October 19th, 2012, 04:13 PM | #1 |
Limp Noodle
Join Date: Jun 2012 Motorcycle(s): 2006 Ninja 250, Fastest Red money can buy Posts: 212
pregens - fuel range
Do pre-gens really have a 4.8 gallon tank? If so, why aren't we getting like 300 per tank?
October 19th, 2012, 04:27 PM | #2 |
Join Date: May 2009 Motorcycle(s): 04 ninja 250, 05 zzr 600 (sold), 07 cbr600rr Posts: 319
yes they do...i get about 240 before reserve which leaves another gallon...so there you go, 300 if you ran it dry...
of course ymmv depending on your riding style...cruising, stop and go, canyons, etc.... |
October 19th, 2012, 06:10 PM | #3 |
/pre-gen tech
October 20th, 2012, 04:52 AM | #4 |
The total tank size is 4.7 gallons (18 liters). You can use about 4 gallons of that before switching to reserve. However, because of the shape of the tank, the reserve amount is divided between the two sides of the tank. So you could run dry on the left side, but still have gas on the right.
You should calculate your mileage and then figure out how many miles you can go on 4 gallons. Then get gas before you hit that number. You should also check your mileage with each fillup. It can change. My bike got 70 mpg when I got it, and now only gets 55-60 mpg. So something is wrong with it and I haven't figured it out yet. So for me, I get gas after 200 miles or so.
October 20th, 2012, 04:55 PM | #5 |
I get 300+ on mine. I fill after at the first opportunity after I hit the reserve, usually around 250. But i've seen 300 a couple of times.
I bet @greenaero gets 400 plus. |
October 21st, 2012, 06:36 AM | #6 |
I hit reserve typically around 3.7 gallons down. The capacity of the tank is more theoretical because of the shape of the tank. There's a big hump that runs up the middle, dividing the lower tank into two sections. There are also pockets at the bottom that hold fuel that's lower than the lowest petcock pickup point. Basically, the published capacity is what the tank will hold when filled from completely dry to the filler neck, and actual capacity is the fuel level above the bottom of the petcock reserve inlet tube, on the left side of the tank. You can lean the bike and slosh fuel over to the left side from the right, but there will always be a quart or more of fuel in the tank that's just not useable.
October 21st, 2012, 02:22 PM | #7 |
Where's the Factory Pro jetting database for pregens? | mr2peak | 1986 - 2007 Ninja 250R Tech Talk | 3 | May 5th, 2014 09:02 AM |
APE Cam chain tensioner fit Pregens? | quarterliter | 1986 - 2007 Ninja 250R Tech Talk | 2 | August 4th, 2013 09:02 AM |
Custom Fairings for pregens? | CalvinAmI | 1986 - 2007 Ninja 250R Farkles | 10 | June 10th, 2013 08:22 PM |
Fair Prices For 2005 pregens | etiainen | General Motorcycling Discussion | 16 | March 23rd, 2012 07:06 PM |
Anyone ever hear of, have or find any pics of a rear tire hugger for our pregens? | Grn99Kawi | 1986 - 2007 Ninja 250R Farkles | 9 | September 5th, 2009 08:58 PM |
