Old January 9th, 2010, 04:03 PM   #1
currentsea
currentsea's Avatar
HID blows fuse when starting bike
A friend of mine put an HID kit in his '08 250R.
When he starts the bike with the high beams on, the bike blows a fuse.
It starts fine with just low beams.
Has anyone else experienced this, and how do you correct this?
I'm looking to buy a kit, if anyone has any recommendations they can post on here too that'd be great.
currentsea is offline   Reply With Quote
Old January 9th, 2010, 04:18 PM   #2
Check out the HID DIY at the top of the tech section, it should cover this.
Old January 9th, 2010, 05:59 PM   #3
why not just start the bike with only the low lights on and switch on the highs later? also, does he have the 35 or 55w kits?
Old January 10th, 2010, 12:17 AM   #4
currentsea
currentsea's Avatar
Alex: Thanks, found the thread, i was looking in the Farkles section.
Kkim: He has a 35w kitt, and yeah starting with the brights off is what he will have to do.
Old January 10th, 2010, 01:46 PM   #5
Rayme
Rayme's Avatar
Motorcycle(s): '04 sv650s
HID will use alot of current when started cold you might need a higher rated fuse. The rated power is when the ballast are all warmed up.
There's 2 types of people in this world, those who complain and those who act.
Rayme is offline   Reply With Quote
Old January 10th, 2010, 10:10 PM   #6
Viper-Byte
Viper-Byte's Avatar
Motorcycle(s): 08 Ninja 250R in Green! (Sold) Now 2011 Triumph Daytona 675 SE
I had the same issue, I installed a 15A fuse and all good (10A is stock), I usually start on low, but sometimes if I forgot to turn high off, don't want the fuse blowing each time i do.
2008 GREEN Kawasaki Ninja 250R.
AreaP Quiet Core Carbon Fibre : 8000k HIDs : Dynojet Jet kit : Double Bubble Windscreen
Viper-Byte is offline   Reply With Quote
Old January 12th, 2010, 09:53 AM   #7
randomwalk101
self wrencher
randomwalk101's Avatar
Depending on which kit you get. I had to replace my fuse with a bigger one.
Posted via Mobile Device
Old January 12th, 2010, 02:26 PM   #8
Timm3h
I hope your wires are thick enough to handle the current. I would hate to hear that by allowing more current through the wires would melt...
Timm3h is offline   Reply With Quote
Old January 12th, 2010, 03:52 PM   #9
once started, the HIDs draw less current than the stock setup.
Old January 12th, 2010, 06:51 PM   #10
Timm3h
Agreed, but what if some how they started to draw more current, over time, that could melt the wires
Old January 12th, 2010, 07:05 PM   #11
anything is possible, but why worry about something that's never happened?
Old January 12th, 2010, 09:04 PM   #12
g21-30
g21-30's Avatar
I can start mine with both lights on and I still have the OEM 10 amp fuse.
Old January 12th, 2010, 09:17 PM   #13
Viper-Byte
Viper-Byte's Avatar
Sam, did you get the 35w kit, or the 55w kit? Mine were 55w.
Old January 13th, 2010, 04:37 AM   #14
g21-30
g21-30's Avatar
David, I have the 35W. Remember, that was why I was so concerned when you were blowing fuses, after your install. Because of you, I always turned my high beam off after a ride. One day, I forgot to do so and realized it the next day. I pulled out of my driveway and reached to turn on the high beam and discovered it was already on! I realized then, the 10 amp fuse didn't blow. Of course, now it's winter time and I don't use the high beam, because I'm running a heated jacket liner and glove liners.
Old January 13th, 2010, 11:49 AM   #15
Viper-Byte
Viper-Byte's Avatar
That would be why, obviously the 35w draws a small enough current at start to not blow the stock 10A fuse.
I try to remember to turn high off, but occasionally forget. I only ride with low beam on unless I am alone on the road at night anyway.
bike wont start. fuse box is buzzing rabies 1986 - 2007 Ninja 250R Tech Talk 13 October 6th, 2012 03:40 PM
Bike not starting.... LoneRonin 2008 - 2012 Ninja 250R Tech Talk 2 April 29th, 2012 07:33 PM
30A main fuse blows j.cuesta 1986 - 2007 Ninja 250R Tech Talk 5 October 29th, 2011 10:06 AM
Bike not starting?! nightrider 2008 - 2012 Ninja 250R Tech Talk 32 September 5th, 2011 04:44 PM
Bike is not starting now :( bikermunda 2008 - 2012 Ninja 250R Tech Talk 6 January 3rd, 2010 10:02 PM
