April 23rd, 2009, 05:47 PM | #1 |
Blue Blue Blue
Join Date: Mar 2009 Motorcycle(s): 2008 Candy Plasma Blue Ninja 250R Posts: 97
Crooked handle bars
Ok some more post crash questions/headaches...i was riding around...and i looked down and it appeared as if my handle bars were slightly crooked...it as if i would be taking a very slight slow speed turn to the right...but i dont know if it is just a trick of the eyes or what...do your bars appear to be lower on the right end? or...i know you can align the rear wheel...is it possible to align the front?
April 23rd, 2009, 06:00 PM | #2 |
Blue Blue Blue
actually i just realized this thread is worthless without pics...all post one tommorrow
April 23rd, 2009, 06:03 PM | #3 |
forks are most likely twisted in the triple tree. very easy to fix if nothing is actually bent.
April 23rd, 2009, 07:54 PM | #4 |
Blue Blue Blue
how would i untwist them? undo them like was lowering the bars? then just turn them?
April 23rd, 2009, 08:17 PM | #5 |
exactly. loosen the bolts that hold the forks to the triple tree, then find a solid object (wall, concrete footing, etc) and whack the tire against it by quickly turning the handlebars in the opposite direction of the twist.
when everything is straight, tighten the bolts back up. be careful when whacking the tire against the wall to not ding the wheel. |
April 23rd, 2009, 08:19 PM | #6 |
Join Date: Jan 2009 Motorcycle(s): 05 GSX-R 600 2003 EX250: Woodcraft Bars, Levers, Mirrors, Shim'd Mixture, Synthetic, '08 Rear Shock Posts: A lot.
...i think that part is highlighted in the manual...
Remember when sex was safe and motorcycles were dangerous? |
April 23rd, 2009, 08:21 PM | #7 |
Blue Blue Blue
awsome ill give that a try tommorrow
April 23rd, 2009, 08:26 PM | #8 |
I use this method to straighten the dirt bike forks. Crash a lot in the dirt and forks get tweaked all the time. You don't even have to loosen up the bolts with the dirtbike. In the trails we use the nearest rock or tree.
the 250R may be a bit harder to straighten out. If my method doesn't work, you'll need to take the front fender off, take off the metal brace they have under there, then try straightening it out using this method. gl... let me know if it works. |
April 24th, 2009, 09:26 AM | #9 |
Happened to me on my 250R. I did the same thing that Kelly suggested, its an old dirt bike remedy lol. Whacked the front tire against a wall, problem solved.
April 24th, 2009, 09:32 AM | #10 |
bikeless n00b
Join Date: Apr 2009 Motorcycle(s): None yet. My dream machine is a BLUE 250R. Posts: 91
*files in brain for future reference* Just gotta say, the signal-to-noise ratio on this forum is awesome. By the time I get my bike, I'll be ready to roll! Thanks y'all!
( Now, why doesn't whacking it against the wall fix a computer? I guess I shouldn't complain, or I'd be out of a job! ) |
April 24th, 2009, 09:35 AM | #11 |
April 26th, 2009, 04:54 PM | #12 |
Blue Blue Blue
Fixed!...hope i didnt break anything.........haha guess ill find out =p
I think my handle bars are too high | Bob2010 | 2008 - 2012 Ninja 250R Farkles | 7 | May 2nd, 2013 08:25 AM |
Bowed Handle Bars | nitehawk | 2008 - 2012 Ninja 250R Tech Talk | 6 | March 27th, 2013 09:38 AM |
Lower handle bars.....?? | LittleRedNinjette | General Motorcycling Discussion | 13 | March 15th, 2013 06:41 AM |
oem 08+ handle bars | NHrider19 | Motorcycle-related | 0 | July 17th, 2012 06:52 PM |
Bent handle bars | cuong-nutz | 1986 - 2007 Ninja 250R Tech Talk | 12 | July 1st, 2011 11:01 PM |
