Old July 5th, 2017, 08:10 PM   #1
kvgeorge1
Motorcycle(s): EX250J
Idle problems (cable won't adjust)
Hello everyone! I am both new to this forum AND a new rider. I just purchased a 2008 EX250J (Ninja 250R) from a friend, that had it parked for almost 6 months. Needless to say, the carbs needed a good scrubbing. Once I did that, everything was AWESOME - until tonight. Take off speeds are really slow and it appeared to bog-down when throttling it up, so I tried to adjust the idle using the idle control knob. Now it idles at about 2500K, but I cannot make it go back down (it is as far to the left as the knob will turn). Also, the knob is really hard to turn.
Any ideas how to fix this so I can get it back to around 1300-1350?
kvgeorge1 is offline   Reply With Quote
Old July 5th, 2017, 08:59 PM   #2
Complete and thorough carb clean and valve clearance check.
Hello Ken, welcome to the board!
Old July 5th, 2017, 09:11 PM   #3
kvgeorge1
So, I already cleaned the carb very well. The fact that the knob won't move easily has me concerned (does this mean that I have to lubricate it)? Can you help me to understand how to adjust the valve clearance?
Old July 5th, 2017, 09:29 PM   #4
Valves:
https://faq.ninja250.org/wiki/How_do..._the_valves%3F
Your sudden change in running points to dirt in the carbs. There are lots of little passages that need to be clean, all jets removed, etc.. Are you sure you really did the whole job?
Air leaks in the intake system can also cause high idle speeds.
Old July 6th, 2017, 01:13 AM   #5
Welcome to the dirty-malfunctioning-carb club!
First, let's address your idle-adjuster. Most likely you have cross-threaded the adjuster cable at the carb end. If it wasn't cross-threaded, it would continue to unscrew and fall off.
Second, did you completely disassemble your carbs down to every last nut and bolt to clean like this? If not, you have crud hiding in tiny crevices and passageways.
Old July 6th, 2017, 05:54 AM   #6
kvgeorge1
I didn't break-it down as far as that (removing the needles from the boots, but I did remove the jets and clean them, along with the gasket areas, and the metal housings).
Interesting about the idle adjustment. I will go back and make sure it is not cross-threaded.
Old July 6th, 2017, 06:26 AM   #7
Did you remove the caps and idle mixture screws when you cleaned the carbs? Did you set them at 2.5 turns out after cleaning the passages?
Another possible issue is the gas tank - is it clean inside? If there was gas left in it while it sat it should be completely drained along with the floatbowls.
You may have cranked on the idle speed knob too hard. If the idle mixture passages are plugged it's not going to want to idle, which would account for why you needed to increase it with the idle speed adjustment.
Old July 6th, 2017, 07:03 AM   #8
kvgeorge1
I did completely drain the tank and drain the float bowls. The mix screws are covered and I don't know how to remove the caps (drill them out maybe???).
It sounds like the idle cable/screw from all the previous posts. I still need to check that.
Old July 6th, 2017, 07:19 AM   #9
That's the first thing that needs to be done when working on the carbs.
Here's some general carb info - https://faq.ninja250.org/wiki/Intake
Here's info about removing the caps - https://faq.ninja250.org/wiki/Removi...re_screw_plugs
After cleaning the passages and confirming the o-rings are in good condition and in the proper spot, adjust the idle mixture screws - https://faq.ninja250.org/wiki/How_do...dle_mixture%3F
Old July 6th, 2017, 10:08 AM   #10
kvgeorge1
Great news! I got it working again!!! Turns out that the screw at the carb looked a bit "dry", so I lightly sprayed it with Slick 50, and now it works like a champ and I was able to correctly set the idle.
I love this site - you guys are a wealth of information!!!
Question about adjust idle mixture screws daverdfw 2008 - 2012 Ninja 250R Tech Talk 14 February 28th, 2016 05:34 PM
Any way to adjust throttle cable? shortyg83 2008 - 2012 Ninja 250R Tech Talk 12 July 19th, 2015 07:22 PM
Idle Adjust location????? Modzilla 1986 - 2007 Ninja 250R Tech Talk 10 January 17th, 2013 06:07 PM
How to Adjust Idle Speed 2013 kawi girl 2013 - 2017 Ninja 300 Tech Talk 6 October 23rd, 2012 07:02 AM
Valve Adjust - whoa! Idle Speed? bungie4 1986 - 2007 Ninja 250R Tech Talk 23 August 2nd, 2011 06:02 PM
