June 8th, 2017, 08:14 PM | #1 |
Join Date: Nov 2015 Motorcycle(s): 2009 Ninja 250 Posts: 386
Question about chain slack for a track bike
so I have just put on a new 520 O-ring chain with 1 track days worth of wear on it.
I am going to a smaller track saturday and wanted to go from a 45T to 47T rear sprocket. After I put the 47T on, without tightening the axle I get 20mm of slack. So my question is this. I can get a new chain from amazon tomorrow, and get a 120 link and use my chain breaker to shrink it. What should I shoot for? 108 links? Thanks! |
June 9th, 2017, 08:17 AM | #2 | |
MOTM - Mar '13, Jun '14
June 9th, 2017, 08:23 AM | #3 |
Or figure out ratios that always swap a smaller front and larger rear, keeping the chain adjustment within range.
June 9th, 2017, 11:56 AM | #4 |
June 9th, 2017, 12:08 PM | #5 |
Not terrible, but I'd rather not have to deal with rivets or master links with each ratio change. It's entirely possible though, that you can change a tooth up or down and not have to change chain length.
Chain Slack | jeffb502 | 2008 - 2012 Ninja 250R Tech Talk | 11 | December 3rd, 2013 10:02 AM |
chain slack | eddiekay | 2008 - 2012 Ninja 250R Tech Talk | 8 | October 18th, 2011 05:40 PM |
Does my chain slack need adjusting? | kobachi | 2008 - 2012 Ninja 250R Tech Talk | 34 | July 16th, 2011 07:07 AM |
Chain Slack Tool? | ScorpionNinja | 2008 - 2012 Ninja 250R Tech Talk | 11 | October 24th, 2010 11:53 PM |
Chain Slack? | Xuracing | 2008 - 2012 Ninja 250R Tech Talk | 2 | June 9th, 2009 09:21 AM |
