Old August 25th, 2023, 07:51 AM   #1
matt234
Motorcycle(s): 1989 GPX 250
Can't get bike to start
I bought an '89 250, non-runner, for a few hundred dollars, that would turn over. I pulled off the carbs, took them apart, gave them a good clean and put them back together. I did an oil change and replaced the oil filter, and got some new spark plugs. But it won't start. The petrol tank is rusted, so any time I'm trying to start the bike I'm using a direct line from a container to the carbs, with the petrol just being gravity fed to the carbs, and I disconnect it so there's no petrol going to the carby when the bike's just sitting. It has spark, and fires if I spray engine starter into the carb. I've got the airbox off. I have the mixture screws unwound 3 turns, and it did start and idle, with choke and without any engine starter, for about 8 seconds. But that's all I've been able to get out of it, and it hasn't done that since. It just turns over. The carbs don't seem to be leaking at all and I'm not too sure where to go from here. I'm convinced it's carby related because it has spark and seems to have compression. The jets, floats, float valves and diaphragms seem alright so I'm not too sure. Any advice would be much appreciated.
matt234 is offline   Reply With Quote
Old August 25th, 2023, 11:03 AM   #2
Hi Matt, welcome!
These carburetors are notoriously difficult to get completely clean. The problem you're having is very common with bikes that have been sitting for a long time. Here's some information about cleaning the carbs:
https://n4mwd.blogspot.com/2013/10/s...-passages.html
Old August 25th, 2023, 12:24 PM   #3
You'll need further complete disassembly of carbs down to every last nut, bolt and individual component for scrubbing with brushes and poking out with matching-gauge soft copper wires. Bike ran perfectly fine when leaving showroom floor. It will again when carbs are restored to factory-fresh clean with all factory settings.
Spray carb-cleaners no longer work due to removal of chlorinated compounds. Scrub with PEA-based fuel-system cleaners:
- Red Line SI-1
- Techron Concentrate Plus
- 3M Max Strength Fuel System Cleaner #08814
- Royal Purple Max Atomizer 18000
- Gumout All-in-One (may be off list soon due to reducing amounts of PEA)
Scrub-brushes from Amazon: https://www.amazon.com/dp/B01N6QEINN
Scrub secret hidden passages in carb-body with PEA-based fuel-system cleaner.
N4MWD's blog: Secret Ninja 250 Carburetor Passages
Completely disassemble emulsion-tube and pilot jet. Poke out all lateral bleed holes with soft copper wire. Dried petrol turns to plastic and cannot be dissolved again. Must be mechanically scrubbed away. Also poke out all bleed-holes in carb-venturi towards float-bowl. Especially the mixture-screw hole.
Ultrasonic soak everything, micro soda-blast. Replace all rubbers: fuel-rail O-rings, float-valves, flow-bowl seals, pilot-screw O-rings. Set float-height with wet-test. Sync-carbs
That's a lot of work and requires lots of experience and equipment. Unless you want to practice and destroy hundreds of carbs to learn this kind of work, I recommend sending petcock & carbs off to ducatiman (gordon) for complete restoration work.
https://customcarbservices.com
Expert work, reasonable costs and fast turnaround! Bike will run like brand-new off showroom floor!!!
BTW - can search "ducatiman clean carbs" on this forum for procedure & photos of what's involved in thorough carb restoration back to factory-fresh OEM clean.
Bike won't start and backfires when trying to start TrickyTriggs General Motorcycling Discussion 30 April 16th, 2018 08:35 PM
If you have started or want to start building a project bike, what bike would it be? Wanderer General Motorcycling Discussion 37 June 4th, 2017 02:17 PM
Bike would not start, then.. 2003ninja 1986 - 2007 Ninja 250R Tech Talk 6 May 19th, 2012 02:07 PM
Can't start my bike lambxchopps 1986 - 2007 Ninja 250R Tech Talk 1 March 21st, 2012 08:07 PM
