#1 |
Join Date: Jul 2013 Motorcycle(s): 2012 ninja 250r Posts: 49
valve inspection
So I'm going to do an inspection o I need to replace the valve cover gasket or do y'all use the same one
#2 |
dirty boy
MOTM - Apr '14
the valve cover has a rubber gasket that is reusable, some people like to put a little sealer in some of the areas. YMMV
I love the smell of burning pre-mix in the morning I don't think I'm a lot dumber than you thought that I think that I thought I was once. ![]() |
#3 |
What's about the spark plug gaskets
300 air switching valve and purge valve (CAL) removal | joyspring | 2013 - 2017 Ninja 300 Tech Talk | 21 | February 13th, 2017 01:36 PM |
Should I do the valve clearance inspection myself? | nickjpass | The Ex-Ninjetters Lair | 13 | June 13th, 2014 12:50 AM |
Did I just grenade my motor by going 1k over on the valve inspection? | bowlingballhead | 2008 - 2012 Ninja 250R Tech Talk | 21 | July 11th, 2013 08:17 AM |
Dropped bike off for valve adj. v. New valve stems? | edxmon | 2008 - 2012 Ninja 250R Tech Talk | 14 | July 17th, 2012 04:55 PM |
inspection | tinng321 | General Motorcycling Discussion | 10 | April 14th, 2009 11:04 AM |
