August 13th, 2013, 12:41 PM | #1 |
Join Date: Jan 2013 Motorcycle(s): 1987 Ninja 250 custom gold Posts: 218
larger sprocket more links?
Hi all,
My chain is making a horrendous noise under acceleration, so its time for a change... I wanted to up the pinion (front sprocket) from a 14 tooth to a 15 tooth, but am wondering is i will need more links in the new chain or will the rear wheel adjustment cover the slack? In regards to the chain, I was told to get a solid chain (no master links), but i can't seem to find one for a reasonable price. How will this do? (Can't tell what type of link this is?) http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER How is bikemaster for chains, cheap quality? Can someone recommend the least expensive chain from amazon that i can get a rivet link or solid chain (no master links)? Thanks, Phil. |
August 13th, 2013, 01:29 PM | #2 |
Join Date: Sep 2012 Motorcycle(s): '06 Ninja 250, 2018 Honda GL1800B Posts: 315
You won't need more links than stock (which is 106, rather than 104, on my '06). The RK SO chain is good, but it doesn't come with a riveted master link, so you'll have to buy one (and the riveting tool) separately.
I got an RK 520-20-106 chain for $46, a link for $6.20 and a tool for $50 ("Pit Posse" brand - works fine). I did the whole project, including a new rear sprocket (stock size) in about a half hour. I saved time by cutting off the old chain with a Dremel cutting wheel. |
August 13th, 2013, 02:01 PM | #3 | |
The EX250-E series have 104 links. Where did you get your chain and sprokets from, that seems like a great price! I currently have a clip type master link, so i won't have a problem getting it off. |
August 13th, 2013, 02:04 PM | #4 |
I got all the parts from Amazon. They have several sellers offering RK o-ring chains, as well as Renthal chains.
August 13th, 2013, 02:18 PM | #5 |
Join Date: Jun 2013 Motorcycle(s): 2006 Kawasaki EX250(Bright Yellow) Posts: 441
Here's some useful info on chains, sprockets, gearing:
http://faq.ninja250.org/wiki/I_want_...nge_my_gearing http://faq.ninja250.org/wiki/What_re..._I_consider%3F |
larger front rotor?? | caltony | 1986 - 2007 Ninja 250R Tech Talk | 18 | March 29th, 2014 08:15 PM |
JT Sprocket 42 tooth Rear Sprocket | lolibater | Motorcycle-related | 36 | February 25th, 2013 12:30 PM |
How many links do I reduce my chain if adding 15t front sprocket, stock rear? | novak2k9 | 2008 - 2012 Ninja 250R Tech Talk | 2 | February 11th, 2013 02:25 AM |
New tire - larger? | shane_colton | 2008 - 2012 Ninja 250R Tech Talk | 7 | January 23rd, 2010 08:15 PM |
