June 30th, 2010, 05:39 PM | #1 |
Join Date: Apr 2010 Motorcycle(s): Yahama v star 650 classic Posts: A lot.
What is this?
Saw this yesterday while working on the bike. Its in the tail. I tried searching. No luck though..
June 30th, 2010, 05:44 PM | #2 |
Join Date: May 2010 Motorcycle(s): 2009 Ninja 250r, 1996 Yahmaha YZ 125... Both in Blue the coolest color Posts: 285
Hmmm I have had my bike completely stripped down to put on my led's and to do my fender chop, I never seen that.
"Well you know, for me, the action IS the juice" |
June 30th, 2010, 05:51 PM | #3 |
Yeah, I never notice it nither. It was kind of hidden.
June 30th, 2010, 05:55 PM | #4 |
FORMER MOTORCYCLE RIDER
Join Date: Dec 2008 Motorcycle(s): Rode an 08 250r then rode an 08 ZX-6R until i totaled it on 7/10/10 Posts: 758
Looks like a battery tender connection
June 30th, 2010, 05:57 PM | #5 |
follow the line back and see where it's connected. On my bike I added that type plug as a recharging point for the battery when using a smart charger. I have the end of that plug connected to the + and - terminals of the battery. If someone else owned the bike before you, they might have used it for something different, so you need to find out where it's connected before plugging stuff into it.
that is not stock... someone added that. |
June 30th, 2010, 06:01 PM | #6 | |
I just followed it back. It in fact, goes to the battery. So I could hook stuff up to it? i.e phone charger? |
June 30th, 2010, 06:02 PM | #7 |
+1
I have one for my battery tender too. I also used one to may a DIY GPS power cord... I like to disconnect it when I am not using it (99% of the time). You must have bought your bike used? EDIT: Your post came through as I was typing.... I don't know why it is there. Were there REALLY zero miles on the bike? |
June 30th, 2010, 06:02 PM | #8 |
Join Date: Sep 2009 Motorcycle(s): 09 Ninja 250R SE Posts: 376
I have the exact same thing sticking out of my back seat, but I put it there on purpose. Mine is a lead that came with my battery tender jr.
It is connected to my battery and allows for a quick connection to the charger so that you can top off the battery or keep it charged if you will park the bike for a long time. Since yours is a 2010, as Kelly mentioned, most likely a previous owner did this. If so, then this wont be very useful to you without the actual charger. Here's the tender: http://www.amazon.com/Battery-Tender.../dp/B000CITK8S |
June 30th, 2010, 06:05 PM | #9 |
yes, it's a constant 12V source direct to the battery. whatever you hook up to it should have an inline fuse of some sort to protect it.
maybe the dealership installed it to keep their bikes charged and forgot to remove it when you bought it? If that's the case, don't worry about it, you've already paid for it many times over. you'll find it very handy to keep the battery charged, if you plan to store the bike over the winter. |
June 30th, 2010, 06:08 PM | #10 |
Well cool! I got somthing out of the deal! lol I will have to buy a charger now. Ohio winters can be burtal.
June 30th, 2010, 06:10 PM | #11 |
Join Date: Nov 2008 Motorcycle(s): Ninja 250R 2009 Posts: A lot.
To answer the question "What is this?" ....It is called an SAE connector.
June 30th, 2010, 06:16 PM | #12 |
I suggest the Regular Battery Tender (Battery Tender Plus), not the Jr. In the grand scheme of things, it isn't THAT much more $$, but I don't believe the Jr. has all the "smart" circuitry. If I am wrong about that, someone please correct me.
June 30th, 2010, 06:34 PM | #13 |
June 30th, 2010, 06:34 PM | #14 |
I dunno, I thought that the Jr and the Plus had similar smarts, but the Plus had a bit more amperage and could charge a battery faster. But like you, I could be wrong as well. The latest Motorcycle Consumer News magazine (the black and white one with no ads that now has a little color), just had an article in there about the newer types of batteries, and compared a bunch of newer generation chargers. The AGM batteries like to be charged at a higher voltage, and the newer chargers take that into account. He (David Hough) did a couple controlled tests, and saw where the battery voltage was afterwards. The Battery Tender Plus was at the bottom of the list, barely able to get the AGM battery where it needed to be, and the recommendation was any of the newer/smarter chargers than the old standby. For the life of me I can't remember the name of a single one of the better chargers, but it's all in that article.
FWIW I have two Plus's in my garage, it's all I use, and I do have an AGM battery in the BMW.
June 30th, 2010, 06:50 PM | #15 |
July 1st, 2010, 08:46 AM | #16 |
My brand-new bike has that connector as well, so it is definitely there from the factory.
Kevin 2009 Ninja 250R |
July 1st, 2010, 08:50 AM | #17 |
Interesting... Does it show up on anyone's wiring diagram for this bike, or is it an easter egg that just started showing up at some point?
July 1st, 2010, 09:38 AM | #18 |
Join Date: Mar 2010 Motorcycle(s): Blue 10 250r Posts: 697
It's for the blinkers on your boat trailer.
July 1st, 2010, 09:55 AM | #19 |
July 1st, 2010, 09:55 AM | #20 |
July 1st, 2010, 09:58 AM | #21 |
Makes sense.
July 1st, 2010, 09:58 AM | #22 |
July 1st, 2010, 10:18 AM | #23 |
