November 19th, 2012, 07:50 PM | #1 |
The Luck Dragon
Join Date: Apr 2012 Motorcycle(s): 2013 Ninja ZX-6R B/W Posts: 738
Low Beam Bulb Died
So remember that side of my light housing I was having problems with where I thought maybe the bulb was over heating and causing the crazing? Well that light just died the other day. Anyone recommend where to purchase this bulb or is it a common bulb that I could just find at autozone? I've been using the high beam bulb in the meantime but that's just not going to cut it.
November 19th, 2012, 07:54 PM | #2 |
not an actual panda
Join Date: Aug 2012 Motorcycle(s): 2008 Ninja 250, 2009 CBR600RR (Sold) Posts: A lot.
Autozone sells them it's a super common bulb. Takes 5 minutes to replace.
H7 12v 55w |
November 19th, 2012, 07:55 PM | #3 |
The Luck Dragon
I figured it was a common bulb, I looked at how it comes out too. Just wanted to be sure before I started messing with it.
November 19th, 2012, 07:55 PM | #4 |
Jigglin' your Jiglets
MOTM - Apr '13
11k miles?
November 19th, 2012, 07:56 PM | #5 |
The Luck Dragon
Last I checked i'm at 8.6k I think.
November 19th, 2012, 07:58 PM | #6 |
Love my kittehs!
Join Date: Apr 2012 Motorcycle(s): 2011 Ninja 250R SE Posts: 266
Well my friend, your in luck! You can purchase a Halogen H7 lightbulb from Autozone and pay 12 to 15 bucks for it, or you can drop by your local Walmart and pick one up for 10 bucks.
I had a similar problem, dropped by a 24 hour Walmart and got what I needed for the next days ride. Remember: Do not touch the bulb with you bare hands, the new bulb that is! The oils from your skin will cause a heat riser in the glass of the bulb and cause it to blow out right where your fingers were. Wear gloves, cause your going to touch that bulb in a lot of places just getting it into the housing. Hope this helps? There was a good video on Youtube for this, and the guy shows exactly how to change it and what to do. |
November 19th, 2012, 07:58 PM | #7 |
MOTM - Apr '13
Obviously your odo is broken. The low beam only goes out at 11k
November 19th, 2012, 08:01 PM | #8 |
The Luck Dragon
Only explanation! Or maybe my bike has an old soul and likes to pretend she's older.
November 19th, 2012, 08:02 PM | #9 | |
The Luck Dragon
November 19th, 2012, 08:34 PM | #10 |
Love my kittehs!
No problem, the worst part i had with it was to get the retaining clip back on the backside of the bulb. I had to use a pair of needle nose pliers to hold it because of the position you have to be in to get it back in place.
November 20th, 2012, 09:54 PM | #11 | |
Just DON'T throw the bulb away until you get the new one in there unless you make sure the little adapter piece is not still on it!
It needs to die. The OP wouldn't even mention it in the description and acted like the everyone is going to follow the back-and-forth in the comments sections on their mobile devices and such. If you already know of it's inadequacies, watching it just to see where to reach/manipulate is acceptable. |
low beam or high beam brighter? only choose one | passive101 | General Motorcycling Discussion | 3 | July 26th, 2013 06:27 AM |
Low Beam Good, High Beam dead | FvnnyL3tt3r1ng | 1986 - 2007 Ninja 250R Tech Talk | 4 | February 21st, 2013 03:44 PM |
Low Beam Bulb Replacement | c_wang | 2008 - 2012 Ninja 250R Tech Talk | 4 | October 15th, 2012 09:03 PM |
make high beam into low beam? | DaMan22 | 2008 - 2012 Ninja 250R Farkles | 2 | July 12th, 2012 06:34 PM |
Has anyone tried to put a high beam bulb in | divingtigger | 2008 - 2012 Ninja 250R Tech Talk | 16 | April 7th, 2010 12:03 PM |
