Old July 9th, 2011, 09:18 AM   #1
peeweecollins
peeweecollins's Avatar
Motorcycle(s): 06 ninja 250
Oil leaking out of airbox bike wont run properly
I did a search before I decided to post i'm a fairly new rider this morning I decided to take the bike for an extended highway run of about 60 miles round trip the bike ran perfectly there average speed 70-80 mph on the way back the bike ran good till I hit the exit ramp where it just died so I pulled over to check it out and I could see oil dripping out of the left side by the coolant tank I wiped it off and discovered it was coming from the airbox somewhere,
after I let it sit for a while it finally started but it wouldn't idle and I could see blue smoke coming out when I reved it, the bike is an 06 250 with only 7k on it so I figured the rings couldnt be shot plus I had no problems with the bike prior to that, it runs then it dies again I have to let it sit for minute before it cranks again sorry for the long post but any advise would sure be aprciated before I take it to the shop when it could just be a simple fix thx.
peeweecollins is offline   Reply With Quote
Old July 9th, 2011, 04:05 PM   #2
darrell85
darrell85
darrell85's Avatar
Motorcycle(s): 2001 250 ninja
how much oil are we talkin about? a few drops or pouring? have you added or changed the oil recently? you probably just have too much oil in the crank case and the excess is blowing up the crankcaes breather tube into the airbox and then both leeking out and being sucked into the carbs. clean the airbox, filter, and read the faq on how to add the proper amount of oil. been there and done that!!!!!!!!!!! good luck
Last futzed with by darrell85; July 9th, 2011 at 04:10 PM. Reason: added more text
darrell85 is offline   Reply With Quote
Old July 9th, 2011, 08:09 PM   #3
peeweecollins
once the bike was running it was more like a constant drip the bike has a hard time cranking and once it starts if you let go of the throttle it dies
Old July 9th, 2011, 08:11 PM   #4
how much oil are you showing in the sight glass on the engine crankcase?
Old July 9th, 2011, 08:17 PM   #5
peeweecollins
when the bike is standig straight i have to lean it more to the right to see any oil
Old July 9th, 2011, 08:19 PM   #6
oil level should be read in the sight glass when the bike is perfectly vertical and on a flat surface. Is that how you are reading the oil level?
Old July 9th, 2011, 08:24 PM   #7
peeweecollins
yea when i was checking the sight glass i had the bike on the center stand
Old July 9th, 2011, 08:27 PM   #8
don't use the center stand to get an accurate reading.
Old July 9th, 2011, 08:29 PM   #9
DaBlue1
DaBlue1's Avatar
The bike must be off the center stand and on two wheels. Checking the oil while the bike is on the center stand will screw up your oil reading.
Old July 9th, 2011, 08:34 PM   #10
peeweecollins
oh ok didn't know that but when I leaned over to the right I did see oil I guess it was verticle then couldn't tell because I was kneeling down at the time looking at the site glass but the oil level was lower than normal tried to crank the bike a few minutes ago it will start but won't idle not even with the choke cant get any rpms neither
Old July 9th, 2011, 08:43 PM   #11
so, what is your oil level reading in the sight glass with the bike vertical and on a flat surface?
Old July 9th, 2011, 08:50 PM   #12
peeweecollins
when the bike is standing straight up you can barely see it below the bottom knotch on the sight glass
Old July 9th, 2011, 08:53 PM   #13
seems like your bike is low on oil. try adding some so it's at the top line in the sight glass.
regardless, that shouldn't be the cause of your problem. has the bike been dropped, on it's side, crashed or similar recently?
Old July 9th, 2011, 09:02 PM   #14
peeweecollins
it fell over this past wensday while running but nothing serious it ran fine after that untill this morning
Old July 9th, 2011, 09:06 PM   #15
when it fell over, it is possible that oil spilled from the crankcase vent into the airbox. They are connected via a hose.
I would recommend you remove your air filter and check to see if it's saturated w/ oil. also, clean out your airbox if there is oil on the bottom.
if the bike still won't start/run cleanly after that, remove your plugs and check them you could have fouled one of them by having too much oil leak thorough your carbs.
Old July 9th, 2011, 09:12 PM   #16
peeweecollins
Thanks man I will do that first thing in the morning I might as well change the oil and filter while i'm at it and again thanks for the advice.
Old July 9th, 2011, 09:14 PM   #17
let us know what you find.
how many miles on the oil and filter now? what oil are you using?
Old July 9th, 2011, 09:29 PM   #18
peeweecollins
I bought the bike second hand it has 7k miles on it i'm assuming the previous owner had it last changed at 5k I don't know for sure and by the book it says it shouldn't be changed again till 10k then again the bike is 6 yrs old
Old July 9th, 2011, 10:05 PM   #19
oil should be changed yearly, regardless if it made the mileage interval. I'd recommend changing it if you have no maintenance records. Rotella synthetic, 5W-40 is great oil to use.
Need Help Diagnosing Bike That Wont Run Yondaime 2008 - 2012 Ninja 250R Tech Talk 25 October 4th, 2014 01:18 PM
Help!! Need advice... Bike Wont Run Trainsk8 2008 - 2012 Ninja 250R Tech Talk 3 May 30th, 2012 06:32 PM
Bike doesn't run properly after sitting only 2-3 days shiftdrift06 1986 - 2007 Ninja 250R Tech Talk 15 April 23rd, 2011 05:06 PM
Oil rapidly filling airbox, won't run without choke. 44chart 1986 - 2007 Ninja 250R Tech Talk 21 March 28th, 2011 09:13 PM
bike wont run without choke on? ReDnEcK 1986 - 2007 Ninja 250R Tech Talk 4 September 15th, 2010 08:50 PM
