Old June 13th, 2017, 08:31 PM   #1
skip
skip's Avatar
Motorcycle(s): 2009 250r
need useful tips
Clean carb no air leaks. Good plugs . bike running crappy idling really low. Anybody have any clue what could be causing the issue don't want to get ripped off at a shop for a diagnosis $200 an hour is crazy. Any help would be appreciated.
skip is offline   Reply With Quote
Old June 13th, 2017, 08:44 PM   #2
Valves out of adjustment?
Old June 13th, 2017, 09:40 PM   #3
skip
skip's Avatar
You know any symptoms of valve adjustment needed it has 42000 miles on it. And is it difficult to do my self or do I need a shop to do it
Old June 14th, 2017, 04:06 AM   #4
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
Have you fiddled with the idle adjuster? Little black knob on the left side. Might have gotten out of whack during maintenance.
Old June 14th, 2017, 06:13 AM   #5
Did you remove the caps from the idle mixture screws, clean the passages, check the o-rings, and set the screws to 2.5 turns out?
Once that's done and the engine is warm, set the idle speed to 1300 and sync the carbs.
If it won't run well after that, it could need additional carb work or other work like valve adjustment.
Valve adjustment info - https://faq.ninja250.org/wiki/How_do..._the_valves%3F
Old June 14th, 2017, 06:46 AM   #6
Mine was finicky to start and didn't want to idle without extra throttle when it was cold. It took several miles to behave itself, and when fully warm it was OK. After I adjusted the valves, it started much easier, and will idle at a stable speed very soon after starting.
Certainly if your problem is just a very slow idle when cold or hot, turn the idle speed knob a little and adjust it.
Is there any motocross tips out there? davidjones82 General Motorcycling Discussion 8 May 18th, 2013 07:10 AM
Tips on Using Craigslist? Minikin_Jo Off-Topic 12 August 3rd, 2012 09:09 PM
Some tips please sze5003 Riding Skills 18 July 10th, 2012 10:48 AM
New rider tips? K-rod Riding Skills 11 April 15th, 2012 08:02 AM
Tips for two up? crankinaway Riding Skills 4 June 20th, 2010 11:48 AM
