Old January 15th, 2012, 04:19 PM   #1
samw
Motorcycle(s): 2005 HON CBR1000RR Repsol, 2012 KAW Ninja 250R
Metal piece under stock front fender
I'm replacing the stock bodywork with race bodywork. Today when I removed the stock front fender I see a fairly large metal brace that runs underneath the fender. It bolts to each fork tube and also holds the cable management brackets on each side. The OEM fiche calls this "BRACE-ASSY,FRONT."
I think I can remove this brace and save weight, but I thought I'd ask here.
It may even interfere with my race bodywork, I haven't test fit it yet.
Can I remove this brace?
samw is offline   Reply With Quote
Old January 15th, 2012, 04:53 PM   #2
Zyconic17
Motorcycle(s): 2010 Ninja 250r Track bike, Honda CRF250r Dirt bike
I dont think you can, the fender bolts onto the brace, so unless you dont want a front fender, i dont think it would be possible. i guess you could always make a new one that is lighter. And it will not interfere with race bodywork, the fender is the same as the stock one.... just lighter.
Zyconic17 is offline   Reply With Quote
Old January 15th, 2012, 08:18 PM   #3
samw
Thanks Zyconic ! If the fender bolts to the brace, I guess it stays on the bike.
Old January 16th, 2012, 02:02 AM   #4
you can. remove the frame, and the fender. save twice the weight.
Old January 16th, 2012, 11:00 AM   #5
randy328
CMRA Mini Endurance #6
randy328's Avatar
Motorcycle(s): CBR954, CBR600RR, EX250
We cut it horizontally on both sides just above the mounting bolts, so that the "crossover" piece was removed. We removed the cable management stuff on the left side since we also removed that cable (speedometer).
The fender is only attached using the side bolts.
randy328 is offline   Reply With Quote
Old January 18th, 2012, 12:29 PM   #6
smokinsingle
L8APEX
smokinsingle's Avatar
Motorcycle(s): 07 KTM 950SMR, 06 KTM 450SMR, 99 KTM 300MXC, 00 Derbi GPR 50, 09 Ninja 250 racebike, race with www.cra-mn.org!
That "fender mount" is a fork brace. Designed to keep the front end from twisting up like a pretzel on the track. It adds a substantional amount of stiffness to the front of the bike, especially on the brakes. Leave it alone! I'm trying to wrap my head around a way to make a stiffer one that looks stock!
www.joemillersmoderngarage.com www.starr-cycle.com
***The most important concept of science isn't memorizing facts, it's observation of phenomena.***
smokinsingle is offline   Reply With Quote
Old January 25th, 2012, 12:26 AM   #7
ROADandTRACK
R&T Suspension
ROADandTRACK's Avatar
The EX's handle better at speed w/o a fork brace. Believe it or not.
The little advantage was under braking, but you can deal w/ the twisting under braking. The binding up/chatter fast sweeper runing off track problem sucks.
Better w/o it if you are a front runner
ROADandTRACK is offline   Reply With Quote
Old January 25th, 2012, 05:25 AM   #8
samw
I've been thinking about this. I haven't ridden the ninjette yet so I don't have any experience with it, but I've never raced a bike with a fork brace. The Honda CBR250R I raced last year has the same size forks too. I haven't gone as far as try to compare frame/fork construction or geometry...
Old January 31st, 2012, 08:34 PM   #9
Shadowwolf1117
Avid enjoyer of life.
Shadowwolf1117's Avatar
Motorcycle(s): 2011 EX250 2010 R6 2008 ZX6R 2010 EX650R
That is my contention, however going with a stiffer brace may just be a bandaid to a fork suspension issue. I personally am running racetech springs premium gold emulators and preload adjusters, it has made a world of difference for front end control. I havent found a need to go to a stiffer fork brace nor have I tried running without the stock fender/fork brace but I am not experiencing the chatter others have stated. Just remember suspension setup is a pinpointed science. Installing new suspension components is merely the beginning to great control. Set up is everything.
"I refuse to tiptoe through life only to arrive safely at death."
