Old June 30th, 2017, 11:41 PM   #1
Ilham Fahri
Motorcycle(s): Ninja 250r '11
Radiator Fan Always Running
Recently i bought an used 2011 Ninja 250 it has 40000km mileage. I notice that the fan is manually set to always running, the previous owner have no idea about this as he's also receive it secondhand.
The question is, how do i set it back to auto mode ? Any help is appreciated.
Ilham Fahri is offline   Reply With Quote
Old July 1st, 2017, 04:50 AM   #2
kfilla
kfilla's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250R
Look to see if they just wired in a toggle switch somewhere. This is a very common mod on my other bike. Never known the ninja to have cooling problems. If there isn't a switch it was wired that way and you'll have to access a wiring diagram to see whats changed.
kfilla is offline   Reply With Quote
Old July 1st, 2017, 05:45 AM   #3
Toggle switch somewhere or possibly a jumped thermostat.
Old July 2nd, 2017, 12:06 AM   #4
Ilham Fahri
Thanks for the reply, today i removed the fairing and take a deep look at the wiring, turns out the fan was jumped to the power source, so i cut the cable and run the bike. Thankfully the fan starts kicking after a few km which mean the sensor still running properly.
Problem solved. Thanks a lot
radiator FAN SWAP james250ninja 1986 - 2007 Ninja 250R Tech Talk 3 August 20th, 2014 09:03 PM
Radiator Fan Question ajcalamia 1986 - 2007 Ninja 250R Tech Talk 9 February 8th, 2009 07:28 PM
