Old June 29th, 2017, 09:47 AM   #1
james250ninja
james250ninjette.newbie
james250ninja's Avatar
Motorcycle(s): 1986 ninja 250
Turn signal not flashing
I have a 2012 ninja 250 am my turn signals are not flashing.
Can I get a flash relay at any local auto parts store.
And what the part number if there any
james250ninja is offline   Reply With Quote
Old June 29th, 2017, 12:09 PM   #2
e.419
Motorcycle(s): 2012 ninja 250r
I got a generic relay from O'reilly's for my rebel and it worked fine. I think as long as it's just a two prong relay it should work fine. However I could only find a round relay so I had to use a zip tie to mount it. The part number I used was 44310. Maybe someone with a little more ninja experience could chime in.
e.419 is offline   Reply With Quote
Old June 29th, 2017, 01:50 PM   #3
ninjala
Motorcycle(s): 2008 Ninja 250
Turn Signal
Check turn signal bulb first. If the bulb is still ok, then you need to check the fuse. You can use the spare fuse in the box to replace the broken one.
ninjala is offline   Reply With Quote
Flashing ECU Abu_Mishary General Motorcycling Discussion 1 June 17th, 2016 09:38 AM
Looking for 09 oem rear turn signal and front turn signals and tail fairings mbbernas Items Wanted 1 September 11th, 2013 10:48 AM
Dashboard flashing? arnoldc6 2008 - 2012 Ninja 250R Tech Talk 4 March 27th, 2013 05:55 AM
Higher flashing rate on new turn signals??? Kitdog 2008 - 2012 Ninja 250R Farkles 10 June 25th, 2010 12:17 PM
Faster flashing signal randomwalk101 2008 - 2012 Ninja 250R Tech Talk 9 January 23rd, 2010 11:56 PM
