Old March 20th, 2013, 08:39 PM   #1
walty87
walty87's Avatar
Motorcycle(s): 2012 ninja 250
Chain issue
So after 12k miles it seems like my chain is done. It has tension in certain spots when I'm rotating the wheel (off the ground). Some parts on the chain it's really loose, and then when I rotate the wheel 1/4 of a turn the chain is super tight. I'm assuming my chain is doneskies.
That being said I'm in the market for a new chain. I think i've read that i might as well just get new sprockets as well?
I'm super lazy does anyone mind telling me what size sprockets and chain a 12' ninja 250 would take?
Thanks
walty87 is offline   Reply With Quote
Old March 20th, 2013, 08:47 PM   #2
msebastian
msebastian's Avatar
Motorcycle(s): 2009 Ninja 250R SE
Stock sprockets are 14/45 and make sure you get a OEM or D.I.D. chain. If you want to get a little more out of the bike (especially first gear) you can go with a 15T front and your choice of rear sprockets. I went with a 15/42 set up on my bike. I have yet to ride it with this set up. Check this for any further questions and diagrams.
http://www.ninjette.org/forums/showthread.php?t=10273
msebastian is offline   Reply With Quote
Old March 20th, 2013, 09:55 PM   #3
menikmati
crash 250, get supersport
Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ
Chain needs to be 520 pitch with 106 links. Stock gearing is 14T front 45T rear and will run you about $45 for a set of JT sprockets.
menikmati is offline   Reply With Quote
Old March 20th, 2013, 11:21 PM   #4
walty87
walty87's Avatar
15t front sprocket would increase top speed or no?
Old March 20th, 2013, 11:23 PM   #5
menikmati
Lowers revs at any given gear, makes 1st more useful. Top speed, doubt it.
Old March 21st, 2013, 04:00 AM   #6
msebastian
msebastian's Avatar
Play around with this until you achieve the gearing you are happy with: http://www.gearingcommander.com/
Old March 21st, 2013, 10:53 AM   #7
Bones85
Check out these:
RK 520 XSO RX-Ring Chain 106 Links 520XSO106
JT Sprockets JTR486.45 45T Steel Rear Sprocket
JT Sprockets JTF516.15 15T Steel Front Sprocket
JT Sprockets JTF569.14 14T Steel Front Sprocket
Bones85 is offline   Reply With Quote
Old March 21st, 2013, 10:57 AM   #8
menikmati
These are the exact same chain/sprockets that I use.
Old March 21st, 2013, 11:02 AM   #9
Bones85
How do you like them so far and how long do you think the chain will last? My chain and sprockets are all stock but I was thinking of buying those when mine wear out.
Old March 21st, 2013, 11:08 AM   #10
menikmati
No problems, I've had my set for the last 8k miles and my chain/sprockets look fine. I lube my chain every 400 miles and clean it when it gets really gritty/grimey but that's only every 4k miles or so. Not sure how long I can expect them to last, probably 25k+ or more at this rate for the chain.
Old March 26th, 2013, 06:16 AM   #11
Vintage Smoke
The 2 Stroke Ninja!!
Vintage Smoke's Avatar
Motorcycle(s): 2010 250R, 1977 RD400, 72&73 RD350 75 RD200
All chains (and even belts) will always have tight and loose spots....even a brand new chain. Sometimes it is almost unnoticeable and sometimes it is very obvious. When adjusting a chain it is always best to find the tightest spot and adjust it there . If you adjust it at the loosest spot it will be too tight when it rolls around to the tightest spot.
From the way you describe just how big the difference is between the tight and loose spots it does sound like the chain is worn. There are better ways to gauge this though. Generally a chain is worn if:
- You run out of adjustment. Removing a link is NOT an acceptable way to get more adjustment out of the chain. This doesn't apply to asll bikes since every bike will have a different amount of travel in the adjusters.
- On the rear sprocket, at about the 3 o'clock position, if you can pull the chain off of the sprocket far enough to see light the chain is getting worn. If you can see enough light to pass something that is the same diameter as one of the pins on the chain through it is done.
- Look at the shape of the teeth on the sprockets. Teeth on a new sprocket will bow out and look almost like this: (). If they look like this )( they are worn. If the teeth are hook shaped it is REALLY worn and probably should have been replaced a long time ago. Here are some pics of worn sprockets:
- Worn compared to new:
http://www.google.com/imgres?imgurl=...QEwAw&dur=7766
This one is even better:http://www.google.com/imgres?imgurl=...AwBw&iact=ricl
You should ALWAYS change chain and sprockets as a set. A worn chain will quickly wear out new sprockets and vice versa.
Vintage Smoke is offline   Reply With Quote
Swapped chain, now have rear brake issue Sirref 2013 - 2017 Ninja 300 Tech Talk 22 October 23rd, 2014 09:44 PM
chain issue LNasty 2008 - 2012 Ninja 250R Tech Talk 3 June 16th, 2013 08:13 PM
issue tightening chain az3200 1986 - 2007 Ninja 250R Tech Talk 23 December 21st, 2012 10:13 PM
[webbikeworld.com] - Chain Pickle Motorcycle Chain Cleaner and Degreaser Review Ninjette Newsbot Motorcycling News 0 April 1st, 2011 04:22 AM
New 15t sprocket/chain alignment issue. headshrink 2008 - 2012 Ninja 250R Tech Talk 46 February 17th, 2011 01:45 PM
