Old March 31st, 2010, 03:26 PM   #1
james250ninja
james250ninjette.newbie
james250ninja's Avatar
Motorcycle(s): 1986 ninja 250
Smile bike wont idle
need some info
wheni start my bike up it starts up then it dies, wheni try to use the idle screw it cant even find the right idel at all
also a little bit of gas seems to leak out from the carb not alot just a little any ides
james250ninja is offline   Reply With Quote
Old March 31st, 2010, 05:02 PM   #2
OldGuy
Live Life
OldGuy's Avatar
Motorcycle(s): 2009 Green SE Ninja 250
James we need some more info. New bike for you or just coming out of winter storage? Starts and runs with or without choke? Old gas, new gas, any conditioner?
- ATGATT -
Scorpion EX700 Hi-Vis Helmet, First Gear MeshTek 3.0 Jacket, TourMaster Transition 2 Jacket and Flex Pants, Sidi Doha boots
OldGuy is offline   Reply With Quote
Old March 31st, 2010, 05:18 PM   #3
james250ninja
i bought the bike on march 2 the lady that owned it said she didnt ride for about a year
so i bought the bike and it ran fine i changed the plugs oil and drained the float bowls and was running fine ,well today i rode for about 10 mins running an erran
all the sudden its just shuts of when im at a stop light
1 i cant find the idel
2 the choke wont even work
3 its starts up but as soon as i let go of the throttle it it dies down and off..
5 the choke was working well up until now...
4 been using regualr gas...
Old March 31st, 2010, 05:32 PM   #4
OldGuy
Live Life
OldGuy's Avatar
Best guess at this point is that there is crud in the tank that has now gotten into the carb bowels. With a pre-gen you should be able to take the gas line off the tank and connect a piece of gas tubing so you can drain the tank by going to the PRIME position of the valve on the tank. Then drain the line into the carbs, bowels, and check the bottom of the gas tank for the "crud". Taking the tank off is very simple so you could clean everything out.
It wouldn't hurt to put a NAPA (or what ever is in your area) in-line filter between the tank and the carbs.
That should get you started. Hope that dumping the bowls and getting clean gas through the system clean things up. Only put a quart or so of gas in the tank to start with until you have everything sorted out.
- ATGATT -
Old March 31st, 2010, 08:46 PM   #5
the pregens don't have a "prime" position on the petcocks.
Old March 31st, 2010, 09:16 PM   #6
OldGuy
Live Life
OldGuy's Avatar
Bad on me - wonder why I thought that. I've swapped a PM with James so I think he is headed down the right track.
- ATGATT -
Old March 31st, 2010, 09:27 PM   #7
cool... didn't want James thinking he had even more things wrong with his bike.
Old April 1st, 2010, 12:05 PM   #8
Slabrocks
Slabrocks's Avatar
Motorcycle(s): 01 Ninja 250
sounds like you should read my thread.
same issue and probably the exact same issue
http://www.ninjette.org/forums/showthread.php?t=40047
"Helmets are like rubbers, you know you should wear one, but its so much better when you don't." Zerk from ADV
Slabrocks is offline   Reply With Quote
09 Ninja 250r wont stay idle without choke TqAmsNy 2008 - 2012 Ninja 250R Tech Talk 11 March 20th, 2013 01:38 PM
Idle jumps to 9000 rpm on choke then wont stay idle after off Shawn250 2008 - 2012 Ninja 250R Tech Talk 1 June 19th, 2012 06:45 AM
FI model problem - wont idle well and throttle surges Christofeser 2008 - 2012 Ninja 250R Tech Talk 4 January 16th, 2012 05:07 AM
Erratic idle, wont start cold, etc. d16soda 1986 - 2007 Ninja 250R Tech Talk 9 August 24th, 2011 02:12 PM
bike wont idle right :( 86ninjarider 1986 - 2007 Ninja 250R Tech Talk 11 August 3rd, 2011 09:09 AM
