August 23rd, 2015, 06:19 PM | #1 |
Chain wobble left to right
Hey everyone i just adjusted the chain and for some weird reason i decided to start it up on the stand and to make sure its right the slack is at .8.I have done this many of times before,i just notics that there is a slight wobble from left to right with every rotaion could it be missed aligned i turn both nuts only half a turn
August 23rd, 2015, 06:31 PM | #2 |
dirty boy
MOTM - Apr '14
measure the distance of the center of the rear wheel axle/bolt to some set point on the bike for each side to ensure it is straight. Don't go by the lines on the tensioners for anything but a rough set.
That being said, the chain will have a little bit of sideways movement on the sprockets, not much but some. As long as the front or rear sprocket are not moving with it you should be ok in that respect. But definitely check on rear axle alignment/squareness
August 24th, 2015, 02:33 PM | #3 |
There is a natural lateral play between the chain and the sprockets.
That play is the difference between the internal width of the chain (between two internal plaques) and the thickness of the sprockets. You should verify/adjust the alignment of the rear wheel, but not because that movement that you have just noticed.
August 24th, 2015, 07:41 PM | #4 |
Thanks guys i loosing everything right off and re adjusted again and there is no wobble now,it was not bad i mean no vibration or feeling bad on corner just looked wierd to me.If the rear wheel was out of align would you not notice it riding at 100km or even in corners
August 24th, 2015, 08:37 PM | #5 |
When the rear is off, the steering tends to pull towards the side the rear is pointing to, especially when you take your hands off the handle bar.
The stronger the missalignment, the stronger the pull. The rear sprocket copies any missalignment of the wheel as both are mounted on the same axis.
wobble at different speeds | wardie | 2008 - 2012 Ninja 250R Tech Talk | 3 | September 14th, 2014 11:11 PM |
Handlebars wobble | Sykes92 | General Motorcycling Discussion | 20 | December 5th, 2013 08:51 PM |
rear wheel wobble | focus101 | 1986 - 2007 Ninja 250R Tech Talk | 9 | July 11th, 2013 05:29 PM |
Chain Sound and Slight Wobble | iHeartDawnKeyes | 2008 - 2012 Ninja 250R Tech Talk | 5 | July 30th, 2012 07:12 PM |
[nytimes.com] - Wobble and Weave | Ninjette Newsbot | Motorcycling News | 0 | August 27th, 2010 12:40 AM |
