March 21st, 2023, 02:03 PM | #1 |
[ridermagazine.com] - 2024 Triumph Street Triple 765 R/RS | First Ride Review*
The updated and upgraded Triumph Street Triple 765 hits a sweet spot in the sporty motorcycle market. It’s comfortable enough for commuting and light-duty touring, cool enough to hold its head high at bike nights, and fast enough for scorching trackdays. With prices starting at $9,995, it offers undeniable value for a sporting naked streetbike. […]
The post 2024 Triumph Street Triple 765 R/RS | First Ride Review* first appeared on Rider Magazine. Hunting for apexes at Circuito de Jerez in Spain. (Photos by Kingdom Creative) The updated and upgraded Triumph Street Triple 765 hits a sweet spot in the sporty motorcycle market. It’s comfortable enough for commuting and light-duty touring, cool enough to hold its head high at bike nights, and fast enough for scorching trackdays. With prices starting at $9,995, it offers undeniable value for a sporting naked streetbike. The Street Triple has been one of our favorite sports roadsters since its 2007 inception as an offshoot of the 675cc Daytona. Surprisingly lively and always playful, it was like a more exotic and more stimulating Suzuki SV650, another longtime fave that punches above its weight. The Street Triple R (left) retails for $9,995, while the RS version (right) demands a $2,600 premium. The Street Triple 765 arrived in 2017 with a power-to-weight ratio that would humble the original 885cc Speed Triple, the Street’s older brother and one of the godfathers of the naked sportbike genre. The revised Street Triple was a bigger, more capable machine that came in three variants: S, R, and RS, with outputs ranging from 111 hp to 121 hp. Related: 2017 Triumph Street Triple RS | First Ride Review Triumph launched its first Street Triple 765 in southern Spain, so it was fitting that we were invited back to Spain to sample the new version on Andalusian roads and the famous Jerez racetrack. Triumph Street Triple 765 Revamped The Street Triple remained entirely composed at the racetrack thanks to class-leading electronics and an excellent chassis. Categorized in the U.S. as a 2024 model, the Street Triple gets an extensive overhaul this year. It enjoys many welcome upgrades and is available in three versions. Along with the R and RS we tested, Triumph is offering a special Moto2 Edition to celebrate its involvement as the engine supplier in MotoGP’s junior category since 2019. It’s basically an RS but with clip-on handlebars, carbon bodywork, and an Öhlins fork, and it’s limited to 765 units for each of its two colorways. Retailing for $15,395, as of press time it’s sold out in most global markets but is still available in America. 2024 Triumph Street Triple 765 Moto2 in Crystal White with Triumph Racing Yellow rear subframe Related: 2024 Triumph Street Triple 765 Range | First Look Review Triumph reps boasted about how they took lessons learned in the Moto2 program and applied them to the streetbike. The bore and stroke of the inline-Triple remain unchanged, but most internals have been changed, including pistons, con-rods, camshafts, and valves. The piston crowns and combustion chamber are now fully machined for optimal flow and combustion, combining for a higher 13.25:1 compression ratio. The intake uses trumpets that are 20mm shorter for a stronger pull up top, and the exhaust now has just one catalyzer instead of two. The Street Triple proved to be a willing accomplice on unfamiliar Spanish backroads. The result, according to Triumph, is an increase in power from the midrange on up. The R version claims 118 hp that arrives at 11,500 rpm, 500 revs earlier than the previous motor’s 116 ponies. The higher-spec RS variant delivers 128 hp at 12,000 rpm, a jump of 7 hp from the previous model. Torque on all models is bumped by 4% to a creditable 59 lb-ft. New to the Street Triple is the addition of an IMU that enables precise traction-control modulation and cornering ABS. Also coming standard and cued to the IMU is one of the most seamless up/down quickshifters we’ve sampled, which uses a pressure-sensitive actuator rather than a basic switch. The RS includes bar-end mirrors instead of the R’s more traditional mirrors atop the handlebar. Styling remains similar but freshened, with a new, sharply creased fuel tank with integrated side panels and a stubby new stainless-steel muffler tucked in next to the gullwing aluminum swingarm. The distinctive dual headlights with LED eyebrows are topped with a mini wind deflector that’s more integrated than on previous models. Scrolling LED turnsignals are a nice upmarket touch. The chassis remains the same but tweaks to ride heights have modestly sharpened the steering geometry to aid agility. A shuffling of