December 1st, 2012, 08:28 PM | #1 |
Razor's Edge
Join Date: Nov 2012 Motorcycle(s): 2007 Sportster XL1200C Posts: 196
Snorkel removed; 2 washer shim...
2012 Ninja (bought new with 1 mile on Oct 3d)
current mileage: 2013 miles I have recently removed the snorkel and added 2 washers to shim the needles. The bike doesn't need long to warm up anymore but still seems slow to take off and once it reaches 4-5k rpm range, it takes off. I haven't set the mixture screws since I have not removed the caps yet. That is still to come. When it was still stock, I didn't notice it to this extreme. Maybe it's because of the added noise from the snorkel removal that actually draws my attention to it...I don't know. But it did take an awful time to warm up though and did have the cold engine hiccup on takeoff. So right now, this is what I am thinking. I am going to put the snorkel back on and set the mixture screws out 2.5 and tune from there. The top end is great, no problems there... |
December 1st, 2012, 08:29 PM | #2 |
Jigglin' your Jiglets
MOTM - Apr '13
You should never be under 4k
Just sayin'
December 1st, 2012, 08:47 PM | #3 |
Razor's Edge
LOL...I don't stay there long at all...I just notice that when I take off (usually around 2-3k rpm) it seems slow until about 5k and it takes off...am I just not applying the powerband accordingly then? I have only had this bike 2 months, still learning it.
Maybe just the sound from the intake without the snorkel is thowing me off...becuase I never noticed this before...stock seemed smoother than what I have now...maybe just a mixture setting adjustment? |
December 1st, 2012, 08:51 PM | #4 |
MOTM - Apr '13
Well @ 4k you are making 7 hp, thats not a whole lot to get ya moving
December 1st, 2012, 09:01 PM | #5 | |
BTW, no need to mess with the mixture screws with just shims. |
December 1st, 2012, 10:10 PM | #6 | ||
Razor's Edge
7 hp isn't really a lot...thanks for that visual. I have seen dyno sheets before, but never really paid any attention to the rev ranges... |
December 1st, 2012, 10:51 PM | #7 |
MOTM - Apr '13
Oh also, that is WOT
December 1st, 2012, 11:07 PM | #8 |
Razor's Edge
so WOT at 4k is under 10hp...I see where you're going with this...
December 2nd, 2012, 03:16 AM | #9 | |
Hi,
I have ninja 2012 and recrntly I have try and error using washer (1 or 2 and 3 each needles) with default air mixture L 2,5 R 1 3/4. With 1 washer each needle the bike hard to rev , seems the to rich in midranges cause sound a little deep. Then I play with idle screw, I assume different between Left and Right is 3/4. So i adjust now L2,75 R 2. Now my bike totaly diffrent, very smooth, rev with all gear change with no drop rpm. So my point is you must set your idle screw for shimming. All this condition still using snorkel, maybe i will try remove the snorkel to see rev to redline easy. Quote:
December 2nd, 2012, 10:17 AM | #10 |
Bueller
I had the same thing happening to mine. I have the mixture screws set right around 2 each. The thing that actually fixed my problem was to balance the carbs. Once I got the carbs balanced correctly it was like a totally different bike.
Hope that is some help. |
December 2nd, 2012, 10:32 AM | #11 | ||
Razor's Edge
Took of on a ride around post to warm up the tires and to test the response. Response was great throughout the range. Following that, I made my way to the highway and up the mountain pass. Altitude in El Paso is about 3800 feet. No issues pulling up the pass all the way up to 5200 feet. We'll see how the fuel mileage is affected after these modifications. Definitely glad I did this. We'll see how the temperature around here affects the performance. Temps go from 30-40s up to 60s for the afternoon. I'll make adjustments as needed. I still haven't tuned the mixture screws and checked the carb sync. That will be next weekend, probably, along with drilling the slides. I will keep you all posted on my results. Environmental conditions: 3800 feet altitude dry/dusty climate 30-40s lows/60-70s highs |
December 2nd, 2012, 12:08 PM | #12 | |
Expect slightly lower gas mileage in temps below 70. You may find yourself adjusting your idle speed from season to season as well. |
December 2nd, 2012, 12:53 PM | #13 | |
Razor's Edge
December 2nd, 2012, 01:35 PM | #14 | |
A carb sync is matching the butterfly valves in the two carburetors so they both open the same amount. Unless one cylinder is firing harder than the other you should not need to do it. If your idle speed is fine, why change it? The mixture screws are set at the factory to meet emission standards and still make the bike rideable. Adding washers the the needles mainly affects 1/4 - 3/4 throttle. So synching and adjusting the mixture screws at this point should not be necessary. Now that you've shimmed and de-snorkled, if you want to improve your midrange and top end a little bit, you can change the stock filter to a Pipercross (just my opinion) although not necessary. |
December 2nd, 2012, 02:43 PM | #15 | |
http://faq.ninja250.org/wiki/How_do_...carburetors%3F |
December 2nd, 2012, 09:47 PM | #16 | |
Razor's Edge
I have my homemade carb sync tool in my storage room too. Whether it needs it or not, I will likely so it anyway. |
December 2nd, 2012, 09:55 PM | #17 |
I'm not sure exactly what you mean by that, but typically carbs that need syncing will have an idle that oscillates rhythmically up and down a little. In my experience, it's not a large variation of speed, but it's just a constant up and down, up and down, up and down with the idle speed.
December 2nd, 2012, 10:03 PM | #18 | |
Razor's Edge
While warming up, the idle will "oscillate" 2-3 hundred RPM. I didn't pay attention to it once it was warm because I was too wrapped up in wringing the throttle on the newfound powerband. |
December 2nd, 2012, 10:06 PM | #19 |
Then syncing might help. Remember, only sync carbs when they're up at operating temp.
December 2nd, 2012, 10:12 PM | #20 |
Razor's Edge
Now that I do know...spent some time doing that on my ninja 500 a couple months ago. Thanks for the info!
December 2nd, 2012, 10:13 PM | #21 |
December 2nd, 2012, 11:00 PM | #22 |
Razor's Edge
I had just switched the choke off...engine still relatively cold.
December 8th, 2012, 06:14 PM | #23 |
Razor's Edge
Topped off yesterday and for about 55 mpg. Not excessively hard on the throttle, but tent to open it up a little more than normal. Great response and not sputtering nor bogging down.
Help double check my Snorkel/Shim/Slipon logic | BRad704 | 2008 - 2012 Ninja 250R Tech Talk | 24 | June 18th, 2013 03:23 PM |
Shimmed needles/removed the snorkel! | NinjaBoyEddy | 2008 - 2012 Ninja 250R Tech Talk | 5 | June 12th, 2012 01:19 PM |
removed the snorkel | azn77 | 2008 - 2012 Ninja 250R Tech Talk | 6 | May 27th, 2012 05:01 PM |
shim-shimminy, shim-shimminy, shim & exhaust REPORT | evi1joe | 2008 - 2012 Ninja 250R Tech Talk | 9 | December 7th, 2011 08:41 PM |
Shimmed/Removed Snorkel, bike feels weaker? A few questions. | 1LoneWolf | 2008 - 2012 Ninja 250R Tech Talk | 31 | September 11th, 2011 10:50 AM |
