Old September 26th, 2015, 01:17 PM   #41
Misti
Misti's Avatar
Sometime soon, Imma challenge you to nearly remove almost ALL "maintenance throttle" from your riding. Sure there are corners or sections of road where a slight roll off or pause in throttle is warranted to complete a steering action or set entry speed (call it what you will) but the secret is to know when and why. To not derail this thread and keep things simple, brakes are for scrubbing speed and setting entry speed. To use them for 99.9% any other reason is to address a symptom vs addressing the cause of the problem in the first place.
Love this, because so often the term "maintenance throttle" is used when it should be called "rolling on". Riders have a false understanding of what they should be doing in a corner to stabilize the bike and hold the throttle steady or use maintenance throttle instead of a slight roll on.
So what kinds of corners or situations warrant maintenance throttle instead of a smooth roll on?
Misti
superbikeschool.com
www.motomom.ca
Old September 26th, 2015, 03:33 PM   #42
SLOWn60
n00bie to wannabie
SLOWn60's Avatar
Motorcycle(s): 2012 250R (Red), 2005 VFR800A (Red), CRF450X (Red), 2012 F800GS (Wants to be Red!)
MOTM - Nov '15
There's one other possible cause of the OP's wandering rear end: your suspension. Have you set the sag and do you have the apropriate spring(s)? If you have set too much preload on the rear spring and you transfer all the weight to your front tire because of hard braking; your back tire may not be able to extend into any surface irregularities because the suspension is fully extended and so it will "hunt" side to side.
The Smart Money: #1 - ATGATT, #2 - Training (machine skills and survival skills), #3 - The bike; whatever floats yer boat with the money you have left over
SLOWn60 is offline   Reply With Quote
Have you guys seen these? ninja820 Videos 9 May 24th, 2013 08:22 PM
What do you guys think? taylorblake General Motorcycling Discussion 9 May 20th, 2012 05:02 AM
Need some help guys... walera 2008 - 2012 Ninja 250R Tech Talk 4 February 12th, 2010 12:30 AM
[SoupKast] - SoupKast by Honda Episode 82: Laguna USGP: Fast Guys, Short Guys and Idi Ninjette Newsbot Motorcycling News 0 July 15th, 2009 11:00 PM
[SoupKast] - SoupKast by Honda Episode 82: Laguna USGP: Fast Guys, Short Guys and Idi Ninjette Newsbot Motorcycling News 0 July 14th, 2009 10:40 PM
