July 7th, 2013, 08:22 PM | #1 |
Carb Question
Hey guys,
New here, looking for a little help, figured I'd try some experts! Anyway, quick question. Have a 2006 Ninja 250 that has sat for a couple years and wanna get it up and running again and probably sell it. Tires, chain and cables all to be checked and lubed, gas drained, and I want to clean/rebuild the carbs. So that brings me to my question... Every carb rebuild kit I see is for up to 2005 250's, the 2006 isn't listed. Is the older rebuild kit compatible, or does anybody know where to source a kit for a 2006? Just wanna double check before I order anything... Any help is appreciated! Thanks everybody, Scott |
July 8th, 2013, 01:27 PM | #2 |
Welcome, Scott !!!
I don't believe that you need any kit to refurbish those carbs. All models between 1986 and 2007 are the same. Use this as a guide for the work: http://faq.ninja250.org/wiki/Intake
July 12th, 2013, 06:30 PM | #3 |
Hey, thanks, its been sitting a while and just wanted to have the parts on hand as a back up...
But now my new problem, hopefully it will get attention without starting a new thread: Working on it now, went to drain the oil, and it came spewing out, and is more gas than oil.... what likely failed and what can be done about this? Should I flush with oil a few times before trying to run the bike? Any help, PLEASE! hahah... Scott |
July 12th, 2013, 06:36 PM | #4 |
Upon further research could be a number of problems coming, possibly from the carbs, so good thing I got the rebuild kits! We'll see once I get them pulled apart!
July 12th, 2013, 09:56 PM | #5 |
Join Date: Mar 2011 Motorcycle(s): 96 Ninja 250EX , 87 CBR 1000, 86 TRX 260R, 86 KXT 250, 84 ATC 200X, 82 ATC 250R (w/CR480) Posts: 134
The fuel in oil most likely was due to the floats sticking in the carbs and dumping raw fuel to the intake side....
carb question | Bob2010 | 2008 - 2012 Ninja 250R Tech Talk | 9 | April 15th, 2014 10:00 PM |
Carb Question | Countersteer | General Motorcycling Discussion | 7 | May 29th, 2012 05:36 AM |
Carb question | drstimpy | 1986 - 2007 Ninja 250R Tech Talk | 9 | March 25th, 2010 02:55 PM |
Carb question | sombo | 1986 - 2007 Ninja 250R Tech Talk | 6 | March 22nd, 2010 09:27 PM |
Another carb question | diablo250 | 2008 - 2012 Ninja 250R Tech Talk | 3 | June 22nd, 2009 11:13 AM |