transmission and final-drive ratios has slightly shortened up the overall gearing for snappier engine responses. Related: Triumph Announces New Colors, Names for Select 2023 Models Is R Enough? Tall mirrors identify this Street Triple as an R version. The R version of the Street Triple makes a good case for saving money over its pricier RS brother. It very well could be the most appealing sub-$10,000 sporty bike on the market. The Street Triple’s new exhaust is more plainly visible without the chin fairing of the RS. It would be unfair to cast the R as a “budget bike,” as it includes a plethora of desirable features. An aluminum frame helps keep weight to a tidy 417 lb wet, fully adjustable Showa suspension can be dialed in to personal preferences, and a Brembo brake package with radial-mount monoblock calipers provides secure speed bleeding through braided steel lines. Tire valves directed to the sides are another pleasing accoutrement. Ergonomics are pleasantly familiar, placing a rider in a modestly leaned-over forward cant and now with a half-inch wider handlebar to aid agility. Long-legged riders may feel a bit cramped because of the high footpeg position that supplies a generous amount of lean angle before they begin dragging. The seat is reasonably comfortable and roomy, but short riders will whine about the 32.5-inch seat height. A lower accessory seat reduces height by 1 inch. The Street Triple R, priced at $10K, is an undeniable value. Note the mirror positioning compared to the RS. GEAR UP
The star of the Street Triple show is its compact three-cylinder engine that emits some of the most pleasing sounds ever trumpeted by a motorcycle – a mix of inline-Four scream tempered by a hint of twin-cylinder thrum. In addition to being delightfully sonorous and pleasingly smooth, it’s blessed with a wide swell of power that can easily carry a higher gear than typically optimum yet lunges for horizons with a howling top-end climax. Torque peaks at 5,500 rpm, which is below the halfway point of its rev range. The Street Triple R has everything you need for an entertaining streetbike – except wind protection. New throttle maps for the three ride modes (Rain, Road, and Sport) are finely tuned to deliver precise and user-friendly throttle responses. Traction and wheelie control settings are tied into each ride mode. The “Rider” mode can be tailored to personal preferences. A slip-assist clutch eases lever effort and sloppy downshifts. Related: 2023 Triumph Rocket 3 R | Road Test Review Handling is another Street Triple strong point, now with minimally less rake and trail. It quickly bends into corners and provides confidence-inspiring feedback. The suspensions of the bikes on our street ride were set up to be compliant on the damp and occasionally bumpy Spanish backroads, but preload and damping (both compression and rebound) can be dialed up to suit rider weights and inclinations. The Street Triple R is classy, thrilling, and capable. The RS version has higher-end brake components, but there’s nothing wrong with the R’s for street usage. Brembo M4.32 calipers bite on 310mm rotors up front and provide strong power and the security of cornering ABS. The brake lever next to the Nissin axial master cylinder has a wide adjustment range to suit hands of all sizes. Application of the front brake subtly engages the rear brake to help settle the chassis during corner entries, but it’s entirely seamless and can be disabled in Rider mode settings. Story continues below 2024 Triumph Street Triple 765 R photo gallery 2024 Triumph Street Triple 765 RS On the Track The Street Triple demonstrated its sporting prowess at the Circuito de Jerez MotoGP track. The RS version of the Street Triple includes everything good about the R and dials it up to a more premium and slightly faster experience. Stylewise, you’ll notice the addition of a chin fairing, a cowl on the passenger seat, and a stitched seat. The RS also includes a deflector in front of the rear sprocket to prevent errant items or digits from entering, an item unappreciated until it’s needed. Ask me how I know. New engine internals help bring output to a claimed 128 hp on the Street Triple RS. Also new the muffler, now with a single catalyzer instead of a pair of them. The RS’s cockpit is graced by TFT instrumentation that includes a lap-timer function, along with more comprehensive switch cubes. Unlike the R, the RS can be fitted with cruise control as an option. Heated grips are another option, which were gratefully fitted to the bikes on our chilly street ride. Bar-end mirrors replace the ones mounted atop the handlebar on the R. Knee down but not dragging footpegs demonstrates the cornering clearance of the Street Triple. While engine internals are unchanged