tonight and maybe try higher tire pressure.
August 26th, 2014, 12:17 PM | #12 |
I think you might want to up your tire pressure then. maybe even to 32/36 and see if it feels more responsive. You may see better tire life also.
August 26th, 2014, 01:02 PM | #13 |
I think I'll try this as well, but being new to motorcycles what exactly does "more responsive" mean?
August 26th, 2014, 02:04 PM | #14 |
It just means it responds to your inputs quicker and more accurately. A good thing, unless it gets "nervous". I don't think making that amount of pressure change will take it that far.
August 27th, 2014, 06:24 AM | #15 |
I inflated up to 32/36 last night.
What a difference it made! I get what you mean by "responsive" - I feel like it's much tighter and doesn't walk around as much. I feel much more confident in my grip and leans. It feels WAY better now. The sound is still happening, but I noticed this morning that it only happens on one stretch of the highway. Maybe it's something to do with the road surface? I haven't had a chance to get the wheels off the ground (still have to figure out how to do that with the tools at my dispoal).
August 27th, 2014, 07:20 AM | #16 | |
I'd still check the chain adjustment. That's something you need to do regularly anyway. Here's a good video with step by step instructions - http://canyonchasers.com/video/chain.php Because you said you were new to cycles, here's a good source of info for general maintenance and adjustments - http://faq.ninja250.org/wiki/Main_Page |
August 27th, 2014, 07:24 AM | #17 | |
modaholic junkie
it will be easier and safer to get a friend to help you, at least to get to spin wheels fast enough... they should spin rather easily and not stop right after you stop applying force...
August 27th, 2014, 08:46 AM | #18 |
Thanks for the tips. I know I'm due for a chain lube as well.
What is this sound? Is this what out-of-spec valves sound like? | CZroe | 2008 - 2012 Ninja 250R Tech Talk | 24 | November 15th, 2021 05:48 PM |
Make Your Phone/iPhone Sound Like the New Ferrari 458 Italia | camaroz1985 | Off-Topic | 0 | August 13th, 2009 07:06 AM |
[motorcycledaily.com] - MD Readers Respond: Will Spec Tires Make a Difference in Moto | Ninjette Newsbot | Motorcycling News | 0 | November 2nd, 2008 12:09 AM |
[motorcycledaily.com] - Will Spec Tires Make a Difference in MotoGP? | Ninjette Newsbot | Motorcycling News | 0 | November 1st, 2008 04:09 AM |
