January 20th, 2014, 04:48 PM | #1 |
Fork drain bolt washer
Anyone know the size washer required for the side drain bolts?
Noticed a weep, AFTER I hit the front brake and got nothing! The ID/OD is the measuement I'd like, or if you know the bolt size. Thanks. |
January 20th, 2014, 09:38 PM | #2 |
Join Date: Jan 2014 Motorcycle(s): GPX250, ZZR250, CT90 Posts: 57
The bolt has a 6mm thread with a 10mm hex head. The washer usually sits flush with the bolt head, so as a guess I'd say the OD would be 10mm.
SO a 6 x 10 copper washer. |
January 21st, 2014, 04:41 AM | #3 |
Thank you.
May 27th, 2014, 11:27 AM | #4 |
On my 2008 model the drain bolt threads had some rubbery seal, like thread tape. The service manual doesn't mention it and I've always wondered what I should replace it with (had to remove to clean the other crap that was stuck to it).
Coolant drain bolt. desperately need help | coraya | 2008 - 2012 Ninja 250R Tech Talk | 16 | June 2nd, 2014 06:35 PM |
1 Head cover bolt, washer and o ring | WageSlaveEscapist | Items Wanted | 0 | September 27th, 2013 02:46 AM |
Fork drain bolt is stuck | Graugaard | 1986 - 2007 Ninja 250R Tech Talk | 20 | April 19th, 2013 09:36 AM |
Triple Tree bolt/ washer | Lychee | Items Wanted | 3 | October 2nd, 2012 01:09 PM |
2009 model oil drain plug crush washer | littledog | 2008 - 2012 Ninja 250R Tech Talk | 14 | January 14th, 2010 02:57 PM |
