April 24th, 2015, 03:19 PM | #1 |
Join Date: Apr 2015 Motorcycle(s): 2006 EX250-F "Sheldon" (Sold), 2010 Ninja 250R "Zeke" Posts: 129
New Biker, New EX250-F, and a video!
Hey there everyone!
My name is John and I'm both a new biker and a new EX250-F owner. I'm 27 and biking is something I've wanted to do for a while. My primary motivation for getting my EX250-F dealt with the fact that my job is 6 miles away and I can save a lot in gas and insurance by using a bike as my daily driver. Secondarily, it's just been a dream of mine to master bike riding at some point in my life. I'll always be a student, but what better time than now in my life to start riding. I did post a YouTube video detailing my first little bit of ownership. I purchased the bike used for $700 from a friend of mine who upgraded to a '15 650 ABS. I took my permit test (I work at the MVD here in Avondale, AZ) and brought the bike in for and possible inspections and for title transfer and registration, and because I could. I had been practicing a whole day prior (which wasn't 100% smart) and felt confident about taking it to and from work. Unfortunately, on the way home I took a turn at an intersection a little too hard and put the bike down at around 20mph. The damage wasn't major but enough that I lost the left side fairing, chipped up my upper fairing and windscreen, gauge cluster and lost a turn signal and headlight glass. In the video I start working on the bike and getting her patched up. My MSF is scheduled for next weekend and I'm looking forward to it! Last futzed with by johncrist1988; April 24th, 2015 at 06:40 PM. |
April 24th, 2015, 03:23 PM | #2 |
Welcome John!
April 24th, 2015, 03:51 PM | #3 |
cadd cadd cadd
MOTM - May '15
Sorry to hear you went down. Went in too hot and hit the front brakes?
Riding it like I financed it. |
April 24th, 2015, 03:52 PM | #4 |
April 24th, 2015, 04:02 PM | #5 | |
cadd cadd cadd
MOTM - May '15
You'll have a lot of fun at the MSF. Enjoy!
April 24th, 2015, 05:04 PM | #6 | |
- Flush the cooling system (doing that tomorrow) - New tires (bought the Kenda K671s front and back, now I just need to find a place to get them mounted when they come in) - New brake pads, rotors are smooth so now worries there - Clean the carb - Soak the chain for a night to clean it, then lube it up - Valve adjustment - Cam chain maintenance, although I don't know exactly what that entails yet. Long term I'm looking at finishing the upper fairing repair and repainting it a baby blue. I'd love to look into finding an analogue to digital converter for the speedometer and designing an interface for an Android tablet to run a full digital setup. |
April 24th, 2015, 05:46 PM | #7 |
I posted here about a click I'm hearing, with an attached video. Not sure what it is, but it's what's mostly leading me to want to look at a timing chain adjustment in my prior post.
April 24th, 2015, 06:29 PM | #8 | |
MOTM - Sep '14
Welcome John
quote me to see how to post vid
Keep calm and ride on -Motofool Never quit on a rainy day -ally99 |
April 24th, 2015, 06:39 PM | #9 |
Thanks! Hopefully now I'll stop breaking things :P
April 24th, 2015, 08:53 PM | #10 | |
cadd cadd cadd
MOTM - May '15
Brake pads are pretty easy as well. There's a DIY somewhere on this site. And I'm sure you can find some youtube vids as well. If you're going to work on the pads, I think you may actually need to take off the rear wheel (it was for the 300). Once you get the wheels off, just carry them into the shop with the new tires. Much less expensive that way when you mount new tires (vs riding the bike in). For the chain, make sure you clean it with something that's O-ring safe. I'm pretty sure all motorcycle specific chain cleaners are O-ring safe. But it can be costly. What I use is kerosene. It is O-ring safe and works better than most aerosol motorcycle specific chain cleaner in my opinion. The crap just melts right off with kerosene. Just make sure you're not smoking or near any flames when using it. Valves - I've never attempted. But looks complicated. Shims involved. I'm just not as patient! But good luck! There's a DIY written up as well if you do some searching on the site. Carbs - I don't know about the pregens. But the 08 bikes are a bitch to work on just because it's frustrating taking them off the bike with the stock airbox in place. But there are plenty of DIYs on carbs as well. Enjoyu getting to know your bike! Take your time. Have fun wrenching!
April 25th, 2015, 01:53 AM | #11 |
Hello and welcome.
April 25th, 2015, 05:52 AM | #12 |
sammich maker
MOTM - Apr '15
Welcome.
https://www.brocksperformance.com/VZ...0035+C450.aspx |
April 25th, 2015, 07:20 AM | #13 |
Ninjette Lurker
Join Date: Jun 2014 Motorcycle(s): 2003 Ninja EX250 (Cafe, Naked, Wreckurrected) Posts: 72
Welcome.
I dont think anyone mentioned it yet, That extra cable in the video you are confused about: it's a extra clutch cable the previous owner must have added incase the current clutch cable breaks while riding. you would disconnect the broken line on the bike and attach the 2 ends on the extra cable up to the lever and transmission down below. Hope that all makes sense! |
May 4th, 2015, 10:41 PM | #14 |
Join Date: Dec 2008 Motorcycle(s): '08 Kawasaki EX250 "Yoshi", '99 Kawasaki Concours "Grace", '06 Concours "Belle", '06 Yamaha YZF600R "Slick" Posts: A lot.
< ATGATT > Sweat you can wipe off, Road rash you can't. HEY!! Unregistered!! Does your bike have a name? |
May 5th, 2015, 04:06 AM | #15 |
Track Clown
MOTM - Sep '15
May 5th, 2015, 06:16 AM | #16 | |
May 5th, 2015, 11:40 AM | #17 |
Join Date: Apr 2015 Motorcycle(s): 11 Ninja 250R se Posts: 46
welcomeee
A little rebellion now and then ... is a medicine necessary for the sound health of government. -Thomas Jefferson |
[visordown.com] - Video Not your stereotypical biker gang | Ninjette Newsbot | Motorcycling News | 0 | July 8th, 2014 04:50 AM |
[visordown.com] - Video biker gang cuts off street in Manhattan | Ninjette Newsbot | Motorcycling News | 0 | January 16th, 2014 03:00 PM |
The Ultimate Biker Dance Video! ;P | 808yewtube | Videos | 2 | March 9th, 2013 06:58 PM |
[visordown.com] - VIDEO: Speeding biker identified by his kit | Ninjette Newsbot | Motorcycling News | 0 | October 1st, 2008 06:20 AM |
[visordown.com] - VIDEO: Police footage of 140mph biker | Ninjette Newsbot | Motorcycling News | 0 | September 30th, 2008 02:57 PM |
