April 2nd, 2014, 01:23 PM | #1 |
Join Date: Apr 2013 Motorcycle(s): 2005 Ninja 250, 2006 SV650N Posts: 642
Brake caliper rebuild help
Okay so I am having trouble getting the larger piston out of the brake caliper. The small one pops out just fine but the larger one will get about half way and stop. I've already put the small one back in and put in some more brake fluid because I think they need to come out at the same time. I'd take some pliers to it but I don't want to damage it. I've tried holding the small piston in to get more pressure behind the larger piston but no go. At least this explains the binding I was having.
Edit: Nevermind got them both out and cleaned everything. Still getting weird sound at slow speed from the front which is what I was trying to fix. Brakes work well though. Swapping the brake disc out tomorrow. So bummed right now. Last futzed with by agentbad; April 2nd, 2014 at 05:12 PM. |
April 3rd, 2014, 02:45 PM | #2 |
Okay sorry to bump my own thread but as it turns out it's not my front brakes making the noise at all but my chain. It seems my chain is not in the best shape in the cush drive may need some love to. I had to roll down the street without my helmet on to really hear it and hit the kill switch. Feel like jackass but it's nice to finally know where it's coming from.
April 4th, 2014, 05:12 PM | #3 |
Join Date: May 2013 Motorcycle(s): '89 klr 650, '00 250r Posts: 177
if your cheap you can just throw some inner tube bits to shim up the cush drive. 2005 is almost 10 years old but my 01 cush drive isn't super bad. i would get a grunge brush, clean the chain and oil it and see what happens first.
the more specific question is what kind of noise are you hearing? |
April 6th, 2014, 10:24 AM | #4 | |
Rear Brake Caliper Rebuild | aurbz | 2008 - 2012 Ninja 250R Tech Talk | 6 | April 5th, 2015 10:57 AM |
Where to buy brake piston rebuild kit? | agentbad | 1986 - 2007 Ninja 250R Tech Talk | 4 | February 26th, 2014 01:42 PM |
2010 Ninja 250r Brake fluid bleed/Replacement and brake caliper cleaning | RandomPhantom | 2008 - 2012 Ninja 250R Tech Talk | 1 | May 30th, 2013 08:13 PM |
Caliper rebuild inquiry | Momaru | 2008 - 2012 Ninja 250R Tech Talk | 12 | January 13th, 2013 08:31 AM |
Brake caliper pistons | JamesNZ | 2008 - 2012 Ninja 250R Tech Talk | 19 | January 22nd, 2012 09:47 PM |
