June 13th, 2010, 08:49 AM | #1 |
Join Date: May 2010 Motorcycle(s): 2007 Ninja 250 Posts: 7
Oil Leaking after Valve Clearance Check
I had the dealership do a valve clearance check and now there is oil coming out from the alternator cover when I run the bike. It only takes about 2000rpm to make the oil leak. Any suggestions of what I might check?
June 13th, 2010, 09:10 AM | #2 | |
Frak It
Join Date: Dec 2008 Motorcycle(s): 2008 Ninja 250R Posts: 199
That is un-f'ing-acceptable. |
June 13th, 2010, 09:10 AM | #3 |
Did they put back the oil cap on the left side of the bike? Check your oil level with the bike standing straight. How much oil is leaking? Are there any bolts that appear loose?
Maybe give them a call and have them pick up your bike if there isn't enough oil in it. |
June 13th, 2010, 09:10 AM | #4 |
Yea, definitely still have the receipt, they're not open until Tuesday, and I need to ride all over the place today.
valve clearance | sharky nrk | 2008 - 2012 Ninja 250R Tech Talk | 8 | July 18th, 2014 06:19 AM |
Valve Clearance check | tsmith3605 | 2008 - 2012 Ninja 250R Tech Talk | 3 | July 26th, 2013 01:10 PM |
Coolant leaking into oil and oil leaking out of somewhere. | Monkeytofu | 1986 - 2007 Ninja 250R Tech Talk | 31 | May 25th, 2013 04:09 PM |
Valve clearance check confusion... | LoneRonin | 2008 - 2012 Ninja 250R Tech Talk | 3 | June 3rd, 2011 10:04 PM |
Valve clearance check/adjustment | Apex | 1986 - 2007 Ninja 250R Tech Talk | 6 | July 16th, 2009 06:49 PM |