Shadowwolf1117 is offline   Reply With Quote
Old February 2nd, 2012, 09:11 PM   #10
smokinsingle
L8APEX
I'm running the exact same front end parts and totally agree. Set-up is everything! What weight fork oil are you running?
Old February 2nd, 2012, 11:25 PM   #11
Shadowwolf1117
I am running 5 weight oil for now and it seems to be doing just fine, I set it at 10mm below stock since i set my emulators a bit stiffer for racing, I also modified my dampening rod to accomodate more equal flow.
Old February 3rd, 2012, 12:05 PM   #12
ROADandTRACK
R&T Suspension
You are either on a slow track or not going fast enough.
They WILL chatter, mainly on very fast sweepers.
Old February 5th, 2012, 10:08 PM   #13
smokinsingle
L8APEX
From the BIR website, where we race:
The 3.1-mile Donnybrooke Road Course has 10 turns and is considered wide – the main straight is 60 feet wide. There is essentially no elevation change. BIR is a very high-speed course; vehicles can reach speeds of nearly 160 mph and take the slowest corners around 80 mph. There are wide runoff areas at most of the corners, which makes BIR’s road course extremely safe.
Whether they were Superbike riders, professional Trans-Am drivers or car club members, household names in road racing have challenged the road course’s 10 turns, including Turn 1, a banked right-hand 60-degree turn that continues to be the fastest turn on any road course in the country.
So I must be slow? LOL
Old February 5th, 2012, 11:25 PM   #14
Shadowwolf1117
+1
Old February 6th, 2012, 08:37 AM   #15
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Motorcycle(s): All of them
5 weight? Did you mean 15?
This is somewhat true. Stock geometry will cause the bike to chatter if 1) you're entry speed is fast and 2) depends on the turn/corner. Mid way through the season I started to experience really bad chatter in certain corners...not all but there were two corners that caused the front to chatter like crazy. Once I changed the setup the chatter completely disappeared.
Old February 6th, 2012, 10:04 AM   #16
Shadowwolf1117
Yes! good catch Nemesis, I guess my "1" grew legs , it is 15w.
Old February 6th, 2012, 10:11 AM   #17
Rexbo
CVMA / AFM / M1GP #250
Rexbo's Avatar
Motorcycle(s): 2009 Ninja 250r, 2011 Zero S, 2009 KLR 650
You mean once you raised the rear ride height
I'm curious to see if this brace makes a difference or not, maybe I'll try taking it off for a session or two and see how it feels.
Rexbo is offline   Reply With Quote
Old February 6th, 2012, 10:53 AM   #18
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Yes.
I don't understand why the brace would make such a huge difference under braking.
Could someone please explain this to me? Someone w/experience that is.
Old February 6th, 2012, 11:46 AM   #19
samw
Based on the feedback in this thread, I think i'll start with the fork brace on, but as I get used to the bike, experiment with taking the brace off. I think results will vary based on riding style, track layout and surface, etc.
Posted via Mobile Device
Old February 6th, 2012, 05:58 PM   #20
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
I don't understand this...by "fork brace" are you referring to the metal piece under the front fender?
It's not a fork brace...it's just there to stabilize the front fender from bouncing around.
Old February 7th, 2012, 12:01 AM   #21
smokinsingle
L8APEX
Come on, Nem you really think they would build a fender mount that beefy. That's not very cost effective. It's a fork brace too.
Old February 7th, 2012, 12:34 AM   #22
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Maybe you guys are right but I seriously think you guys are reading into this way too much. A fork brAce for a 250? LOL
But out of curiousity I'll ask my contact (design engineer) @ kawi. Can't wait to hear the answer. Haha
Old February 7th, 2012, 08:02 AM   #23
Rexbo
Rexbo's Avatar
hey they make them for dirtbikes! and its probably cheaper to make a fork brace than put real front forks on these bikes
Old February 7th, 2012, 08:20 AM   #24
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Dirt bikes I can understand but a street bike like our 250s? Oh, thanks for reminding me to send an email. LOL
Old February 7th, 2012, 11:08 AM   #25
ROADandTRACK
R&T Suspension
Nem and Smoke, the things WILL chatter when you go faster.
Even w/ geo. changes.
