October 14th, 2011, 11:39 AM | #1 |
Join Date: Nov 2009 Motorcycle(s): 2004 Ninja 250 Posts: 21
Turned bike off while waiting for construction, 5 mins later won't restart
I was coming into work and was stopped along the road by a flagger with a stop sign in his hand due to construction on a road. It was taking a while, so I decided to turn off my engine. About 5 mins later when I was able to move, my bike wouldn't start and eventually I drained the battery and had to get a jump. Has anyone experienced this before or knows why this happened. I was just trying to conserve energy!
2004 Ninja Krystle |
October 14th, 2011, 11:45 AM | #2 |
you probably turned the engine off without turning the key/lights off. lights drained the battery. bike dead.
October 14th, 2011, 12:01 PM | #3 |
ur a genius. makes perfect sense, though i didn't realize how quickly it drains. i totally lucked out this time, this experience will probably save me in the future. thanks a lot!
October 14th, 2011, 01:53 PM | #4 |
I had to go out and play with my Ninja to figure out what you guys were talking about. So it looks like you are saying that you used the KILL switch to stop the engine rather than turning it off at the switch. I checked and the headlight stays on when you do that.
I just learned something new! However, I never use the kill switch myself because I thought it was just for emergencies.
October 14th, 2011, 03:48 PM | #5 |
ohh. now i'm doubting what I learned in my MSF course. What does everyone else do?
October 14th, 2011, 04:07 PM | #6 |
Kill switch. To instinctively use it in an emergency, one must program ones self to do so. The manual says to use the key though. I follow MSF instead.
October 14th, 2011, 04:12 PM | #7 |
October 14th, 2011, 06:23 PM | #8 |
The poll says its neck and neck between the kill switch and the key. Honestly, knowing that it doesn't cut anything else off, and you still have to remove the key, I'm wondering why anyone would use the kill switch on a regular basis.
I would only use it in an emergency such as when the bike gets dropped. The kill switch is usually always in the same place on all bikes. That means that a passerby could always find it should you be incapacitated. That's not true for the key switch which could actually be underneath a bike on its side. One thing for sure is that when I turn off the bike with the key, my headlights go out and the battery doesn't get drained.
October 14th, 2011, 06:47 PM | #9 |
Avid Kitteh Poster
Join Date: Sep 2011 Motorcycle(s): 2006 Yamaha TTR 50 SUCK IT Posts: A lot.
MSF I was taught use the kill switch so you can keep both hands on the handle bars until you get off. I use the kill switch now. Then turn the key off.
I powdercoat stuff Help me pay for my addiction I say funny stuff. http://twitter.com/JustinPWNSyou sometimes... I write like a 12 year old too, http://justinpwnsyou.wordpress.com/ |
October 14th, 2011, 07:54 PM | #10 |
I stop with the bike in 1st, feet on the ground, then with the clutch pulled, I use my right hand to turn the key. Then I release the clutch and the bike is locked from rolling off the kickstand. In my garage, I leave it in neutral, but everywhere else, I leave it in first.
October 14th, 2011, 08:06 PM | #11 |
Join Date: Jan 2011 Motorcycle(s): 06 yzf r6r previously: 09 ninja 250r, black 07 zx6r Posts: A lot.
I unplugged my zx6r's battery the other day to take the tank off, went to start the bike this morning and realized it took a good 2-3 full seconds of rolling over before it fired up; generally it takes less than 1 second. I didn't think it would make that large of an impact from having the battery out of the bike for 1 1/2 days but I guess it's always a possibility.
October 15th, 2011, 05:57 AM | #12 | |
I just did the valves on mine and now it wont tolerate the choke and only starts without it. Warm or cold.
October 15th, 2011, 09:55 AM | #13 | |
To prevent the headlight from quickly draining the battery I installed a new rocker switch (two position: on/off) that independently kills the headlight so I can turn it off while keeping the rest of the bike's electrical system powered up for diagnostic work. Once the headlight is off there's not much draw on the battery. |
October 15th, 2011, 11:31 AM | #14 |
oh, another question. Does this mean I need a new battery?
October 15th, 2011, 02:41 PM | #15 |
Only if it no longer holds a charge. You should also check to make sure your bike is still charging.
Take the seat off to access the battery. Measure the voltage at the battery terminals with a digital multimeter. The battery should be exactly 12.7 volts. If its less than 12.7, then its not charged. Now start the bike in neutral. Measure again. It should be about 14-15 volts or so while the bike is running. If its still 12.7 volts or less when running, then its not charging any more. If you jumped the bike incorrectly, then it could have blown a fuse or damaged something. Never jump to a running car.
October 15th, 2011, 04:48 PM | #16 |
ok results:
Voltage- while off: 12.8 after started: 14.6 after switched off 13.6 am I good? |
October 16th, 2011, 04:53 AM | #17 |
CBR? This is ninjaaaaaa!!
Keyoff. Killswitch for emergencies.
October 16th, 2011, 04:54 AM | #18 |
If it cranks over and starts fine, you dont need a new battery.
October 16th, 2011, 05:17 AM | #19 | |
Sometimes when an older battery gets run down, such as by leaving the lights on, it will kick it over the edge so that it wont come back. But your voltages indicate that your battery is good and that its probably still OK.
October 16th, 2011, 03:26 PM | #20 |
i tried it again this morning after about 14+ hours. It read 12.693.
But i have to admit, I repeated the same stupid mistake yesterday while waiting for someone. seriously only a few minutes. luckily after waiting about 10 minutes, it started back up again. maybe i should just get a new battery. |
October 16th, 2011, 03:45 PM | #21 | |
Dies and Won't restart! HELP me out | Klondike1020 | 2013 - 2017 Ninja 300 General Discussion | 8 | June 21st, 2014 08:59 PM |
Bought first bike and 1 day later it won't start: do I have a junk bike? | brendandubs | 1986 - 2007 Ninja 250R Tech Talk | 43 | May 11th, 2014 07:59 AM |
[visordown.com] - If BMW turned its K1600 into a sports bike | Ninjette Newsbot | Motorcycling News | 0 | August 4th, 2011 01:40 PM |
Has your confidence in your riding skills ever turned you nutter on your bike? | virgilsc | Riding Skills | 22 | January 20th, 2011 04:01 AM |
Kills & won't restart. | DragonKen | 1986 - 2007 Ninja 250R Tech Talk | 8 | March 13th, 2010 08:22 AM |
