July 4th, 2011, 12:04 AM | #1 |
Join Date: Jun 2011 Motorcycle(s): 2008 Ninja 250r Posts: 62
Ninja throwing star sprocket?
So today we were joking that if my ninja was black I should get leathers that looked like a ninja costume, katana-looking handlebar grips.. and ninja throwingstar sprockets..
I looked, and.. yeah - I kinda want them! http://cgi.ebay.ca/VORTEX-CAT5-REAR-...#ht_2853wt_905 |
July 4th, 2011, 02:15 AM | #2 |
That would look totaly cool on any color Ninjette. Great find.
July 4th, 2011, 11:09 AM | #3 |
Ridin Dirty
Join Date: Jun 2011 Motorcycle(s): 2011 white se 250r , 2008 zx6R Posts: 921
the white SE ninjas actually have a little ninja guy throwing stars.. its in the black part of the graphics.. didnt even notice it at first until i peeled them off and was up close on them..lol! actually all over the side fairing vinyl and near the rear seat has little throwing stars very faint like shadows.. kinda cool.
#1 |
July 4th, 2011, 11:15 AM | #4 |
is that made from aluminum? if so, I wouldn't recommend them.
July 4th, 2011, 11:25 AM | #5 |
Ridin Dirty
they say it is.. Made from 7075 T6 aluminum
#1 |
July 4th, 2011, 11:31 AM | #6 |
Ninjette wanabe :D
Join Date: Apr 2011 Motorcycle(s): white 300 :D Posts: A lot.
because aluminum wears quick? if so how long you think?
VROOOM vrooom >.> |
July 4th, 2011, 11:37 AM | #7 |
It varies. But significantly quicker than steel sprockets.
July 4th, 2011, 11:55 AM | #8 |
Ninjette wanabe :D
do they make steel colored sprockets :O
VROOOM vrooom >.> |
July 5th, 2011, 09:34 AM | #9 |
ModMy250.com
That's a 47T sprocket
The www.ModMy250.com guy |
July 5th, 2011, 09:46 AM | #10 |
Ninjette wanabe :D
man we need a 60t poping wheelies all day x] jk XD
VROOOM vrooom >.> |
July 9th, 2011, 09:58 PM | #11 |
Uhh... that looks more like a saw blade.
July 10th, 2011, 08:32 PM | #12 |
so 47t is bad?
And maybe a saw blade, but to me it looks like a throwing star |
July 10th, 2011, 09:05 PM | #13 |
ModMy250.com
47T will increase acceleration but reduce how much top speed you get. Generally speaking, people go lower than the stock 45, not higher. You can use http://www.gearingcommander.com/ to figure out what speed you would be at with what kind of gear combo. The ninja 250 is in the database so just use the menu to select it and you can play around with it.
July 12th, 2011, 11:20 PM | #14 | |
That site is pretty cool, though I'm not sure I understand it. I think if I read right, if I went with a 17/42 setup, I could hit a top speed of over 200km/h - but I don't see anywhere that it refers to accelleration affects... any ideas? |
July 13th, 2011, 12:18 AM | #15 |
While it will increase the speed at a given RPM, it doesn't actually increase your top speed unless you were rev-limited (on a Ninjette, you weren't). Same HP vs. Wind resistance = about the same top speed
Now, a 16 tooth front sprocket requires you to modify the sprocket cover. A 17 tooth might not be easily possible. Taking the rear down to 39 would have about the same effect as that extra front tooth, so 16:39 is possible. |
July 13th, 2011, 08:39 AM | #16 | |
ModMy250.com
Here's an example: stock gearing/ sprockets 15/45 sprockets: Notice the numbers- the speed in MPH- goes up in relation to the RPM? Since the Final Drive Ratio is now taller, the speed is now higher at a given RPM. However, what this means is that it takes longer to reach that speed. 13/45 sprockets: Conversely, lowering the number means you will accelerate faster, but lose the top speed in 6th gear. Notice how in the stock 14/45 setup at 12.3K RPM the speed is maxed out at 99.8, but with a 13/45 setup at 12.3K RPM the speed would be maxed out at 92.7. Hope that helps
July 13th, 2011, 09:00 AM | #17 | |
July 13th, 2011, 09:08 AM | #18 | |
ModMy250.com
Sorry to derail the thread though.
July 13th, 2011, 01:01 PM | #19 | |
July 13th, 2011, 03:32 PM | #20 |
wow you guys know your stuff -
so if I understand, I can't increase my top speed because even if the sprockets would theoretically allow for it (understanding a decrease in acceleration), the bike doesn't have the HP to get there? is that right? I really should write a post about this on my site - just not sure I get it yet :P |
July 13th, 2011, 04:14 PM | #21 |
ModMy250.com
Every bike and rider is different. For instance my bike has jetted carbs, shimmed needles, brt tis ignition, and a 15/43 combo. I've never tried to hit top speed because it's pretty fast. I can do 80mph in 6th at only 9k and the bike still feels like it can go faster. I believe that the bike could max out the speed at over 100. I know I hit 90 on it once with the stock sprockets and it was still pulling when I let off the throttle. I wouldn't write off the ninjette as not having enough hp to increase your speed.
July 13th, 2011, 04:36 PM | #22 | |
Since we already hit that equilibrium in top gear and can't pull to redline (assuming a reasonably stock bike and stock gears), changing to taller gear doesn't improve top speed much at all, if any. With most motorcycles, people make the gearing shorter to improve acceleration. A typical sportbike gearing, has it hitting redline in top gear at 170+ mph+ for a 600 and 190+ mph for a 1000, though they are often electronically limited to 186 mph anyway. By making the gearing shorter (smaller front sprocket and/or larger rear sprocket), it improves the acceleration of the bike in real-world conditions, and while top speed is affected, nobody needs to go 160+ on the public roads anyway. The ninjette is a special case with our tremendously short gearing already, so people often go the other direction and make it taller (larger front sprocket and/or smaller rear sprocket), which lowers the revs at a given road speed, and making things slightly calmer on the highway.
July 13th, 2011, 06:19 PM | #23 |
Tightwad Tinker
Join Date: Apr 2011 Motorcycle(s): '09 Ninja 250R Posts: 161
One thing to keep in mind is that it is beneficial to choose sprockets and a chain length with a coprime number of teeth/links with the idea to spread wear the most evenly.
July 13th, 2011, 08:45 PM | #24 |
The rev limiter is actually a bit past redline (14K, IIRC. redlines at 13K) but you may be looking at redline for top sustainable/safe cruising speed. Because it increases your speed for a given RPM, it does increase the speed that you can reach while staying under redline. You kinda have to be going downhill and 105+MPH indicated to do that with stock gearing and that's about the top speed regardless of gearing anyway. I routinely see almost 110 indicated (~100MPH actual) when going downhill with 15:41 and I'd probably be in the red at 14:45 but, as long as it doesn't require over 14K RPM, it can do it at any gear ratio.
July 13th, 2011, 08:48 PM | #25 |
Good point, redline doesn't necessarily equal rev limiter.
[motorcyclistonline] - Throwing Codes | COOK'S CORNER | Ninjette Newsbot | Motorcycling News | 0 | March 27th, 2015 03:40 AM |
People throwing things at you? | wtfh4xx | General Motorcycling Discussion | 59 | June 13th, 2012 06:18 AM |
[hell for leather] - Throwing The One Motorcycle Show | Ninjette Newsbot | Motorcycling News | 0 | February 7th, 2011 06:00 PM |
Talk about throwing a wrench in my plans... | Apex | General Motorcycling Discussion | 13 | May 9th, 2009 04:50 AM |