from the R, different ECU settings endow it with 10 extra ponies at its top end, to 128 hp at 12,000 rpm. A higher-end Showa fork damps bumps up front, while an Öhlins shock does duty out back. Sticky Pirelli SuperCorsas replace the R’s ContiRoad rubber. Riding a naked sportbike on a MotoGP racetrack seemed incongruous before I arrived at Circuito de Jerez, but that proved not to be the case. The Street Triple RS was fully capable of cutting quick laps, suffering only a lack of wind protection while traveling at speeds reaching 140 mph at the end of the back straightaway. Following the tire tracks of MotoGP riders at Circuito de Jerez was a rare treat on a streetbike. The RS adds a Track setting to the R’s ride modes, which disables the linked brakes and cornering ABS for a purer riding experience. Track mode also ups the limits of traction control, wheelie control, and ABS interventions. Kudos to Triumph for enabling high limits for the electronic nannies on track. Unlike some systems that intervene too early when riding aggressively, I wasn’t tempted to disable any of the RS’s safety nets. The TC indicator lamp frequently flashed on the TFT, but intervention was so smooth that I mostly wouldn’t have otherwise noticed it. The Street Triple proves you don’t need a faired sportbike to cut quick laps on track. The bike’s handling prowess is enhanced by sharper steering geometry due to a slightly taller rear ride height, tightening the rake angle to 23.2 degrees from the R’s 23.7 with a marginal decrease in trail. The bike proves to be agile but without any hint of instability, even when the front tire is dancing just above the tarmac during acceleration events out of lower-speed corners. It’s notable that no steering damper is fitted and isn’t needed. Tucked in and blasting through the air to 140-mph speeds at the Jerez racetrack. GEAR UP
The hills are alive with the sound of music from the Street Triple’s sonorous three-cylinder engine. The RS proved to be far more worthy of racetrack exploration than I had imagined. Its versatile and punchy motor allowed a choice of gears in corners, so it could be tractored out smartly or revved out until it screamed. Throttle modulation is excellent, and its quickshifter is a wonderful aid on track. Cornering clearance is bountiful, so you’ll need to be a bit of a track hero to drag its pegs. Story continues below 2024 Triumph Street Triple 765 R photo gallery What’s Not to Like About the Triumph Street Triple 765? A sign of motorcycle excellence is when a reviewer must search for things to complain about, and that’s the case here. Really tall or really short riders might complain about the rider triangle layout, but it fit me well – I’d be comfortable enough to use it for light-duty touring and tolerate the wind blast or find a fashionable windscreen. We know it’s a superb bike when my biggest complaint is that I couldn’t clearly see the shift lights while revving the bike out at the track. Unless you’re cutting hot laps at a racetrack, this is a complete non-issue. A larger fuel tank would be nice, but a 150-mile range isn’t a deal-breaker. See all of Rider‘s Triumph Motorcycle coverage here. The combination of a sonorous and thrilling motor, low weight, admirable electronics, and a playful character places the Street Triple near the top of my most desirable streetbikes. It’s more debonair than the 3-cylinder Yamahas (MT-09, XSR900) and will blow away a KTM 790 Duke. Just as thrilling and likely a bit more agile is the 890 Duke R, but the KTM retails up at $12,949 and lacks the Triumph’s soul-stirring soundtrack. Which brings me back to the Street Triple R. It’s astonishing that a semi-exotic and highly refined motorcycle with such outsized performance capabilities can be had for less than $10K. At a $2,600 saving over the admittedly cooler RS, I’d say it’s one of the best values in motorcycling. Along with the chin fairing, the RS version of the Street Triple includes a seat cowl for a sportier appearance. 2024 Triumph Street Triple 765 R / RS Specs
[motorcycle.com] - 2024 Triumph Street Triple 765 R/RS – Video Review | Ninjette Newsbot | Motorcycling News | 0 | March 15th, 2023 10:29 AM |
[cycleworld.com] - First Ride: 2024 Triumph Street Triple 765 | Ninjette Newsbot | Motorcycling News | 0 | March 3rd, 2023 03:15 PM |
[motorcycle.com] - 2024 Triumph Street Triple 765 R/RS Review – First Ride | Ninjette Newsbot | Motorcycling News | 0 | March 3rd, 2023 02:19 PM |
[ridermagazine.com] - 2024 Triumph Street Triple 765 Range | First Look Review | Ninjette Newsbot | Motorcycling News | 0 | November 3rd, 2022 10:41 AM |
[visordown.com] - First ride: Triumph 765 Street Triple RS review | Ninjette Newsbot | Motorcycling News | 0 | February 15th, 2017 07:51 AM |
