Old June 7th, 2017, 05:05 PM   #1
Thatdudeguybro
Motorcycle(s): 2005 250r, 2005 CBR600RR Race Bike
Permanent Removal of Passenger Footpegs
Hey all,
The fastener holes that the right passenger footrest attaches to are broken off of the frame. The frame itself is A-OK, but this is causing issues for the exhaust clamp, as that originally connects to the footrest.
I have never (and likely will never) had a passenger on my 250, so I don't even need the passenger footrests. Anyone have a solution for mounting the exhaust clamp on a bike without the passenger footrest? What's your suggestion? Any track day peeps out there that have done this for weight reduction?
Honestly, I'd get them welded, but I really don't want to have to take the bike apart as welding with everything on would fry all of the electronics, most likely.
Thanks!
Thatdudeguybro is offline   Reply With Quote
Old June 7th, 2017, 05:10 PM   #2
Bolt a strap that wraps around muffler to peg mounting-hole.
Old June 7th, 2017, 05:33 PM   #3
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
Originally Posted by Thatdudeguybro View Post
honestly, I'd get them welded, but I really don't want to have to take the bike apart as welding with everything on would fry all of the electronics, most likely.
I've welded on cars and motorcycles lots of times without unhooking anything, I do make sure to put the ground onto a good ground on the piece to be welded, as close to the spot to be welded as I can get it. Make sure your grounding on bare metal. Paint or rust do not make a good ground! In fact I have welded exactly those mounting points back on.
Old June 9th, 2017, 11:18 PM   #4
Here's a bracket you can make from a piece of bar-stock from Home Depot.
Last futzed with by DannoXYZ; July 1st, 2017 at 12:12 AM.
Old June 9th, 2017, 11:22 PM   #5
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
I don't have passenger pegs
Old June 10th, 2017, 05:15 AM   #6
empire00
empire00's Avatar
Motorcycle(s): 2009 250r SE, 2015 FJ-09
Since he doesn't have the mounting tab for the bracket this would need to be modified. Buy a longer piece of bar stock and go up past the subframe rail. then use a U-bolt and drill two holes through your new bracket.
empire00 is offline   Reply With Quote
Old June 10th, 2017, 02:03 PM   #7
You can also get rack mounts eyelets for panniers from bicycle shops. These come in various diameters, 1", 1-1/8", 1-1/4", etc. sizes.
Heavier-duty versions for 50-lb bags are available too, but is overkill for a muffler.
Old June 10th, 2017, 08:02 PM   #8
empire00
empire00's Avatar
Good find. Would have never thought about that.
[visordown.com] - Troy Bayliss announces permanent retirement Ninjette Newsbot Motorcycling News 0 March 23rd, 2015 09:00 AM
[visordown.com] - Bayliss announces permanent retirement Ninjette Newsbot Motorcycling News 0 March 23rd, 2015 03:00 AM
[visordown.com] - BMW permanent erection claim tossed out Ninjette Newsbot Motorcycling News 0 March 19th, 2014 09:10 AM
WTB: Rear passenger footpegs for a pre-gen 84blue Items Wanted 1 April 13th, 2012 08:44 PM
Airbox removal + Kleen air removal? MikeBudd 2008 - 2012 Ninja 250R Tech Talk 6 February 16th, 2012 04:57 PM
