June 29th, 2009, 10:33 AM | #1 |
Join Date: Jun 2009 Motorcycle(s): 08 Ninja 250 Posts: 16
Emissions
I've searched all over the internet and found nothing, so maybe you guys can help. Do motorcycles undergo emissions testing, and more specifically in PA? Anyone living in PA have any problems with this? Area P said the exhaust would fail if they do test it so I'm just wondering if I'll need to keep the OEM system so it can pass.
June 29th, 2009, 10:48 AM | #2 |
Join Date: Jan 2009 Motorcycle(s): 05 GSX-R 600 2003 EX250: Woodcraft Bars, Levers, Mirrors, Shim'd Mixture, Synthetic, '08 Rear Shock Posts: A lot.
Remember when sex was safe and motorcycles were dangerous? |
June 29th, 2009, 11:24 AM | #3 |
I fail at google
June 29th, 2009, 11:42 AM | #4 |
no worries we're not grading you on this one
find anything useful?
June 29th, 2009, 12:04 PM | #5 |
Yea motorcycles are exempt Now I just gotta worry about them being anal about the fender chop, but I already called the guy up where I usually take it and he said as long as it doesn't look butchered the reflectors are really small anyway. Good stuff.
June 29th, 2009, 12:11 PM | #6 |
got a pic of your bike? if it isnt posted, can i have a look?
June 29th, 2009, 12:22 PM | #7 |
It's kind of hard to see it cause it blends in with my dad's vulcan.. i just took a dremel to it |
June 29th, 2009, 12:30 PM | #8 |
thanx for the view!
tail mod looks good from what i can see! can understand your concerns though. think you'll be fine. you taking it in for...? safety check?
June 29th, 2009, 01:56 PM | #9 |
Yea it's not do for awhile though. Looking through the inspection code it says reject if the rear fender has been removed, but i didn't remove it, just chopped it, so I don't expect problems. a fender eliminator kit would be tougher to push through tho
June 29th, 2009, 02:18 PM | #10 |
ah i see. don't know how expensive those rear wheel 'hugger' type fenders are, but if there were any concerns you think one of those would pass inspection? good on ya for looking into that with time to spare.
June 29th, 2009, 03:07 PM | #11 |
Ryley, you can also use reflective tape as a replacement for the reflectors if they're going to be anal about it. If you need it, I can give you the section of federal code that states this.
CA Emissions removal | Olie | 2008 - 2012 Ninja 250R Tech Talk | 19 | April 30th, 2014 10:39 PM |
CA Emissions? | sledneckrider | General Motorcycling Discussion | 4 | May 15th, 2011 11:43 AM |
California Emissions Removal | SdSy675 | 2008 - 2012 Ninja 250R Tech Talk | 1 | April 19th, 2011 12:27 PM |
emissions question | joyinc | General Motorcycling Discussion | 75 | June 7th, 2010 08:52 PM |
California Emissions? | jump | General Motorcycling Discussion | 3 | October 25th, 2009 10:41 AM |
