Old June 7th, 2009, 03:44 PM   #1
Purspeed
Purspeed's Avatar
Touch Up Paint for 2007 Blue Ninja? Anyone...
Any tips would be appreciated. Color Rite and DupliColor are kind of expensive.
"This is my Ninja. There are many like it, but this one is mine..." ~ Purspeed (ca. Nov, 2008)
Purspeed is offline   Reply With Quote
Old June 7th, 2009, 04:21 PM   #2
I was going to send you to the touchup paint article on the wiki:
http://www.ninjette.org/wiki/Touchup_paint
but all it does is send you to the same Color Rite company that you're already aware of. If you do end up finding a less expensive source, make sure to post it back up either here or within the wiki article so other folks can find it as well. Good luck...
Old June 7th, 2009, 04:30 PM   #3
Purspeed
Purspeed's Avatar
Thanks Alex. I'll check around and see if I can find an "El Cheapo" solution to my problem.
Old June 7th, 2009, 04:53 PM   #4
Buffalony
Buffalony's Avatar
hobby paint
Old June 8th, 2009, 10:17 PM   #5
Verus Cidere
Verus Cidere's Avatar
Motorcycle(s): '91 Honda CBR600 F2
I just went to a local paint shop and had them do a color match. Price difference: I'm not sure about just a small amount, but I got a quart for $90 instead of colorrite's $190 per quart. It's a bit better I think in price. I still haven't had the chance to put it on the bike, so I couldn't tell you if it's a good enough match or not.
1991 Honda CBR600 F2, White/Gray, D&D slip-on exhaust, tail integrator, gel grips, Custom undertail.
Verus Cidere is offline   Reply With Quote
Old June 9th, 2009, 09:29 PM   #6
Nemy
Nemy's Avatar
Motorcycle(s): 2009 SE Ninja 250R
its gonna be hard from sources outside of colorrite because the plasma and thunder blues are pretty unique and with a hint of sparkles. 1 spray can, though, can repaint 2 whole fairings (4 coats) so that might help justify the cost :P
Nemy is offline   Reply With Quote
Old June 10th, 2009, 09:26 PM   #7
Verus Cidere
It's true, there's quite a bit of stuff in it isn't there? Again, I'm not sure if this is a match or not, but the paint I got has a list of different things it has in it.....
Organic Blue, Bright Coarse Alum, Blue Pearl, and a basic Blue all in it at the same time. Again, we'll see if it matches right once I actually have the money to get my new fairings. (Fiberglass and inexpensive, but the AP exhaust comes first.)
Old June 10th, 2009, 10:11 PM   #8
Purspeed
Purspeed's Avatar
Thanks for the info. I am not really looking for perfection. A decently matching paint will work.
If anyone has a particular brand and part no. for a little cheap color, that would be great. Otherwise, I'll live the scratches.
Old June 12th, 2009, 02:51 PM   #9
Verus Cidere
I found out that there isn't really a paint number for this color. Like Tim said, there's quite a few things in this paint that make it very unique. You could try going to a paint shop and seeing how much a color match would cost. You'll see how much it'll cost without them actually mixing anything, so you won't have to pay anything. It's fairly easy, and if you don't buy any, no harm done.
Old June 12th, 2009, 02:55 PM   #10
Elfling
Elfling's Avatar
Motorcycle(s): 03 Ninja 250, 02 CBR600 f4i
You don't have to buy in quarts from Color Rite- they sell little pens full of color for a lot less. BF says his primer and special colors ranged from 10-30, but they have lots of smaller amounts to get.
Elfling is offline   Reply With Quote
Old June 12th, 2009, 03:07 PM   #11
Elfling
Elfling's Avatar
How much are you looking to cover, Pur?
For example, this is pricing for my f4i silver:
touch-up Pen +$15.95
Touch-up Jar +$20.95
Aerosol +$33.95
1/2 Pint +$81.95
Pint +$119.95
Quart +$189.95
Old June 13th, 2009, 02:00 AM   #12
Purspeed
Purspeed's Avatar
Aerosol +$33.95
1/2 Pint +$81.95
Pint +$119.95
Quart +$189.95
Thanks for the tips all. I'm looking to fill a few scratches, that's all. I think that a pen will do, but from what I read, I need a base and a secondary color. I wonder if I can get away with just the base or overcoat? Hmmmmm...
Anyone?
Old June 13th, 2009, 10:03 AM   #13
call them and ask.
Old June 13th, 2009, 03:20 PM   #14
Purspeed
Purspeed's Avatar
call them and ask.
I did a few years back and they always tell you that you need to buy all of the combo's (sometimes up to 3). But, in real life, you may be able to get away with buying the main color only.
Old June 13th, 2009, 05:14 PM   #15
Elfling
Elfling's Avatar
Yeah, BF says if you just want something that blends mostly in, you can try just the top or middle color; if it's a thinner scratch you can get away with this pretty easily.
08+ Right Side Fairing (Cowling) & C.P. Blue Touch-up Paint Wolvy Items Wanted 6 May 24th, 2012 08:54 PM
Touch up paint? Betlog General Motorcycling Discussion 6 December 27th, 2009 03:13 PM
