April 14th, 2016, 01:10 PM | #1 |
[motorcycle.com] - 2017 Yamaha FZ-10 Announced for Canada
Yamaha Motor Canada has announced it will offer the MT-10, bringing it over under the name FZ-10 as an early 2017 model. As of this writing, Yamaha’s American arm has not made an official announcement for the U.S. but we expect one shortly. In Canada, the FZ-10 will retail for CN$15,499 (US$12,055). That puts it CN$3500 lower than the 2016 YZF-R1 and $1200 less expensive than the YZF-R1S. The FZ-10 is powered by an 998cc Inline-Four derived from the R1/R1S engine. As with the R1, the FZ-10 uses four-valve cylinder head design but uses 31 mm steel intake valves instead of the 33 mm titanium intake valves on the superibike (the 26.5 mm steel exhaust valves are the same however). Intake and exhaust cam profiles and timing were altered to improve low-to-mid-range torque and power. The engine still uses a crossplane crankshaft, but it’s heavier than the one on the R1 for improved control at low engine speeds. Yamaha modified the pistons and combustion chamber and compression ratio to make the engine more street-friendly. The FZ also uses a single set of injectors compared to the twin-injectors on the R1. Yamaha claims a peak output of 81.8 lb-ft. at 9000 rpm for the FZ compared to 83.2 lb-ft. at 11,500 rpm for the R1. No horsepower numbers were released for the Canadian-spec FZ-10, but considering the peak torque is the same as the European specifications, we expect horsepower to be similar to the 158.2 hp at 11,500 rpm claimed on the other side of the Atlantic. A Yamaha Chip Control Throttle handles the fueling, offering three power modes to go along with three levels of traction control. Cruise control is standard, working at speeds from 50-160 kph (31-100 mph) in fourth gear or higher. The chassis is comprised of the R1’s deltabox frame but the rear subframe is steel instead of magnesium, so it can better support the extra weight of luggage (sold separately, of course). The fully-adjustable KYB fork is based on the R1’s unit but with slightly revised settings. The rear wheel is suspended by a fully-adjustable monocross KYB shock with piggy-back reservoir. Both front and rear suspension offer 4.7 inches of travel. Braking ability is provided by radial-mount four-piston calipers gripping twin 320 mm discs up front while a Nissin single-piston caliper squeezes the 220 mm rear disc. ABS is standard. Other features include a steering damper, full LED lighting, digital LCD display, 12-volt DC connector, a 4.5-gallon fuel tank and a claimed wet weight of 463 pounds. Canadians will have a choice between a Matte Dark Metallic Gray with Black paint scheme or the Bluish Gray with yellow wheels. 2017 Yamaha FZ-10 Canadian SpecificationsEngineLiquid-cooled, DOHC, 16-valves (4-valves/cyl), inline four-cylinderDisplacement998ccBore and Stroke79 x 50.9 mmCompression Ratio12:1Maximum Torque11.3 kg-m (81.8 ft-lb) @ 9,000 rpmEngine ManagementYCC-T, D-Mode (3), Traction Control (3), Cruise ControlFuel Delivery45 mm Mikuni throttle body fuel injectionLubricationWet sumpIgnition / StartingTCI / ElectricTransmission6-speedFinal Drive“O”-ring chainSuspension (Front)Fully adjustable inverted 43 mm fork / 120 mm (4.7″) wheel travelSuspension (Rear)Fully adjustable link Monocross / 120 mm (4.7″ wheel travel)Brakes (Front)Dual 320 mm discs / radial mount 4-piston calipers / ABSBrakes (Rear)220 mm disc / single piston caliper / ABSTires (Front)120/70ZR17Tires (Rear)190/55ZR17Length2,095 mm (82.5″)Width800 mm (31.5″)Height1,110 mm (43.7″)Wheelbase1,400 mm (55.1″)Rake / Trail24° / 102 mm (4″)Ground Clearance130 mm (5.1″)Seat Height825 mm (32.5″)Fuel Capacity17 liters (4.5 US gallons)Wet Weight210 kg (463 lb.)Colour(s)Bluish Gray Matte Dark Metallic Gray with Black[Source: Canada] 2017 Yamaha FZ-10 Announced for Canada appeared first on Motorcycle.com News. Click here for full story...
[American Motorcyclist Association] - Deeley Harley-Davidson Canada announced as spon | Ninjette Newsbot | Motorcycling News | 0 | July 8th, 2014 07:40 AM |
[motorcycle.com] - 2015 Yamaha FZ-07 Announced for Canada | Ninjette Newsbot | Motorcycling News | 0 | March 18th, 2014 01:50 PM |
[motorcycle.com] - 2011 MV Agusta 1090R Announced in Canada | Ninjette Newsbot | Motorcycling News | 0 | April 7th, 2011 07:40 PM |
[motorcycle.com] - Canada gets 2011 Yamaha FZ8 and Fazer 8 | Ninjette Newsbot | Motorcycling News | 0 | June 10th, 2010 07:10 PM |
[motorcycle.com] - 2011 Yamaha TT-R models announced | Ninjette Newsbot | Motorcycling News | 0 | June 10th, 2010 07:10 PM |
