Old April 20th, 2009, 07:06 PM   #1
DirtyBoy
DirtyBoy's Avatar
Brake light works but tail light doesn't
If i hit the front or rear brakes the light works but it's completely off when the bike is running without the brakes applied. I checked the wires and tail light fuse under the seat but everything looks to be OK. Any ideas on what it could be?
49T sprkt/ EK gold chain/ Galfer pads and SS lines/120 frt 150 rr Pilot Powers/ GSX-R can/Desnorkled/ Raised needles/ Slider spools/ Cowl/ LED rear signals/ Fender eliminator/ Tinted lights / Emu seat
DirtyBoy is offline   Reply With Quote
Old April 20th, 2009, 07:20 PM   #2
Jlin
Motorcycle(s): Ninja 250r
check the bulb, the brake light is a dual filament bulb, maybe that needs to be replaced.
Jlin is offline   Reply With Quote
Old April 20th, 2009, 07:36 PM   #3
Viper-Byte
Viper-Byte's Avatar
Motorcycle(s): 08 Ninja 250R in Green! (Sold) Now 2011 Triumph Daytona 675 SE
Your bulb is blown, replace it.
I have had the issue, the bulbs are dual fillament, which is why the brake light works but tail light doesn't.
2008 GREEN Kawasaki Ninja 250R.
AreaP Quiet Core Carbon Fibre : 8000k HIDs : Dynojet Jet kit : Double Bubble Windscreen
Viper-Byte is offline   Reply With Quote
Old April 20th, 2009, 07:48 PM   #4
TnNinjaGirl
Ms. Personality
TnNinjaGirl's Avatar
Same issue, blown bulb. There was a recall awhile back if I remember correctly.
Old April 20th, 2009, 07:52 PM   #5
Snake
Snake's Avatar
Good time to switch to an LED direct replacement bulb. They are very bright and no filament to burn out.
Old April 20th, 2009, 10:42 PM   #6
DirtyBoy
DirtyBoy's Avatar
Thank you all very much.
Old April 20th, 2009, 10:43 PM   #7
so, did you fix the problem?
Old April 20th, 2009, 10:47 PM   #8
DirtyBoy
DirtyBoy's Avatar
No not yet. I was too lazy to go and get a new bulb. I will definatley take care of it tomorrow.
Old April 29th, 2009, 12:30 AM   #9
i916it
Motorcycle(s): 250R 08
Yeauuupp. I've replaced mine atleast 10 times.
I think I got something shorted out inside.
It's the filaments...argh.
i916it is offline   Reply With Quote
Old April 29th, 2009, 02:18 PM   #10
zail
zail's Avatar
Motorcycle(s): 08 Ninja 250r
I had this problem too but where the filiment had broken it was still making contact sometimes thus leaving me with fully working brakelight and intermittant tail light - I checked all the wiring and totally dismantled the tail tidy before I even thought to check the bulb, and even then the break in the filiment was barely visible..
zail is offline   Reply With Quote
Old April 29th, 2009, 04:59 PM   #11
Old May 19th, 2009, 07:44 PM   #12
bluphobic
Motorcycle(s): None
Does anyonw know how frequent this issue is? I just realized it was out on my bike.
bluphobic is offline   Reply With Quote
Old May 19th, 2009, 07:46 PM   #13
what year is your bike? they had some bad bulbs in the first year of the new gen 250Rs. Replace the bulb if it's burned out... should be good for a few years at least.
Old May 19th, 2009, 07:56 PM   #14
bluphobic
Motorcycle(s): None
its a 2008, would you happen to know where i could get an LED replacement bulb?
Old May 19th, 2009, 08:04 PM   #15
OldGuy
Live Life
OldGuy's Avatar
Motorcycle(s): 2009 Green SE Ninja 250
Have you tired the search function yet?
- ATGATT -
Scorpion EX700 Hi-Vis Helmet, First Gear MeshTek 3.0 Jacket, TourMaster Transition 2 Jacket and Flex Pants, Sidi Doha boots
OldGuy is offline   Reply With Quote
Old May 19th, 2009, 10:00 PM   #16
Here are two threads with some related bulb info:
http://www.ninjette.org/forums/showt...highlight=bulb
Old May 19th, 2009, 10:56 PM   #17
DirtyBoy
DirtyBoy's Avatar
I bought some Sylvania bulbs one of which blew again about a week later. Now the one I replaced that one with burned out. I want to put LED's in but I dont want to have the same problem with a more expensive bulb.
Old May 20th, 2009, 06:33 AM   #18
TrueFaith
TrueFaith's Avatar
Motorcycle(s): 2011 Honda CBR250R
The tail light bulb was an issue for 2008s. I had to replace mine within a month of getting my bike. A replacement bulb is only $1-2 so if you have a 2008 and the tail light hasn't gone yet, it's worth the peace of mind to replace it. You don't want it to go at night when you're far from home or you're likely to get rear-ended.
I hope eveyone is checking the operation of this bulb before every ride even if it has been replaced.
TrueFaith is offline   Reply With Quote
Old May 27th, 2009, 05:04 PM   #19
Cochese
The Grand Royal
Cochese's Avatar
Mine died yesterday. Going with an LED replacement.
Cochese is offline   Reply With Quote
Old May 27th, 2009, 07:18 PM   #20
bluphobic
Motorcycle(s): None
I tried an led light, specifically a high power 5watt led bulb http://www.superbrightleds.com/specs/115x-xLX3.htm. It's not bright at all, not even close to the light output of stock bulbs. Don't waste your money on an LED brake light.
Tail light works, Brake light NOT SO MUCH :( Enrgkid 2008 - 2012 Ninja 250R Tech Talk 3 July 19th, 2014 05:08 PM
Rear Brake Doesn't activate Brake Light And DOT3/4 FRONT BRAKE OIL coelgrim 2008 - 2012 Ninja 250R Tech Talk 16 March 11th, 2013 05:10 PM
Front Brake Switch Doesn't Light Tail Light ajcadoo 2008 - 2012 Ninja 250R Tech Talk 19 January 30th, 2013 07:06 PM
Brake light works, but doesn't work =/ CalvinAmI 2008 - 2012 Ninja 250R Tech Talk 6 May 14th, 2012 07:24 AM
OEM Tail/Brake Light Comparison to LED Tail/Brake Light g21-30 2008 - 2012 Ninja 250R Farkles 19 November 7th, 2009 12:08 PM