Old February 7th, 2012, 11:16 AM   #26
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Wait...we're talking about the metal brace. You're talking about chattering. What are we talking about again? LOL
And define "when you go faster"?
Old February 7th, 2012, 11:46 AM   #27
ROADandTRACK
R&T Suspension
W/ or w/o the brace they will chatter.
In our experience it chatters at a higher speed on our tracks w/o the brace. So we don't run the brace.
If you aren't feeling it then you aren't going fast enough. I'm not being a jerk, it is just that simple.
Last futzed with by ROADandTRACK; February 7th, 2012 at 11:47 AM. Reason: I'm talking about an actual fork brace. the fender mount doesn't do much.
Old February 7th, 2012, 12:02 PM   #28
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
I know you're not trying to be a jerk.
And here's the key word "on our tracks". And since we all race on different tracks not all of us may experience what you have experienced.
Also, after I eliminated the chatter I ran 2 seconds faster. Then in the last round 3 seconds faster and still no chatter. So what exactly am I doing wrong if I'm going faster but am not experiencing chatter.
Sorry not trying to be a jerk.
Old February 7th, 2012, 12:04 PM   #29
ROADandTRACK
R&T Suspension
Go faster
Old February 7th, 2012, 12:14 PM   #30
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Go faster
Okay, go faster so I can feel chatter again even after eliminating it. Then what shall I do once I eliminate the chatter. Go even faster? I like the way this guy thinks.
At this rate, I'll be doing 2:05s in no time.
Old February 7th, 2012, 12:19 PM   #31
ROADandTRACK
R&T Suspension
That's what you are supposed to do.
Old February 7th, 2012, 12:21 PM   #32
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Werd!
I like you.
Old February 7th, 2012, 03:11 PM   #33
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
This just in:
The only purpose of the bracket underside of the 250 front fender is to HOLD the fender in the place. It has NOTHING to do with the forks for handling function.
In early 70's some bikes had a similar bracket to brace the forks but not on today's bikes.
Old February 7th, 2012, 03:27 PM   #34
JGRIM
Motorcycle(s): 09 Ninja 250r
Here is a fork brace my buddy and I built. Its based on one he made for his bike, just a little smaller. It changes the way my bike handles for the positive. Think of it as an anti- sway bar on a car. That thing under the fender, I don't know what thing is suppose to "Brace". BTW, I ride on the street only. I know the track is different, but it works great on the street.
JGRIM is offline   Reply With Quote
Old February 7th, 2012, 03:43 PM   #35
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Why? Makes no sense whatsoever. Struts on cars vs on motorcycles?? Apples & oranges, my friend. Apples & oranges.
Old February 7th, 2012, 06:29 PM   #36
ROADandTRACK
R&T Suspension
I agree, take that off.
Old February 7th, 2012, 06:47 PM   #37
JGRIM
Funny.....Same thing your mother says to me
Old February 7th, 2012, 07:00 PM   #38
smokinsingle
L8APEX
This just in:
I still don't understand why Kawi would build a piece that big to just "hold the fender" . It makes no sense to have the loop of metal over the wheel if that is the case. Keep in mind we don't have pinch bolts at the bottom of the fork legs keeping torsion forces off of the axle.
And who is being quoted here?
Old February 8th, 2012, 09:07 PM   #39
samw
Interesting thread here
Old February 9th, 2012, 12:08 PM   #40
ROADandTRACK
R&T Suspension
And it looks silly
5 - 7 inch piece of bent metal on my bike IF13 2008 - 2012 Ninja 250R Tech Talk 3 August 21st, 2013 02:51 PM
Front Fender - Metal Bracket Removal Rollin.. 2008 - 2012 Ninja 250R Tech Talk 4 August 14th, 2013 06:35 AM
metal stock alex.s Off-Topic 4 April 14th, 2011 02:39 PM
2008/2009 Stock Blue Front Fender FREE! TygaUSA.com Motorcycle-related 4 July 16th, 2010 12:36 PM
Selling - Stock '09 Fender/Blinkers (Front) Brently7785 Items Wanted 5 June 1st, 2010 09:49 PM
